Question about Panasonic Audio Players & Recorders
Can hardly hear the record playing on an old panasonic se 2519 turntable. How do I know if the cartridge, needle, or belt needs replacing?
  • Panasonic Master
  • 5,158 Answers
The belt will only need replacing if it breaks or falls off, or the sound has wow and flutter on it. It will not effect the sound level. First has the sound level gone down or is this the first time you have connected it to your amp?
If it is the first time, you need to check the amp has a 'magnetic cartridge pre-amp' built in. If you don't know look at where the turntable plugs in. If it doesn't say phono or record deck etc, then it most likely doesn't. In which case search on the net for one.
If the sound has gone bad then: (A) sound quality poor - change stylus. (B) sound level low change cartridge. A good test to determine it's the cartridge is to remove the wires to it. With your amp working touch them one at a time. You should hear a loud buzz on the right on one wire and and another buzz on the left on another wire. The other two wires should not produce any sound or little.
If you do hear the buzz then the cartridge is faulty, if not then either the amp isn't working or the connections between the two devices are faulty.
Posted on Nov 20, 2010
How do I get a replacement needle for model #9408mo?
If you look at the cartridge that the stylus fits in you should see a make and model number for the cartridge. Put that into Google and the rest of your questions should be answered.
You don't need to phone anyone.
Oct 02, 2014 | Audio Players & Recorders
I bought an old Garrard turntable. But when I put a record on you can't hear it playing through the speakers. I thought it was the needle but I replaced it and still no sound through speaker. I know...
Firstly check all the connections to the cartridge where the stylus fits. If they are OK. Remove them and with the amp on touch each wire -one at a time- with your finger. If the system is OK you should hear on two wires a buzz - one for each channel. If you do replace the cartridge. If you don't, then there's either a bad connection, or a faulty pre-amp inside the stereo.
Jun 14, 2013 | Audio Players & Recorders
Well im not too sure if my needle is broken but when i play a record i cannot hear sound and it sounds like my record is being scratched. Do i need to keep the white cap on the needle or not? or is it just...
It's called a stylus. What red or white caps are we talking about? Some phono cartridges come with stylus guards that flip up out of the way for play or down to protect the stylus from damage while in storage or during tonearm balancing. The stylus needs to touch the record groove directly.
Jul 14, 2010 | Numark ttUSB Turntable
I just inherited an old Zenith console turntable and stereo combined. Stereo sounds wonderful, but when I play records, the sound isn't loud. Is this a problem with the needle or what? When I touch the...
Hiya, check and be sure the turntable is plugged into correct inputs, "phono"
If thats OK, then probably is the stylus but could also be the cartridge itself. Check the wires on the back of cartridge make sure they are fixed properly. If all Ok, then start with a new stylus first.
Hope it helps
Jul 25, 2009 | Audio Players & Recorders
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
Crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Dec 12, 2008 | Crosley Conductor CR73 Turntable
1210 problem
Those are just standard phonograph player characteristics in my experience. You'll hear a tap on the deck because there's essentially a live mic ( the needle ) physically coupled with the record on the turntable and the rest of the phonograph player even though they try to dampen the coupling of the turntable as much as possible. The rumbling noise at high gain is because the turntables being driven by a motor via gears or a belt and creates some  vibration, wich is transmitted through the turntable and picked up by the transducer ( needle ), low frequency rumble, just like a recording studio on a busy street may pick up from road vibration/ noise.
Aug 06, 2008 | Technics SL-1210 Turntable
Tone arm is hard to move and when it's placed on a record the needle sticks at on spot on the record. the same needle and record plays fine on other technics 1200 mk5. seems like the arm has resistance in...
You have a bad tone arm. I have the same tables. You need to get it repaired if under warrenty. Or there is a service manaul online you can get from ebay. Service center for our tables is Panasonic.
I had the same problem on mine. But while it is in the shop they recalibarte it
Feb 13, 2008 | Technics SL-1200 Turntable
PANASONIC COMPACT AUDIO SYSTEM MODEL #SG-HM22 help
some models have a hole(s) in the turntable under the mat. You can put your fingers through the holes in the turntable to fix the belt into position. Good Luck.
Oct 28, 2007 | Audio Players & Recorders
253 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
