Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Spots in top center portion of screen
Spots or splotches appear to be yellow or pinkish when viewed on lighter back ground
  • joepirraglia Aug 07, 2008
    My unit began to show reddish or pinkish smudges on screen after 3 years or so. This is not dirt on the surface.  This is something else.  It is now 41/2 years old and these splotches or smudges now cover the whole screen, darker and closer at the center, radiating out in all directions with lesser splotches.  When I first noticed this I contacted Sony and was told the unit was no longer under warranty. Sony said there was a know problem with the units 3 color module.  Dust or dirt was thought to be the culprit.  I was told to have the unit serviced by a licenced repair shop and submit a claim for POSSIBLE reembursement.  The replacement module cost $1,800.00 plus labor = over $2,000.00!!!!!  I bought the unit for $2,300.00 and was not about to sink in that amount without assurance I would be reembursed.  Back then I did find a web page that detailed a way to remove the module myself and clean it.  I can no longer find that site.
    Does anyone know of a method to fix this?  Please help!
I believe this is what you are looking for
http://splinke.googlepages.com/sonykdf-55wf655opticalblockreplacement
Posted on Aug 13, 2008
I have a hitachi 50vs69a with 2 yellow spots in the middle of the t.v when powerd on.....black when off. these spots almost resemble states...there is also blue splotches in the middle of these spots. any...
Yes, if the spots are round or teardrop it may be burnt picture tubes.
Easy to confirm this by covering lens of tubes one at a time with set on and see which removes the blotches.
What happened in a lot of these sets is the set arcs and burns a black dot dead center in one or all three of the screens of the picture tubes used--fatal case and permanent.
Mar 14, 2012 | Hitachi 50VS69 50" Projection HDTV
73' Mitsubishi has magenta splotches moving around screen and eventually getting larger until whole screen is covered.
bad main digital board. It's the bottom board on the left, try Encompas Parts to get digital board.
Nov 27, 2011 | Televison & Video
My tv has black splotches or pools on the bottom
If the splotches are a shawdowy black and look like mold growing between the Lens, its most likely dirt or water spots on the bottom of the large mirror. I cleaned mine and missed a few water spots on the bottom of the large mirror and the splotches (spots) showed on the screen. Other than Dirt, or water spots, There is nothing else that I can think of that would cause this. Unless the Someone has cleaned the screen and it soaked up between the lenes. But it Takes about 30 minutes to disassemnble, give it a good cleaning and put it back together.
Nov 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Color splotch when TV is powered on, then TV powers down automatically
Good Day;
It is very common for this model from what you spoke. If you handy return to me, Big Irish, and I will continue to help you.
99.9 % of the time of what you stated it sounds like a shorted CRT, picture tube. I have seen hundreds.
First, call the manufacture and complain about your concern and ask them for a CONCESSION because your tube has gone out.
2.If that does not work ; call a factory authorized service dealer to confirm problem and get an estimate, then return ti #1.
Good Luck, Day, Big Irish. I hope I helped.
Jun 15, 2008 | Sony KP-51WS510 51" Rear Projection...
Yellow spots are appearing in the upper right quadrant of the screen. After the set has been on for a couple of hours a second spot appears in nearly the dead center of the screen. This issue coincides...
Try the new lamp as indicated by the blink codes. That may resolve the problem. If not, the problem is in the "light engine" portion of the set which should be covered under warranty.
Keep us posted.
Dan
May 29, 2008 | Panasonic PT-52LCX65 44" HDTV
Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Bright spot on my 52hm95
can see it in certain lighting and even when the TV is off! It will appear lighter than the surrounding areas at times and can be annoying. I called Toshiba and had a service man come out and even though he acknowledged that this is common, Toshiba will not replace the screen.
Feb 11, 2008 | Toshiba 52HM95 52" HDTV Projection...
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Blue Spot in top center of screen
same problem, guy said i need a COLOR DRIVE!! $1000, trying to find cheaper
Jan 07, 2007 | Hitachi 60V500 60" Rear Projection...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
147 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
