Question about HP Office Equipment & Supplies
When we press start to print a document it makes a squeak noise continously until the project is done. What is wrong?
    Genius:
  • HP Expert
  • 1,325 Answers
Sqeak noise usually indicates that the rollers need replacing or maintainace required --most likely the fuser assembly kit needs replacing (includes rollers & fuser)
what is the printer model ?
Posted on Nov 14, 2010
Faded print
using the D-pad on your printer, scroll down the menu until you get to "maintenance"
Press OK
Scroll down to "clean printhead"
press OK
The printer will now make some noises and after about 30 seconds will say complete.
Now scroll down once more to "Print test page"
press OK
load paper and press the start button
Iff the printed page looks ok...job done. If still faint, repeat the above steps once more.
Nov 18, 2013 | Kodak ESP5250 All-In-One InkJet Printer
When removing the document that prints, how do I remove it from the continous paper without wasting a sheet every time?
Press the view button tear off the paper then press view button again and the printer will bring the paper back down, I think anyway
Mar 23, 2012 | IBM 6400 Matrix Printer
Kenmore dryer he2 - loud continous squeaking noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 20, 2011 | Dryers
Hi I have a HP LaserJet 1320 Printer and when sending multiple documents it is pausing between them. I have to press the Green button to make them print, until the start of a new document when I have to...
Is the paper size set on the computer for the size of paper you are printing to?
Usually if you have to give a 'thumbs up' to the printer is because it is trying to print on an different size paper.
Aug 09, 2011 | HP LaserJet 1320 Printer
When the dryer gets hot, the tumbler begins to make a continous squeaking noise as if there is metal to metal; not a grinding noise. If you allow it to cool down and restart, it doesn't start until it...
Well ya never mention in your question what brand you have but a GE or Hotpoint dryer has a small plastic insert that wears thin over time. It begins to do a squeak squeak squeak type of noise.And that noise is intermittent, on a Frigidaire model the noise would start out low and gradually get worse. The bearing sometimes gets so bad it gets chopped off and the tub falls into the heating element.
Jun 30, 2011 | Dryers
When ever the dryer is running it make a horrible squeaking sound until the load is done. How do i stop it from squeaking?
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 20, 2010 | Dryers
My car makes a humming noise when excellerating and is especcially noisey when turning steering wheel to the left. there is also a continous squeak. my husband put WD40 on the bolt on power steering box...
If WD-40 got on belt, and squeak went away for a while, it may just need a new belt. The humming noise sounds like a worn wheel bearing that should be checked and replaced if needed. If squeak goes away when you push slightly on brake pedal, it may be rotor on same side as wheel bearing making the noise due to slight shifting of rotor because of worn bearing.You can try swapping tires on front from one side to other to confirm it isn't tire problem as well. If noise shifts to other side, then it's a tire.
Dec 03, 2009 | 2003 Pontiac Grand Am
Printer squeaks when printing
remove the fuser wiper if the noise is still present remove the fuser and turn by hand. fuser bearings will cause this
Aug 28, 2009 | Lexmark T632 Laser Printer
HP 1720 I making a noise when printing.
    NOTE: Refer to the Testing section in this document for instructions on performing the tests.
  1. Turn the printer off, and then turn the printer on. The grinding or squeaking noise should not occur while the printer is initializing.
  2. Perform a paper path test. The grinding or squeaking noise should not occur because the carriage should not be moving.
  3. Perform a self-test to localize the noise.
  4. Check the printer for obstructions by lifting the top cover and making sure nothing is blocking the carriage movement.
  5. Check the paper path by following the instructions below:
    1. Remove all media from Trays 1, 2, and 3.
    2. Pull out any visible stuck paper.
    3. Lift the top cover, and pull out any jammed paper.
    4. If you are unable to free the jammed paper, pull out the handle of the paper knob, pull the knob away from the printer, and rotate it to remove the paper.
    5. Lower the rear access door by lifting up on the two rear door latches.
    6. Remove the back panel by pushing the two catches inward.
    7. Pull out any paper that may be stuck inside.
  6. Wipe down the milky white strip (see Figure 1) that the front of the carriage glides on with a clean, soft, dry, lint-free cloth.
Figure 1: Location of the white strip
bpp90119-1.gif Replace the whole unitgtabtop.gifIf the printer is still making a grinding or squeaking noise after following the steps above, replace the whole unit. See Whole Unit Replacement instructions, which are included with the whole unit replacement.
Testinggtabtop.gifUpon replacement of the whole unit, perform a Paper Path test and a self-test as described below to verify that the new unit is functional.
    Performing a paper path test
    1. Press the MENU button on the printer control panel until Diagnostics Menu is selected.
    2. Press ITEM until Perform Tray x Paper Path Test is selected.
    3. Press SELECT to perform the test.
    NOTE: The paper path test will terminate only when the paper in the tray being tested runs out or the printer is turned off.
    Performing the stand-alone self-test
    1. Press the MENU button on the printer control panel until Self Test Menu is selected.
    2. Press ITEM until Print Menu Map is selected.
    3. Press SELECT to perform the stand-alone self-test.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | Dell 1720dn Laser Printer
Squeaking noise when printing
Probably, but you?re going to have to try to isolate the problem a little better. Typically this would involve removing side panels and such; however, you may just have a faulty consumable like a toner cartridge, fuser or more likely the transfer kit. I typically try to isolate the sounds location then try replacing some of the consumables in that area one by one. In your case if you can?t isolate the location I would start with the transfer kit since that has a greater chance of making noise. Let us know what you find out and please don?t forget to rate the posting when we?re done.
Feb 02, 2007 | HP Color LaserJet 5500hdn Printer
114 people viewed this question
Seeker5211
Seeker5211
