Kenmore Elite Model 27086603 Trapped clothing
This top load machine has an inside stainless tub with about a two inch separation from the plastic outside tub enclosure. The stainless tub aggitates and spins inside this outer enclosure. At the top of the inner tub, if not careful when loading, socks or other smaller clothing can be pushed into the gap between the inner tub and outer enclosure. My question is, how do I get out the clothing that has found its way behind the inner tub?
  • Skeeter49 Jun 20, 2008
    A++++ This advice was dead on! Thank you soooooo much!!!! Just a follow up on this. The clips that hold the top to the front were very strong, so a fair amount of pressure was needed on the clips while sliding in a couple of flathead screwdrivers to pop the top off the clips. I suggest wrapping a cloth around the screwdriver and/or putty knife to avoid marring the finish of the washer. Having a second set of hands holding the top up because of the spring action of the lid was most helpful. Removing the plastic ring was easy. The bolt on the bottom of the tub required a fair amount of torque, so a large socket wrench worked best with a 7/16 socket. With an assistant, this took me about 30 minutes to remove the sock from under the tub. I did not have to take the drain pump apart. Now knowing how to do it, I suspect the next time it will take no more than 15 minutes. Hopefully, there won't be a next time.......
  • 246 Answers
Where the front panel and the top of the machine meet, there is a crack. When using a flashlight, you will see 4 items in this crack. 2 are green 2 are black. The black peices are support studs, ignore them. The green one's are clips that hold the top to the front. Using a putty knife (easier) or a small flat head screw driver (a bit more difficult) push one of the green clips towards the rear of the machine while lifting on the top. Only lift slightly (too far and it will bind on those support studs I told you about) Now press the clip on the other side and lift the top up. Now you should see your tub (from a new perspective) you will see a plastic ring around the top of the tub. Disconnect the green clamp on the hose towards the left rear using a pair of pliers or channel locks. The ring is held down with clips all of the way around the tub. By pressing down over each clip and pulling the lips slightly forward, you can remove the top ring. The rest is the easiest part. In the center of the basket, there is a small cap. Rremove this with a small flat head screwdriver. Remove the bolt that is underneath the cap. Now lift the whole basket out. If your small items get too far (ie, the pump), remove the back panel. On the left hand side you will see a small black hose towards the botom. this connects to the pump. Forign objects can ldge in here keeping it from draining also. If you disconnect the hoses, have something handy for all of the water to go into (large wet vac is usually the best). Drop the 3 #20 torx screws and the pump will come down and you can remove the obstructions.
Posted on Jun 19, 2008
My Kenmore front load washer is making a load banging noise had to shut off.
I think you need washing machine tech to fix probably broken bearing on inside
Feb 02, 2015 | Kenmore Washing Machines
Kenmore elite model 11027052602 clothes wet after spinning cycle why
You might have a restriction in the outlet hose. Worse, you might have a bad pump.
It is easy to check for the constriction. Pour water into the tub, set the timer for the spin cycle and watch how strong/fast the water leaves the hose. Check for water beneath the tub.
Oct 07, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
What cu. ft washer in a model 110-82870120 top load kenmore washer.
you can find out by measuring the depth of the tub in inches. Measure the diameter of the tub at the opening where you put the clothes in. Multiply those 2 numbers. Then divide the figure by 144 which is a cubic foot in inches. That will Give you the cubic feet.
Example Depth of 23 inches and diameter of 21 inches. 23X21= 483/144 = 3.35 cu. ft.
Jan 16, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Washer Mod 110 27062601 Ser CT 3770465 The load will not stay level. I checked the suspension rods and compared spring strength to a new assembly. They feel the same. The tub is suspended ok...
I would still replace the suspension rods and bushings. Not much else it could be if machine is level and clothes are distributed evenly. I also have seen the cabinet weld separate at bottom, so be sure cabinet is secure.
Nov 04, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
I get brown streak type stains on my clothes regularly. They are about 1 to 3 inches long and orange-brown in color. They are very difficult to remove. I have a 5 year old Kenmore Elite top loading...
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite spraying fabric softener all over clothes and tub
hello mam
is this softner provided by the kenmore dealer if not please getit from them because they know whish softner should be used and for the spots use descaling powder and run the machine without loading clothes.
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
Worn out front rim of plastic tub surrounding stainless basket
well not sure about yours but some front load washers have a five year warranty on the tub but you have to pay the labor which is between 100-150dollars
Dec 29, 2008 | Kenmore Elite 45986 Front Load Washer
Agitator in kenmore elite oasis
Use the bulky bedding cycle for oversize loads.
Oct 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis TL washer, stubborn Sd code
Found the problem. After removing the back panel, found some garments in the bottom of the surrounding clear plastic tub. These must have been periodically blocking the outflow area and triggering the Sd error code. Fixed it by opening the top components of the washer so I could see down into the surrounding tub from above. Fished out the garments with clothes hangar. Put everything back together and have done six loads with zero problems.
Mar 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
