Question about Sanyo Televison & Video
Sanyo dp50749 vertical wide black lines on screen
  • 586 Answers
SOURCE: Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Posted on Jun 27, 2009
SOURCE: Line in middle of LCD screen
I have the same problem, black line running right to left accross the screen, warranty still is active and sharp's customer service seemed very helpful. Seems like a technician should be here soon to fix the tv
Posted on Apr 09, 2008
SOURCE: philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Posted on Jul 22, 2008
Dissolu
  • 221 Answers
SOURCE: Black vertical column
for your reference regarding black vertical lines
http://www.metacafe.com/watch/3009132/video/R/CFD_1002/
Posted on Jun 29, 2009
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
I had one vertical line it cam and went for awhile then stayed permanently and I took it in for repair only to be told they couldn't fix it now they are trying to give me a used tv (warranty don't want to pay) but I refuse I purchased it new and I told them I want a new one. I had that tv less than 2 years. So if you have a warranty and lines get it in fast.
Posted on Mar 26, 2010
Vertical linesman a Sanyo #DP50749. Occasionally the screen turns black for a second with no sound. Sometimes perfect pucture?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 09, 2016 | Sanyo Televison & Video
On a plasma 50 inch tv Sanyo model number DP50749 it got black line coming down the front of the tv, what is the problem
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 04, 2014 | Sanyo DP50749 50 in. Plasma TV
Black lines screen vertical
It sounds to be a COF fault. If you wish to get more details, check the site linked here. Pull up older posts. It has screen-shots to defective plasma and LCD TVs, along with some details to locate the faulty section.
Dec 01, 2013 | Televison & Video
Approximately. 2" wide vertical black line top to
You may need to adjust the resolution of your laptop to fill the full screen of the TV.
Sep 27, 2013 | Televison & Video
I have a Sanyo 50" Plazama, model#DP50749, it is 2 1/2 years old and there is a bunch of vertical lines on the screen, I have unhooked the service box and the lines are still there, any help would b
tried to disconnect other connector cable that have been hooked in the component input of your tv which may cause of video interference. if still the same problem, at this time you will need to remove the back cover of the tv and then tried to re seat connector going to buffer and main board might have loose connection. but make sure you have to turn off and unplug the tv before you do this good luck.
Oct 24, 2012 | Televison & Video
Sanyo DP46848 LCD TV has black screen with colored vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 16, 2017 | Sanyo DP46848 LCD TV
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Televison & Video Logo
120 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
