Question about Sony Computers & Internet
Replaced "C" drive, and now
  • Sony Master
  • 27,725 Answers
It might be a power problem make sure the leads that are attached to your cd/dvd drive have secure connections and are not bad/faulty including electrical extensions or replace them they might be bad/faulty or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Nov 14, 2010
Cd drive is scratching discs
I recommend you replace this CD drive rather than trying to fix it.
Feb 25, 2013 | Acer Aspire Computers & Internet
When I try to play a movie with my samsung se so84d drive, my mac says "a valid dvd drive was not found." How can I play the movie????
Good day..!!Maybe your using cd disk that why ur external wont accept it.,or maybe there was a error on your cd.thanks
Aug 17, 2011 | Samsung External Slim DVD-W USB Compatible...
I have a hp pavilion 6370Z. i lost my windows 98 CD, and my hard drive was formatted. When i try to boot the computer it just says "invalid system disc replace the disc, and then press any key."...
You can dump the windows98 setup to your usb flash drive using wintoflash software and boot your system using usb flash drive. Proceed with the installation steps for win98.
Regards,
Sreejith
Aug 12, 2011 | Microsoft Windows 98 for PC
My burner will read, but it will not burn. it worked fine until I had to have a new hard drive put in my PC, and now, it responds to all comands, exept it will not burn. I get a message "the cd in...
You need to reinstall the drivers for this device if you dont have the disc you can download them from the manufacturers websight
Please dont forget to rate my answers
Jun 17, 2011 | EZQuest Computers & Internet
Installing DVD-RW LiteOn iHAs124-04 b AL0L with Windows 7 64bit but getting "Device driver software was not successfully installed." General Device Properties show:" Windows cannot load...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 26, 2011 | Lite On LiteOn IHAS124-04 Black 24X SATA...
Hi, I have Windows 7 on my MSi L1350 laptop. Whenever I try to play a DVD on my RockSoul DVD Multi Recorder (RW) on Windows Media Player, I get the following error message: "Windows Media Player...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or
http://majorgeeks.com/Realtek_High_Definition_Audio_for_VistaWin_7_d5513.html
hope this helps
Apr 04, 2011 | Toshiba ROCKSOUL ED100 USB slim external...
I CANNOT LOAD WIN7 I cannot get my system to boot from a CD disk (Win 7 Ultimate) I set the BIOS to boot from a CD device - the priority is set for CD first. All other values are default. In...
try to reset bios if does't work try using a usb dvd drive (external dvd drive) remember you do not will be able to read a dvd CD(WINDOWS 7 CD) using a cd burner.
you will need a dvd drive.
Feb 07, 2011 | ASUS Computers & Internet
I downloaded " cd burner
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 25, 2010 | Toshiba XM-6702B 48x CD-ROM Drive
The master cd drive is broken. I need to find a repair shop nearest to Miami, Fl 33168 to get it repaired.
If you have google, switch to Maps and enter "Miami, Fl 33168 electronic repair" (without quotes)
Nov 03, 2009 | Telex SpinWise Seven Drive (301735000)...
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
