Question about Clarion XMD3
Clarion XMD3 Aux problem with IPOD
I have an XMD3, and am attaching an IPOD via the aux in cables. Works fine, except I'm only getting sound out of the right channel front and rear.
Any input will be greatly appreciated.
  • 2 more comments
  • geoffvt Jul 01, 2008
    There are three sets, black, gray, and red. The black and gray are sub', and the red are aux.
    If you go to the clarion website, and pull the wiring diagram from one of the other marine stereo's, it will get you close enough.
    HTH,
    Mine is just bad, I changed cables and it didn't work. I know several others that work fine.
    http://www.clarion.com/us/en/MungoBlobs/...
  • Anonymous Apr 26, 2009
    Same problem, hooked up and only get sound pit of front spekers from Ipod. Alos sound plays all times not just on auxillary.
    Second if unhooked from IPOD all works like before.
  • Pat b Apr 26, 2009
    I am having the same problem, did anyone figure out how to get it working with all four speakers?
  • unplugged1 May 11, 2010
    I also have an XMD3 and the manual refers to the aux inputs, but the wiring diagram does not show them......what did you connect to???
KaeZoo
  • 156 Answers
SOURCE: auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Posted on Mar 15, 2007
  • 6 Answers
SOURCE: mp3 to aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Posted on Nov 04, 2007
SOURCE: I can't use my ipod.. pressed SCR and only tuner and standby is displayed
Yes i had a very similar problem.
I have the MP-235. I could not edit my clock, my subwoofer settings werent active, and I could not switch to AUX.
If you have these problems, you have to hold down the menu button (bass boost) to enter the menu. then scroll around, turn AUX on, change the clock, etc etc.
You turn demo mode off the same way. Kinda silly how they have it all set up.
Hope that helps anyone in the future. i just wasted 3 hrs with this crap!
Posted on Dec 27, 2007
Eagleeyes
  • 199 Answers
SOURCE: AUX inputs
http://www.service.pioneer-eur.com/peeservice/instrmanuals.nsf/0/7250595BA2950068C12570EE0049C3FE/$File/XRD7099_DEH-P6800MP.pdf
ok spoken to pioneer technical. page 46 and page 49 see above link for user guide.
let me know how you get on.
Mark
Blue ICE
Posted on Feb 26, 2008
SOURCE: NO SOUND FROM CLARION XMD3
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
Posted on Jul 08, 2008
Will the clarion cy460 play mp3s?
Why don't you play them via Bluetooth or Aux cable, far easier.
Jul 21, 2014 | Clarion Car Audio & Video
How do I attach an MP3 player to the receiver? I have an Bose Accoustimass 15 attached and am using the AUX but only getting muffled sound from the sub-woofer and none of the speakers are working with this...
Try another source on AUX to prove the AUX works ok with all speakers.
Any iPod, smartphone or MP3 player at its most basic level is just an ordinary analog audio source.
For just listening, any audio device with a headphone/earbud output can be connected to any available analog Line Level input (except PHONO) with a simple adapter. They don't tell you that in the iPod manual because they want you to purchase expensive accessories like docking stations. You'll still have to control the music from the portable device. Oh well.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
Sep 20, 2011 | Sony STR-DE697 Receiver
Is there a way to wire in for an ipod
Only way would be via a FM modulator which I would not recommend. There is no Aux input cable or port on the XMD2.
I would recommend upgrading to a newer model with full ipod control and charging capabilities. Any Clarion dealer can help you with that.
Feb 04, 2011 | Clarion XMD2 CD Player
My daughter has an Iwantit ipod speaker model IW900 and it works/sounds fine with her ipod usind the dedicated ipod connector. On the the back of the speaker there is an Aux in socket. She would like...
It took me a while to figure this one out. Firstly plug your device in to the aux socket and play some music so you can hear when it's correctly switched over. Turn on the iwantit using the switch at the back then press the play button once, you should see the lights on the buttons go brighter. Now press the play button again, this time holding it down for exactly 3 seconds. When you release the button you should be in aux mode and you should hear your music playing. Hope this helps, it took me about an hour of faffing around before I finally figured it out.
Aug 16, 2010 | Audio Players & Recorders
How do you connect an Ipod throught the aux input?
what type of input does your radio have? if its a head phone jack input just get a headphone to headphone jack wire from radioshack and plug one end into you ipod and the other into the radio, set your radio to aux and your ipods volume to 70-80%. if its an rca input, it exactly the same but you will need an rca to headphone jack wire. if its usb, just use the cable that came with you ipod.
May 01, 2010 | Clarion XMD3
No Sirius function available.
I have the same problem. When scrolling through the source options, the display goes from tuner-cd-aux and back to tuner...no sat. radio. need help.
May 29, 2009 | Clarion XMD3
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
XMD3 unable to select anything but satellite
i have had several problems like that. It is probably one of your controllers especially if you have the old oval ones. Go to the back of the stereo and unplug them, then plug one in at a time and isolate the problem to a controller.
Jul 19, 2008 | Clarion XMD3
Connecting my ipod to xmd3
I believe that if you use the RCA connectors, you can use your iPod. If you use the clarion cca connector, you get more functionality from the dash of the clarion.
Jul 07, 2008 | Clarion XMD3
No sound from MP3 player
Is there an IPOD or AUX function on your system?
Feb 12, 2008 | Kenwood KDC-135 CD Player
Clarion XMD3 Logo
1,967 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
