I have an Advent 7085, it is around 3 years old. I have had numerous problems with it but eventually got it fixed.For quite a while now it has been playing up. When i load up my laptop (using the power cable) it loads up, i enter my password and as the desktop comes on the screen goes dark, as though a light has gone out, the laptop does not switch itself off however, as i can still faintly see the desktop if a light is shined on to it. If i load up my laptop without the power cable it works, but the battery life is very poor so i am unable to use it for the amount of time needed. Any ideas what is wrong with it?
  • Anonymous Aug 31, 2008
    I have this exact same problem, I am wondering if this is the backlight rather than the whole screen, can I just get a new inverter or something?
    Thanks
SOURCE: Advent T2310 laptop screen blank
Have you tried it with an External monitor?
Posted on Mar 10, 2008
imp_squared
  • 56 Answers
SOURCE: My Amilo A1630 laptop is
To isolate the problem try this:
Plug your laptop to an external monitor using the monitor out port on the laptop. Hit the "function" key and the corresponding F key that has the LCD Screen/External Monitor icon. Usually around F6-F8 or so.
This will test if there is something wrong with the screen and if the laptop is booting up past the BIOS.
Please comment back with results.
Posted on Aug 15, 2008
ehsan_bba
  • 112 Answers
SOURCE: The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Posted on Jan 22, 2009
hk_danni
  • 67 Answers
SOURCE: Unknown power-on password on hp dc5750 desktop
If your using XP you need to run safe mode(press f8 while booting) then choose safe mode >2 box while show 1 with administrator and the 1 you mentioned>choose administrator>it will open your pc>go to control panel>users account>change or remove the user then restart...pls. rate
Posted on Jan 30, 2009
Geekman
  • 32281 Answers
SOURCE: Dell Inspiron laptop monitor is gone very faint
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 15, 2009
Advent problems
the cable between keyboard and computer is lose or fitted in place.
May 05, 2014 | Advent Netbook
Keyboard backlight
Dear Jaine,
I did not find any replacement keys for your keyboard, but I located in ebay some replacement keyboards for around US$ 20 that may be an option. Please, have a look at:
http://www.ebay.com/bhp/advent-keyboard
Hope it helps!
Best regards,
Miguel L. Martins
Nov 03, 2013 | Advent Computers & Internet
My bolt light flashes pink on my advent laptop
The rechargeable battery probably needs to be replaced, if the battery is 1 to 3 years old have it checked. Go to www.ebay.com Type: make and model of laptop, refine search to battery.
May 02, 2012 | Advent Computers & Internet
Advent 5401 left touchpad button broken
Had a similar problem a couple of months ago, The left button started playing up, not working with every mouse click, it gradualy got worse till it was nearly unusable.. I suspected that the microswitch under the silver button had some dirt in it. After taking a deep breath I removed the battery and the screws that hold the case lower and upper halves together and was able to seperate the case front by about 3/4 of an inch. Then using a contact cleaner Servisol Super 10 and supplied flexible straw I squirted cleaner into both mouse click buttons. After waiting for cleaner to evaporate and resecuring case halves and replacing battery I switched on .... The button works 100%..
Feb 02, 2010 | Advent Netbook
Advent 6415 Combo.Graphics stripey with what looks like 16 colour. Screen eventually clears up with stripey blotches on screen after 10 - 20 mins. It is almost 8 years old. Graphics chip old and dying?
internal graphics card is failing u can get this fixed at local laptop repairer cost vairies depending on type of graphics chip fitted and what labour charge they impliment max 2 hours id say tho
Oct 24, 2009 | Computers & Internet
I have the same problem since 1 year. getting worse every months.
its more than likely going to be the camshaft dephaser, this is quite a costly job as it requires replacing along with the cambelt and auxillary belt, its a common fault
Aug 10, 2009 | 2004 Renault 181
I bought an advent 7203 pc model number eaa-89 in january this year and whilst using it the other night the screen went black so i thought the battery was flat and put it on charge when i tried to switch...
dont buy advent total **** buy a 2nd hand dell better value less chance of breaking honestly i had two advents both **** one when i lifted the hard disc stopped! cheap **** now i have a shiny dell xps 1 year old warranty extend option if you want build quality night and day im also sitting with a busted 7093 yeah advent boards just burn out nasty cheap conning mothers**
Jun 21, 2008 | Computers & Internet
Advent HT2751A display no good until after 1-2 hour warmup - maybe
After 3 years, I finally decided to open up the TV and do some troubleshooting. Found out the problem, It was a blown capacitor Location C554 Capacitor value is 2200uF 16V - costs about a dollar to replace yourself and the TV works brand new.
Aug 16, 2007 | Recoton Advent Advent HT3251A TV
Horizontal lines when I first turn on my Pansonic 51" PT-51HW41 Projection TV
It's probably failing capacitors, does it squeal while this is happening?
Jan 14, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
