Question about Whirlpool Washing Machines
I have a TYPE 199-02 090WT/CR Whirlpool front-loading washer. Went washing in the green print out F35 come on and in the manual I have found other F's but not F35. What does F35 stand for.
  • 1028 Answers
SOURCE: Whirlpool Duet Washer Model No. GHW9100LW, Serial No. CSM2608446, Type No. 199-AWM075/GY
not unless you make it yourself ..replacement handle is just like the 1 that broke
Posted on Aug 20, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 1891 Answers
SOURCE: message sud and f35 causing washer to stop washing
don't panic/ suds is just what is you have / look in the window. do you see suds/ ok if door is unlocked poor into tub two lids of fabric softner . mixed with a quart of water . wait over night . and everything will be ok . f35 ?? it will probably go away also . if it does not get back with me. . no to stop this from happing again cut down the amount of dergt. or change to the proper type like H E .. hope this helps / ps remove the front panel 3 screws and on the left side remove the drain clean out .. this will help a great deal ..mm feed back please ..mm
Posted on Dec 17, 2009
SOURCE: Sud and F35 error in my kenmore elite h5 steam
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Posted on Aug 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: model: wfw9500tw01 f35 error
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
I have an "F35" message
The only Whirlpool washer with an F35 code that I know of is the Duet. For that washer, the code indicates a failure of the analog pressure sensor. Check if the pressure hose is connected properly. Check that the hose is not blocked. Finally check for a blockage in the airtrap. If the hose and airtrap are fine, then the sensor or the related circuitry is bad.
I hope this helps.
Jul 24, 2011 | Whirlpool Washing Machines
My whirlpool front load washer, only a year and a half in use, stops after filling and flashes the message F35. The trouble shooting manual does not give any explanation for F35. Any suggestions?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
Jun 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Washing clothes all day have an F35 flashing
F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Check these problems.
Plesae leave a solved rating before you leave the site
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 Message on Brand New Washer
suds is determined using the level sw located on top right rear side. remove top cover to see. most letter codes do convert to a f code. most common reason for suds error is use of standard detergent or too much detergent. running a empty load of fabric softener can clean the system. or rinse/spin with nothing. other common problem is this is a whirlpool product.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
