Question about Bose Cinemate Digital Home Theater System Speaker
No sound on certain inputs
I am not getting sound through the component 1 input which has been selected for my high definition cable box. If I chose antenna input which shows the cable channels only in regular not high definition, then the sound works. Please help
I did not have the audio cords going into the back of the cable box properly.
Posted on Jun 19, 2008
I hooked up my soundbar using the HDMI out (TV) port from bar to HDMI in port on my Philips TV power is on bar however I can't get any sound out of bar. But just audio cables worked what to do?
OK, If its the Samsung Sound Bar, this item should have 2 HDMI input, 1 3.5mm audio jack input and a digital audio input (fiber optic). Since there are various input, the remote control should have a source button, or it will probably read O/A Input, this is to change thru the inputs from the sound bar. If you connected your TV HDMI output to HDMI 1 from the Sound Bar, then press the source button to reach HDMI 1, maybe it will be display with a different name, like sound 1, or DIGI.1 Give it a shot and let me know in the comment section. Good luck.
Dec 19, 2015 | Samsung HW-H450 2.1 Channel 290 Watt...
How can I set up with my lcd Sony tv
If your home theater receiver has a digital optical input, run a digital optical cable from digital optical OUTPUT on TV to digital optical INPUT on receiver. If receiver is older and only has analog inputs, you can get an 1/8 inch to RCA cable(red/white), and plug 1/8 inch side to an output on back of TV and plug RCA side to aux input(or CD or cassette input) on back of receiver. DO NOT PLUG INTO PHONO INPUT! Either one of those cables can be found at Walmart, radio shack, or best buy, etc. Digital Optical cable is definitely the best choice, but I just used the 1/8 to RCA setup to hook up a Sony led to my brother's early 90's Pioneer receiver(not the ideal setup, but will work). Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
Apart from the "line input"
input and output are for low level ( as with RCA cable connectors) ,, the speaker connections are for high input, (red and black connections. ) you can run the mains to the (rca) from your receiver to run the sub woofers, and from that use the speaker wire connections, to go to the left right speakers, (out only not in) this is done if you want to run the subs and the Rt/lt/ speakers , eliminating the speaker connections coming from the receiver. which you could use for 2 additional speakers if you want
Apr 23, 2011 | Wharfedale SW150 Subwoofer
My woofer is humming i replaced the ic2030 but problem is not sol pl give mi solution
Hope u fixed this by now but I had a hum also and tracked it down to the cable box as found a site which told me to unplug the coax cable from the setup box and see if the hum stopped and it did. However after trying their suggestions and was gonna get a transformer went to my receiver I had used a dig coax for sound from the mot box to my receiver, pulled that cable and the hum stopped, replaced it with a toslink cause I had one laying around and have the receiver inputs for it end of hum for good so one more thing to try if your connected that way but it was definitely cable related.
Nov 11, 2010 | Sunfire True Sub MK II Subwoofer
How can i directly connect a LG H30 TV, or a PS3 or a Wii to a Regent HT391 sound system? Is it possible to? So far the only 'surround sound' I can achieve is by connecting my tv thru the cable box...
According to the various vendors that carry this model, the unit has multiple inputs to accommodate gaming systems, dvd, tv, etc.
Look on the back of your system and see if there are inputs labeled as Game, DVD, TV, etc. You should be able to connect each component, and use the remote to switch between the multiple sources.
Good luck.
Feb 03, 2010 | Durabrand HT-3915 System
I have a sorround sound lg and im trying to watch a movie and there is no image. my tv says that i have no signal but the sound comess out. i dont know what to do.
Sound comes out because your player is working and speakers are connected to the DVD/VCD/BlueRay/ Home theater (what ever your player is). However, you may not have connected the video cable to the TV. (I think this is the case because, usually when you connect the video cable, LG pops up a message; something like: New input connected, Do you want to enjoy it with a Yes/ No option, which you can select using the remote. If you have connected the video cable you need to select the correct input in the TV. Click the input button on your remote. That will show you the various inputs, use the right/left arrow to scroll through the active inputs. If you are connecting an HDMI cable to connect the player to TV, select it. If you use A/V cable select it. If you are using a S Video cable, select that. If a component cable is used select that as your input. Once this is done correctly you will have signal. Hope this helps. Anil
Jan 21, 2010 | Audiovox Audio Players & Recorders
Same same here!
Any readily available Stereo RCA to Mini cable. These cables are a in stock item at any electronics store.
Plug Mini side of cable into ipod headphone jack and the RCA side of the cable into any available input on the Bose system, match color for color, Red to right and White to left. Select that input on your Bose system and use the ipod as normal. This is the cost effective solution.
The better choice is to use a after market ipod dock system such as DLO http://www.dlo.com/products/homedoc_dx_Prod.tpl there are several levels to chose from all the way to HD outputs. These units can put your ipod display on your TV screen.
Jun 07, 2009 | Bose LIFESTYLE 28 Series III System
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Subwoofer probelm
I suspect you have a bad cable, a poor ground or a bad
power supply inside the speaker amplifier. The amplifier
(inside the sub-woofer) could also be defective.
1) Bad cable or connector:
If the (braided shield/outer tube) of the coaxial input cable is
not grounded, the cable will pickup line frequency "hum"
from surrounding power lines, house wires, lights and
appliances.
This hum is then amplified by the speaker's amplifier
causing the constant bass sound you speak of.
Because the hum frequency fundamental is 60 Hertz in
North America, 50 Hertz in Europe, you hear it coming
mostly out of the sub-woofer, because the midrange and
high speaker circuits filter it out.
Check the input connectors, cable at both ends, wiggle
the jacks at a low volume setting to see if it changes.
Make sure that you are indeed using a properly shielded
coaxial cable.
A coaxial cable consists of a thin inner conductor, surrounded
by a flexible tube made up of a braided metal shield, which
must be grounded. This prevents hum from being picked up
by the sensitive amplifier inputs.
2) If the power supply within the sub-woofer's internal amplifier
is defective, the the power supply hum will also get coupled
into the amplifier and speaker with same results as above.
Power supply hum is typically twice the line frequency,
i.e. 120 Hertz, but not always, depending on what
component failed: Rectifier diode, filter capacitor, or
the voltage regulator.
3) Ground loops:
When you run very long cables between the source and
destination of an audio signal, multiple ground paths (must)
exist between the two points in space, creating complete
loop circuits.
Power line hum from the environment can (will) induce
heavy AC currents around these loops, creating a voltage
gradient across these cables, and in-between the end
devices.
Once again, this AC hum is coupled into the amplifier inputs.
Ground loops become a problem with cables over 10
feet long, and an astronomical problem for stage audio
engineers. To avoid ground loops, they must break
the circuit's continuity by using isolation transformers,
optical isolators, and/or differential input amplifiers.
So how long are your cables?
Most house stereo components are only designed to
handle 6 to 10 feet of cabling max.
30 feet is already asking for major trouble.
4) Feed back oscillation: This occurs when the output of
an amplifier is fed back to the inputs with a round trip
gain greater or equal to unity. The tiniest little electrical
disturbance is then amplified and re-amplified, over and
over again, usually at one preferred frequency, causing
the typical (ear-splitting) microphone squeal or howl.
In your situation feedback and/ loss of original signal
could be the result of mis-wiring the input cables.
Note that this is NOT as silly nor as unlikely as it sounds,
because many computer audio cards and even some
home stereo systems have re-configurable inputs and
outputs.
SOFTWARE configuration decides which jack at the
back does what !!!!
On my computer, for example, the Realtek audio driver
tries to automatically figure out what cable is connected
to each jack (usually it gets it wrong)
Using the Realtek control panel applet, I can then
manually re-configure the gray jack as input,
the green jack as bass, pink jack as center.... etc.
If this situation also applies to your system, please check
the software configuration. Connecting an output cable to
an input jack will certainly cause a lot of HUM and not
much music.
5) Finally, don't rule out internal sub-woofer failure. Unlike
the passive stereo/hi-fi speakers of days gone by, modern
multi-channel theater systems with front, center, rear and
sub-woofer speakers are internally amplified, with active
frequency cross-over filters and special effect/ surround
sound capabilities.
Usually, the large sub-woofer contains most of the
electronics, amplifiers and filters.
It feeds the other speakers, and it is controlled by
an external volume control module which can be separate
or built into one of the tweeters.
These sub-woofer electronics are prone to poor design,
overheating and early failure. (Even fresh out of the box
like yours)
If you cannot get it working, take it back to the store,
and make the NICE salesmen **** with it.
Good luck
Please rate my answers
Martin.
Jul 20, 2008 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Am setting up a bose GSX 3-2-1 home theater
simplist solution, if the TV has an audio output just run that to the Bose system.
what type of TV are you connecting to?
Is the cable box an HD or digital box?
Jun 23, 2008 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Digital Home Theater System Speaker Logo
81 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
