Question about Denon Audio Players & Recorders
I have denon 1311 reciever, which I have purchased a month back in bangalore. I love this product, but the problem I am facing is that it gets hanged after some time of switching ON. But is not always repeating. Till not this would have happened for atleast 15 times. Each time this happens, we are required to remove the power plug and again plug in, since even the power ON/OFF button on the panel does not function. Is their a solution for this problem. I am highly dissapointed by finding this kind of nuisance problem in a product of Denon.
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
SOURCE: denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Posted on Jul 06, 2008
Foxyjay
  • 13 Answers
SOURCE: Power Button Flashing Red
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
Foxyjay
  • 13 Answers
SOURCE: Denon AVR-1508
Hope thats of use!
webdevil
  • 43 Answers
SOURCE: HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Posted on Jan 06, 2009
Samsung galaxy gt i9003
tryed new firmware? official or not
May 20, 2013 | Cell Phones
Is there a way to get a Denon rc1146 remote to work with a Denon 3310 receiver?
If you have already tried it and it doesn't work, than there is nothing else that you can do other than purchase the correct remote or just go to a universal remote. You would think that denon would keep their ir codes consistant through different models of recievers.
Jan 05, 2011 | Denon Audio Players & Recorders
Connected denon avr 1800 reciever to new hd tv. i cant find my reciever manual. how do i set the reciever to play the tv sound?
If you connect your tv's audio output to the reciever's audio input in the (TVor video section) using audio cables only---red & black or red & white) then select TV or Video on the front of the reciever depending on which connection on the back that you use it should work fine!!
Nov 06, 2009 | Denon AVR-1800
How do i hook an i-pod to my denon-AVR3801. Headphone jack? If so what function?
I'm assuming you want to play your i-pod through your reciever? If so, you need a male stereo mini to dual male RCA Y-cable (follow the link at the bottom for an example). The mini end goes into your i-pod. Plug both RCA's into the CD or PHONO inputs on the left side, center, as you face the rear of your reciever. Left(L) is usually white or grey and right(R) is the other color, usually red or orange.
I hope this gets you started. Ask again if you have more questions.
http://www.bestbuy.com/site/olspage.jsp?skuId=7005457&type=product&id=1099392032460&ref=06&loc=01&ci_src=14110944&ci_sku=7005457
Dec 03, 2008 | Denon AVR-987 Receiver
How do I purchase a remote
just look for a remote that says on the back of the package that it supports your reciever make ( denon ) and has the extra functions that support that reciever ( audio support remote )
electech
Nov 26, 2008 | Denon AVR-1403 Receiver
Why do i have static and then no sound ?
Hi...
You have a faulty reciever.
Take it back and get another.
No sense in going any further.
Nov 14, 2008 | Denon AVR-1908
Elvis Phone
So the handset is not heavy enough to hang up the phone? This is a new development? The spring for the hookswitch may have gotten jammed in the wrong position causing more spring tension. It sounds like a fairly easy fix. You may find a local TV, VCR, etc.. repair business willing to look at it.
Nov 27, 2006 | Novelty Elvis Phone (w-elvis)
362 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
