Question about Whirlpool Kitchen Ranges
Can't unlock model # mt9160xyq-1 - Whirlpool Kitchen Ranges
How unlock my LG 420G to use sim card?
en you receive your email with your unique LG unlocking codes, you may see there's actually more than one code as some models require more than one code to unlock them fully. However, for simplicity, we do aim to send you a single unlock code.
Depending on your modelption 1 method - LG Models
To enter your unlock code, LG phones often require access to a hidden menu first. To access this menu simply enter the digits 2 9 4 5 # * 7 1 0 0 1 #.
1. Insert an original SIM card and turn the phone on
2. Access the hidden menu by typing 2 9 4 5 # * 7 1 0 0 1 #
3. Select 'Menu' and then 'Settings'
4. Next, select 'Security'
5. Select 'Network Provider' and 'Deactivate'
6. Finally enter the Unlocking Code provided. (Please note: Some phones require a slightly different access code - please see the list below if the above access code doesn't work for your phone.)
Option 2 method - LG Models
1. Insert a not accepted SIM Card and switch your LG phone
2. The phone will display 'phone restricted'.
3. Select Cancel
4. The phone will display 'phone restriction code'.
5. Enter the Unlock code provided
6. Select OK
7. Your LG will now be now unlocked
Sep 29, 2016 | LG Tracfone 420g - CePhone - DoubMinutes -...
Lg 440g unlock
Option 1 method - LG Models
3. Select Cancel
6. Select OK
Aug 04, 2014 | Cell Phones
Unlock lg440g cell phone
3. Select Cancel
6. Select OK
May 31, 2014 | Cell Phones
My phone is locked
Hi if your siemens A57 mobile is locked to network provider .Then you can easily unlock it using network unlock code .You can purchase code from sites like ClassicUnlocking.com they are rendering unlock code for all mobile models at reliable cost .You first verify that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone .
May 09, 2014 | Siemens A57
Unlock pantech p8000
How to enter the Unlocking Code for a Pantech Model phone Option 1 - Pantech Models
1. Turn on your phone with an original SIM Card in it
2. Type the following: * # 8 6 5 6 2 5 #
3. A 'SIM Unlock' Menu will appear, press Ok
4. Enter Unlock Code + * (8 digit code)
5. Re-enter Unlock Code + * (8 digit code)
6. The phone will display 'Unlock Process Complete'
7. Press Ok
7. The phone is now unlocked.
Option 2 - Pantech Models
1. Insert a not accepted SIM Card and turn the phone on
2. When prompted, enter the unlocking code provided
(Note: Use the onscreen keyboard and make sure that wireless mode is off)
3. Your phone will now be unlocked.
Option 3 - Pantech Models
1. Insert an non-accepted SIM Card and turn ON your phone
2. A hidden 'Sim Unlock' Menu will appear
3. Enter the Unlock Code provided
4. The phone will display the message 'Unlock Process Complete'
5. The phone will now be unlocked.
AT&T Pantech Crossover P8000 Unlocking Instructions
1: Turn on phone with Not Accepted SIM card.
2: A menu will pop up to Insert the code.
3: Insert the provided code and press OK
4: Device is now unlocked.
Your phone will be permanently Unlocked,it will not erase your contacts or any data from your phone.
Reasons to remote unlock your AT&T Pantech Crossover P8000:
* If you are travelling, buy a local SIM card and save on roaming fees
* The resell value of AT&T Pantech Crossover P8000 will increase significantly as it is available to more carriers.
* Easily switch between SIM card, using the same phone.
* Unlock your phone from the comfort of your own home
* You never send your phone to anybody.
* There is absolutely no risk of damaging your AT&T Pantech Crossover P8000 by unlocking it.
* Very easy, no technical experience necessary.
* The phone is permanently unlocked, even after updates
* Warranty will not be voided by this Code
* 100% Guaranteed, if we cannot get you your unlock code we will refund you no questions asked.
Jun 29, 2012 | Pantech Crossover (P8000)
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
Id like to unlock my lgks360 for free but im finding it hard. could you give me a code to do this please?
Only trust best unlocking specialist for unlocking your mobile , it will be the best & safest way for unlocking . In order to unlock your Lg KS360 MOBILE make use of this site wickedunlock ,select the network you need , then get the unlock code here , using unlock code specified in it proceed unlocking your mobile & gain solution .
May 28, 2011 | LG Cell Phones
My bmw 320d remote wont lock car however does lock the car with the key its a 55 reg
Programming
When
Key batteries completely discharged. Key batteries not replaced within 60 seconds. Key added or replaced. DO NOT press remote control buttons during battery replacement.
How
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 1 [1]. Press lock button Fig. 1 [2] briefly 3 times within 10 seconds keeping unlock button [1] depressed. Release unlock button Fig. 1 [1]. Some models: LED Fig. 1 [3] flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Some models: Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously
Later keys with bmw badge on key. Battery can not be replaced
Battery in key charges while driving
Dec 22, 2010 | BMW 3 Series Cars & Trucks
The doors do not open by remote control key(BMW 740il 1996 model)
Programming
When
How
To change batteries remove panel back of key then screws on plastic bar
Batteries are available from your local motor factor shop
You might not need new batteries try re programing as described above
Apr 24, 2010 | 1998 BMW 7 Series
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
Kitchen Ranges Logo
26 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
