Question about Balboa Instruments Garden
I have a Great Lakes Spa, model Huron Elite. The top panel readout went out. I have checked the fuses and the power to it. I have continuity thru the wire to the top panel but am not sure if the readout quit working. I am not sure what wire brings power to the top panel and which ones take the signal back. Thanks Doug
2 Suggested Answers
shaddow4115
  • 105 Answers
SOURCE: When I put power to my unit. A Sn code appears.
If the SnS or Sn Message is Alternating with the Water Temperature on the Display, it is a Possible Sensors Out of Sync Message.
If the SnS or Sn Message is Blinking or Flashing OFF and ON without showing Water Temperature, it is a Verified Sensors Out of Sync Message.
http://service.balboa-instruments.com/ErrorCode/ for code info
Posted on Dec 11, 2009
My Great Lakes sunlighter tub will not heat - need a part number to order
check temp sensor if calling for heat check heater element
Nov 12, 2015 | Pool & Spa
Great lakes spa model 733136
check with google they have answers for that and where to get parts
Jul 14, 2014 | Pool & Spa
The power went out in town, the power came back on, and the power is on to the hot tub, but we got an F2 code, and it isn't going on to cycle and the temp is at 54 now. What is the F2 code. We have a great...
I need to know what kind of control pack your tub has. If you can open the side panel and tell me what brand the pack is I can tell you what the error code is for.
Nov 03, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
FL code with Great Lakes spa ...Pumps won't run and tub is cold... light won't even come on.
FL code is because no flow from pumps check to see if recirculation pump fuse is ok
Aug 02, 2013 | Jandy Laars Lite2 Pool & Spa Heater -...
Drained my 2000 Great Lakes Spa now OH is displayed when I turn up the heat it kicks out the breaker..
OH is overheat due to insufficient water flow through the heater.
Common Causes:
  • Gate valves not opened/partially closed.
  • Air trapped in suction lines or pump
  • Blocked suction fitting
  • Dirty filter
  • Restricted water discharge lines
Try remove filter cartridge and run spa.
Check pressure switch for continuity.
Unplug & plug hi limit sensor.
Oct 14, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
KENMORE ELITE DISHWATER panel went blank but there
Check the continuity of the thermal fuse. It's clipped onto the electronic control inside the console.
Let me know if you need more help.
Mar 12, 2009 | Kenmore Dishwashers
Open Questions:
Master spa legacy hot tub pumps stopped working after refilling it? my legacy inspire hot tub was fine before i drained it, then after refilling it pump 1 sounded like it was trying to work and never turned on, pump 2 was working, so i reset the power and let it go through prime mode and still pump 1 was still not working but make the same noise and pump 2 still worked, i then left it on overnight and in the morning pump 1 and 2 stopped working completely, made no moter noise at all, so i reset the power and still nothing, the balboa vs series controller box makes a click sound but wont let pumps work at all, now i get 5 different codes dr, sns, hfl, dry and ice, so we bleed all the unions to remove any airlock, then reset power and still the same click sound, then we emty the tub and started over again and refilled it with hot water and cracked all the unions and its still the same click, so we found an article about reseting the memory on the balboa controller and turned off power used the j46 jumper turned power on then off again then took off jumper then powered on again the the lcd panel said a bunch of reset numbers and worked but still the pumps dont work? i think the balboa controller is not letting the pumps to even try priming or to even try to work it just clicks in the balboa? is there a reset for the sensors memory?? ive replaced the heater and sensors last year so its not broken i just dont understand pump 2 was working then stopped and both completly stopped working overnight?? can someone help!!!!!
Dec 10, 2012 | Balboa Instruments Duplex Digital Panel 2...
Garden Logo
60 people viewed this question
Top Balboa Instruments Garden Experts
Craig Butler
Craig Butler
Delage guy
Delage guy
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
