Question about Coleman Powermate Powermate 5000W Generator
I have a coleman powermate 6250 genpower 305 10 hp ohv. I was having trouble with it cutting out while it was running so I changed the oil, air filter, spark plug, cleaned out the tank, put a new gas line with an inline filter & fresh gas. It will not start. I took out the spark plug to test spark, there is none. I'm not sure what the proper gap is for the plug and the coil. And I'm not sure if thats the problem.
  • 1 more comment
  • Tim Garcia
    Tim Garcia Aug 29, 2012
    i have this same generator- never had this problem - cause for no-spark could very likely be a broken (internally) plug wire. try getting a new one, or at least try to check continuity on it. Then check the magnetic field spark generator. If it's loose it won't work.
  • mark j dale.com Nov 13, 2012
    unplug the oil cut out wire from the switch looking at the switch it is the one all the way to the right
  • Abbas Mahar
    Abbas Mahar Mar 29, 2014
    i have the same generator , can anyone tell me that from where can i get it air filter online ?? ill be thankful if u e-mail me the site on my id .... abbasmahar_acca@hotmail.com
Most likely the problem is the "low oil" sensor. Remove (white) sensor wire and check for your plug firing. If it fires, recheck oil level in sump and/or pull and clean sensor.
Posted on Oct 16, 2014
If you have a business card you can use it to set your coil works great actually . Same for your plug
Posted on Feb 01, 2013
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Oil to used for a briggs and stratton genpower 305 10hp ohv engine
Hi Jim, sae 30 mineral oil for all Briggs engines. Regards Phil.
Sep 24, 2011 | Coleman Powermate Powermate 5000W...
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman powermate 6250 no spark, switch on, has oil. changed spark plug.
check wiring most likely loose wiring, happens when your generator viabrates
Nov 11, 2009 | Coleman Powermate Premium Plus 6250W...
Powermate 6250 wont start
try checking the WKM setting...i dont know what its called in english....but we call it WKM ...on my gen. its a peice of metal (with OHV written on it)...if you don't know how to set it...send me an email at
sal_kh_sab@yahoo.com
Sep 05, 2009 | Coleman Powermate Premium Plus 6250W...
Oil type and capacity
Use 10/30 weight oil fill till : " if it has a "dipstick" fill to middle of hash marks" if not, There in the hole for the oil filler cap their is a knotch cut out of the theads for that cap. fill to just below the top of that knotch . drain plug on bottom of crankcase
Sep 01, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
1,842 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
