Question about Hotpoint Aquarius WF000 Front Load Washer
How to replace drum bearing for hotpoint aquarius+ wf740
When my machine is in full spin it's extremely loud but only when a load of washine is in, even really small loads cause a lot of noise. When the machine is empty it makes the normal sound. It's so loud that you need to shout over it to hear yourself.
How do you fit a new drum bearing?
  • 5 more comments
  • swainnr43 Jun 25, 2008
    I have exactly the same problem. Looks like a common problem.
  • eg0011g8189 Jul 26, 2008
    hi, my machine was making a load noise (like a banging noise while on spin). i bought brushes for the machine. my husband sayed it's not the brushes. where am confused we both dont know what the problem is. it has stopped spining. can you help? my machine is hotpoint wf000 and 3 years old.
  • harveyalmo Oct 13, 2008
    need 2 change the bearings on my hotpoint aquarius 530 but it seems 2 be a sealed drum, how can i do it please
  • russie55 Nov 06, 2008
    i have a hotpoint aquarius+ wf740, and it is v loud on the spin cycle, i suspect its the bearing, am i right? if so how easy is to do??
    regards russ
  • hill_gary1 Nov 07, 2008
    I also have the Hotpoint Aquarius WF430 which when spinning deafens the neighbours!!! If anyone can assist would be appreciated..
  • bobwrigley20 Mar 15, 2009
    I have the same problem, how hard will it be to split the drum in half to replace the bearings ?
  • robert samples May 11, 2010
    how old is your washer and what kind of noise are you hearing you are talking a major chore here and i don't think you can get the tub bearing separate anymore its pressed in the back of the tub and you have to buy the back half of the tub but it can be done whats your model number
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Posted on Jun 25, 2008
  • swainnr43 Jul 22, 2008
    My machine is a WF430, will I have to replace the drum or can I just replace the bearings.
Have an hotpoint aquarius 530 how can i change the bearings please
Posted on Oct 13, 2008
2 Suggested Answers
SOURCE: How to replace a Hotpoint Aquarius+ WF740 drum bearing?
I had the same problem and it turned out to be the ballast securing bolts had sheared off and the back of the drum had to be replaced
Posted on Dec 24, 2008
I have got a Hotpoint Aquarius + WF740 1400 spin speed. When the drum is moving slow inbetween cycles there is a wereing noise, In the wash cycle it clunks but it's ok in spin mode. When I move the drum...
there could be something stuck between the inner and outer drum, eg. a bra wire a common culprit.
inside the drum you have 3 lifters ( blue pillars). remove one of these by pulling it towards you.this will allow you to see into the inner drum. get a flash lamp and have a good look rotating the inner drum around.
if you see anything get a pair of pliers to pull in out as you cant get a nasty cut.
replace lifter as u removed it.
if bearings were gone would sound like a tractor while spinning.
Mar 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a aquarius hotpoint 340, bearing gone
You have to split the drum to replace the bearings
The reason the bearings have gone is that water has leaked into them and the soap content has destroyed the grease
There is a carbon seal on the spider assy which attaches to the back of the drum , this normally cracks so the spider or seal has to be replaced
Feb 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
WF340 hotpoint aquarius WASHINING MACHINE
Hi, Remove the drive belt from the drum & motor then turn the drum be hand, Is it noisy? if it is then the drum bearings need replacing i have used this website before and they are very good.
Apr 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Bearings on Hotpoint
Apr 07, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
2,304 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
