FIOS / Cable box needed?
With FIOS, I'd prefer not to use a cable box as I'm planning on hanging the TV on my wall. What channels will I receive? What type of TV do I need to buy?
    Novelist:
    Champion:
  • 216 Answers
Greetings mjt444,
It appears that with basic FIOS you will recieve between 15 and 49 channels. You would most likely need to consult with Verizon to find out more specifics on that. As long as your television is high definition ready, it should not matter what type you purchase, however one with an internal tuner would be preferrable. I would ask your local sales person what type they recommend. The sales staff in any Best Buy™ store should be qualified to answer these types of questions.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Posted on Jun 18, 2008
Yamaha rx-v367 and internet tv audio
try connecting the hdmi out from cable box to your tv hdmi input, and leave the hdmi out from tv to the reciever where it is, leaving reciever selected to 'TV' and yes, a sub matters (it is not part of your problem but you need the bass a sub provides)
Mar 05, 2013 | Yamaha RXV367 Receiver
I got a hd box and the channels keep cuttin out
Hello, I actually install HD boxes for Verizon Fios. If your video signal is too low, you will notice "Pixellation" (Those weird square boxes that come and go) and in some cases, you will not even be able to receive some channels at all. HD channels use much more bandwidth than standard definition channels. The good news....there's a fix. If you use standard cable (Not Fios) you can buy a signal booster. These can be purchased at best buy, Radio Shack, etc. It is a powered device that plugs into an outlet (110v) You take your cable company's input or "Feed" run it into the booster, connect the power, and the run a coax cable out of the booster and into your splitter. Assuming all of your cabling is up to par, this will fix your problem. If you have Verizon Fios, you must call and have us come out as our tv service uses "Moca" and cannot be boosted with a store bought unit. I hope this helps.
Jan 03, 2011 | Televison & Video
Connected the coaxial cable to the tv but got no channels. the tv turns on but all I have is snow
Some possible things to check:
1. Are you trying to receive off-the-air broadcasting? If so, you'll need a digital converter box. This set doesn't have a digital tuner, so there won't be any channels for it to receive without the converter.
2. Are you connecting a cable from a cable converter box, satellite receiver or FiOS set-top box? Your TV will need to be set to channel 3 or 4 to see the signal from the device.
3. Make sure the center wire in the plug on the end of the cable isn't bent over, and that it extends far enough (about 1/8 to 1/4-inch) to make a good connection.
4. Do you know for sure that the cable you are connecting is working? Is there actually a signal on the cable? It may be disconnected somewhere else (at a splitter, for instance) or there may not be any signal source.
5. Have you tried another TV to test the cable? If the cable works with another set, the tuner or antenna connector on the snowy set may be bad. If the cable connector is tightened too much when hooking it to the TV, the connector may be damaged and this can cause the snow.
Start by checking with a known good TV. If that one is snowy, you can check the other possibilities. If it works, you'll know the problem is in your set and can decide what to do (repair or replace).
Hope this helps! Thanks for using Fixya.
Nov 08, 2010 | Toshiba 27AF42 27" TV
Setting up a new TV
you will receive upwards to 150 channels (depends on how the tv is designed) you will not receive all the channels which you receive on the tv which has the "box". You will need an addtional box if you want to receive essentially any 200 or above channel.
Hope this helps
Apr 12, 2010 | Samsung Televison & Video
How do i hook up my 16-454 to my verizon fios cable?
I am not sure what a FIOS use, but I was able to split my cable connection and was connect my regular TV AND portable tv with the cable.
IN YOUR CASE:
Look at your fios set up box, behind the box, there should be something that would say "TO TV" or "VIDEO OUT" or "TO TV/VCR"
Usually, the cable coming out from there goes to your regular TV. So instead of your regular TV, you can connect that with your portable TV.
AS FOR MY CASE (Having 2 tv's),
1. I removed the cable that is connected to the wall (RF IN or From WALL or CABLE IN).
2. I hooked that end to the "IN" part of a 3 way splitter
3. I bought a short cable and connected one end to the Cable Box and the other end to the OUT of the splitter
4. I bought a longer cable and connected one end to the portable TV and the other end to the OUT of the splitter.
5. Then I turned on the TV and pressed MENU
6. I clicked the right arrow until I see ANTENNA. I pressed the down button to choose CATV instead of AIR.
7, I did auto scanning.
My portable TV now has the basic channel while the big TV (since it is connected to the cable box) has the added digital channels. Nevertheless, it is great to have both so when I want to sleep, my hubby can just use the small tv
Jul 02, 2009 | Accurian 16-454 Television
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Jul 28, 2008 | Sanyo DVW-5000 DVD Player/VCR
Can you help me?
go to verizon.com and look up fios tv and then from there go to installation and then troubleshooting
Apr 09, 2008 | RCA F27625 27" TV
Televison & Video Logo
Top Televison & Video Experts
