Question about Garden
I installed new bar and chain .cleaned every thing .assembled saw filled up chain oil thank. started sarted saw ,chain still not oiling.
    Genius:
  • 1,015 Answers
Without knowing what saw you have it is hard to exact directions.On most saws their is an adjusting screw on the bottom side of saw by oil tank and chain that adjusted the flow rate of oil. If you can locate that try rurning it one turn clockwise and run saw for a short period and see if you are getting any more oil.If youare sure you have the right screw I would continue adjusting . If it doesn''t seem to work I would remove screw and make sure there is no blockage and that oil is present. For proper operation you need to keep a light film of oil on it. If you aren't getting enough oil you will cause chains to overheat,possibly ruining chain and bar. Hope this help you. Thanks
Posted on Nov 14, 2010
Makati DCS 4610 chain saw is not getting oil through to te chain but the tank is full
How old is the saw? The first and easiest thing to do will be to drain the oil tank and make sure that filter isn't plugged. It's probably wise to fill the tank half way with fuel mix while it's empty and give it a few good swishes to clean it out real good. Next make sure that oil holes on your bar aren't clogged with gunk. After that take off the clutch cover, and remove the bar and chain. Start the saw and see if your getting any oil to the discharge. If you have oil there, make sure that the oil hole on the bar lines up with the oil discharge on the saw. If you're not getting oil at the discharge, your oil pump is likely faulty.
Mar 17, 2017 | Garden
Wild thing saw brand new used once, over heating, not wanting to cut, why?
If there is no oil getting to the chain, you will have metal to metal contact between the chain and the bar with no oil film, the chain will look dry and be covered in baked on resin from the heat, make sure you have adiquate chain oil in the oil chamber, this chamber is seperate to the fuel chamber, it should be filled with a non fling chain oil.
Aug 28, 2011 | Poulan P4018WT Wild Thing 18Inch 40cc...
After adjusting. Chain and running saw. FOR A COUPLE OF MINUTES. THE CHAIN. GETS REAL TIGHT STALLING THE SAW
sounds like your chain oil-er is NOT working, pull bar and take a stiff feeler gage and go around the whole bar cleaning the groove out and then make sure the oil hole in bar is clean also because if hole going to bar groove is plugged you won't get oil to lube chain. fill with oil and start and run on piece of cardboard or similar to see if it is throwing oil off chain, if so you are good, if not you are looking at cleaning/and or replacing oil pump Good Luck
May 16, 2011 | Homelite Garden
Hi i have a Husqvarna 445 18" 45.7cc the automatic
Verify you have oil in the oil fill tank. Try cleaning inside the drive sprocket cover. Release the chain tension and carefully dislodge the bar and chain assembly. Clean sawdust and debris from behind and inside the housing and behind the bar. Use a wisker wire to clean the through ports and channels on bar( these ports are the path that the oil travels to the drag groove that the drive links on the chain uses to pull the oil to the tip of the bar).
Please refer to this link below for your saw maintenance-
http://www.chainsawsdirect.com/manuals/HUSQ_445_MAN2.pdf
If this does not correct the problem contact Husqvarna customer service or a local service repair.
May 13, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
The chain oil is not feeding to the chain/bar
Release the chain brake and remove the bar and chain. Clean the engine area where the bar fits up to, and start the engine--oil should ooze out of the side port there. If nothing, then the oil pump, oil line, or oil filter in the tank may have failed. If it oozes ok, then clean the drive end of the bar--especially the two small passages that run from the large holes out to the chain groove on each edge of the bar. Re-assemble everything, then run the saw bar-tip near some cardboard for several moments--it should throw off a thin line of oil. There should be an oil volume adjustment screw head under the case near the chain return area--turn CCW to increase flow. Hope this helps!
Dec 22, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My chain keeps freezing up on me and its brand new. how do I fix tha t on my husqvana 16 inch
Turn the chain brake off, then remove the bar and chain. Clean the side of the engine where the bar fits to, start the engine and observe whether the small oil port on the engine oozes out oil. If nothing and the oil tank is filled, put the saw back together and take it back to the seller for warranty repair of the oil pumping system or a fresh saw in exchange. Hope this helps!
Dec 21, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My saw simply will not pump chain oil. Iv'e run it with the bar and chain off and the pump works.Put it back together and nothing. Before reinstalling the bar I blew the saw clean. I had a Sears Poulin a...
Check that the bar oil ports are clean; there should be a small hole or slot on each side of the bar and these can become pluged with sawdust. Also clean the groove in the bar with a small screwdriver or bar cleaning tool every 8 hrs of operation.
If this does not fix the problem check the oil sump screen in the oil tank(usually on the end of a rubber hose); if no screen in tank: remove oil pump and clean(screen is sometimes in oil pump assembly).
Oct 06, 2010 | Poulan Pro Chain Saw 46cc 20"
My remington 16 inch electric chain saw is not oiling, how do i fix it?
Start by making sure it's unplugged. Then remove chain, and bar, and clean oil slot in the bar and all of the housing in the area the oil comes out onto the bar. I use carb cleaner (safer than gas) and then empty and clean the oil reserve. Refill with straight 30 weight. Never use car oil like a 10w30 or 5W40! Then prime (pump) and start the saw without chain or bar. You should see some oil squirt out. If not, soak a clean empty oil reserve overnight in carb cleaner and try again.Once the oil path is clean, you should be back in business. If not - see your authorized service center.....LOL
Jun 17, 2010 | Remington 16" Electric Chain Saw Assembled...
Makita DCS51018 Chain Saw Oiler
OK found a complete oil pump for this saw, part number is 181245250 and if you would like to download a copy of the breakdown go to Makitatools.com and in the bottom go to Makita Canada and you can find it there. I don't know why they don't have it in the US version but that is where I got it from Good Luck and let me know if I can be of any more help
Feb 22, 2009 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Bar oiling problem
Just a thought: Is it cold where you are? At this saw mill where it is my job to keep chain saws running, learned years ago that you cannot use "bar oil" in winter. Need thinner oil, like motor oil. ....preferably a "non-detergent" motor oil, plain 30-weight is OK, HD30W will work, but the HD part causes the chain to stretch more so than standard bar oil. The bar oil literally is so thick in cold that it stripped the worm gear out of a Poulan Pro oil pump (plastic gear, anyways, wasn't much to begin with.) But thought you may want to try thinner oil, if it is cold where you are. Oh yea we also have 2-Husqvarna 359's with 20-inch bar, and use thinner oil in winter. Our Husqvarnas have an oil adjuster located on bottom, on clutch side. Straight slot screw adjustment.
Nov 18, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
180 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
