Question about Vizio L32 32 in. LCD HDTV
A loud crackling, static noise when the 37" vizio is turned on. has good picture, but no sound,just that crackling and static noise.
  • 3 more comments
  • laswientek Nov 14, 2010
    where is the jack for headphones located on a37" vizio?
    VX37L
  • laswientek Nov 15, 2010
    tried the headphones,got no sound.
    what is the SSB and where is it located?
  • laswientek Nov 18, 2010
    Yes, I Would Like To Do It Myself.
  • 4,889 Answers
Ok. That sounds like malfunctioning speakers. To confirm try connecting headphones or external speakers into the headphones jack and see if you can get sound if yes, then its definitely the speakers. Try it and let me know
Posted on Nov 14, 2010
  • 4 more comments
  • eagle338
    eagle338 Nov 14, 2010
    Can I have the model number of the set please?
  • eagle338
    eagle338 Nov 15, 2010
    There is a port called audio behind the tv, next to the RGB PC port. That is the headphones jack.
  • eagle338
    Confirmed case of faulty tuner circuits. which means you will have to replace the SSB to fix it. Will cost you around 100-125$.
  • eagle338
    Its the main signal board with the tuner circuits. The problem you have described indicates that the digital audio tuner circuit has failed . You should take off the back cover of the set to be able to see it. It is located at the center of the set, usually covered by a metal plate.
  • eagle338
    eagle338 Nov 16, 2010
    Would you like to do it yourself?
  • eagle338
    eagle338 Nov 18, 2010
    Ok. Take off the back cover of the set, and remove the metal plate at the center, covering the main board. Get me the part number thats on the board(usually on a label or under it) so that I can tell you where you can get it from.
When I try to dial out the phone has loud crackling noise.
You have a line problem call your Telcom provider.
Feb 06, 2016 | Lands Phones
Vizio 37" went dead while watching it.
hi sounds like the fuse inside could have blown or the psu has blown look for tech in your area hope it helps
regards
shaun
Jan 23, 2014 | Vizio VO370M 37 Class LCD HDTV
Static crackling sounds
Replace the speakers or let it be repaired by some one.their may be rust near the speaker coils.just giv it a try.
Nov 20, 2013 | Yamaha Music
VIZIO 37" LCD has sound but no picture
Good day!
that problem is happen when your inverter board is defective please replaced it..
This is the picture of inverter board.
thank you and good luck
Jun 10, 2011 | Vizio VU37L 37 in. LCD TV
The tv takes 25 minutes to turn on. it shows no signal, makes loud crackling noises and then turns on
i would look at the power supply as it sounds like the caps in it are getting weak
Oct 14, 2009 | LG Z37LC6D 37 in. HDTV LCD TV
WHEN I TURN ON THE TV ITS MAKES A VERY LOUD CRACKLING NOISE.
If you have lost your freeview channels & your picture has been breaking up (pixelating / freezing) etc as well as crackle on the audio, then I would suspect you check your antenna, it could be your incoming signal is weak which would give you these problems.
Aug 13, 2009 | LG 37LH55 37 in. LCD TV
Sound will go to loud static noise, but picture is fine
it sounds like you need someone to look at it for you so fix it under warrenty if you can. Maybe buy a set top box and source your sound from there. also buy 5.1 surround (if you like as its a excuse to upgrade) for your speakers.
Jun 01, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Sound but no picture on 32in visio plasma
this sounds like you need a professional, can you get it fixed under warrenty
May 31, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Vizio L32 32 in. LCD HDTV Logo
738 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
