Question about Garden
Troy Bilt RTZ Mustang ZT50 When I put it in reverse the blades turn off. Cant mow in reverse. How can I turn off safety feature
3 Suggested Answers
  • 133 Answers
SOURCE: new troy bilt mower (pony) when you put it in
It is a safety feature. You can disconnect it if you want. Where ever you place the tractor in reverse there will be a switch . Try disconnecting the switch an use a piece of wire to act as a jumper. You will put the piece of wire with insulation on it so it doesn't short out into the ends of the wire harness that is comming to the switch. Once the jumper is installed try starting the tractor and engage the blades and put in reverse. If it does not shut off and runs alright then you can cut the end off of the wire and using a wire connector join the two wires and wrap with electrical tape. YOU HAVE TO BE VERY CAREFUL AFTER YOU DO THIS BECAUSE THE BLADES WON'T SHUT OFF WHEN IN REVERSE!!!
Let me know if this helps.
roundo4
Posted on Aug 25, 2009
al_kupchella
  • 843 Answers
SOURCE: are the nuts holding on the blades reverse threaded?
If a blade, when viewed from above, rotates clockwise, it will have right-handed threads. This is because the shaft is turning to the right, and the resistance imparted on the blade will tend to tighten a right-handed fastener. If a blade rotates counter-clockwise it will have a left-handed fastener. I don't know this mower, but this is a universal thing.
Posted on Apr 23, 2010
How do I make my Troy Bilt Colt XP zero turn mower mow in reverse
it may have a separate setting with the key. mine after starting you turn the key back one notch and it will let you mow in reverse. hope this helps.
Apr 24, 2016 | Troy Garden
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
Troy bilt mower pony
are your blades engaged when you try to do this??
if so it is a back up safety feature from factory,turn blades off and try?
Or put the ignition switch in the position that will keep the mower running when you go in reverse with the blades on or push a button on dash when you go in reverse,probably not on yours just some of the features on some models and just something to look for on yours
Aug 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 50" troy bilt zero
All riding mowers have a seat safety, blade engage safety and a brake clutch safety, some mowers have a reverse mowing safety. Seat under the seat, blade and brake you will have to check the linkages underneath, and if there is a reverse mowing one I have seen them near the shifter handle right under the fender.
Aug 23, 2011 | Garden
Put a new battery on it and still wont turn over
Check all of your safety circuits: Drive safety, blade safety, seat safety.
Naturally, ensure that your key circuit is operating.
Gary
Dec 20, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt self propelled assembled in the box got it out of the box and finished setup but when it came to the pull start cord it would not pull am i missing something?
The unit has a safety feature that stops the engine with a brake when you release the handle. In order to start the engine you have to release this brake by squeezing the handle lever as if you were mowing. You have to hold this lever in that position as you pull the cord.
Aug 02, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Put mower in reverse, turned it off and mower
There are safety interlocks on zero turn mowers. These prevent starting unless you have: 1. the handles in 'neutral' position 2. the brake on 3. the mower engagement (PTO) switch off 4. yourself in the seat.
Chances are one of these conditions hasn't been met. Since you were reversing when it happened, perhaps you haven't got the handles back to neutral position?
Jul 06, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
New troy bilt mower (pony) when you put it in reverse and engaugethemower the engine will die. Is this a safety feature and if so can itbedisconnected, cant always mow going forward
roundo4
Aug 25, 2009 | Garden
Troy bilt mower self propelled 21". Belt has come off
Take the three screws out of the belt cover. One screw in behind each back wheel. The other is under the mower near the shaft to blade. Remove the tension spring off the transmission. Then remove blade and the cover comes off. You then can put the belt back on. Sounds like fun don't it!
Jun 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
376 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
