Question about Whirlpool Dryers
My dryer is running and not shutting off automatically
  • 161 Answers
If this happens in the auto dry cycle, try using the timed section. If this works I need more information to help you further. If this doesn't work the timer motor needs to be replaced. This is not always practical as they are usually not sold seperately. If this is the case I would go to a used appliance store and see if they have a used timer you can take the motor off of. A whole new timer can run up to $100 or more. It might not be worth fixing.
Posted on Jun 29, 2008
If its a newer dryer, they have moisture sensors that determine if it should shut down early or stay on longer if needed. Let it run the extra time and see what happens. If it keeps doing it, then the sensor is defective.
Feb 21, 2016 | LG Dryers
Maytag dryer stops after few minutes
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Feb 21, 2015 | Maytag Dryers
I have a whirlpool electric dryer and the automatic sensor mode is not working. In the automatic sensor mode it drys the clothes but will run forever. The timed mode works by drying the clothes and...
I wonder if maybe your wire is attached to the sensors? If it vibrated off the connection that could be the problem. Here is a video I made which shows how to connect the wire:
Oct 16, 2013 | Dryers
Maytag Dryer Model med5630TQ0, run it for 30 minutes works great run a second time for 30 minutes it automatically shuts-off and than I have to wait until it cools off to use heat option
Try cleaning out the vent in the wall and also check the vent hose to ensure its not kinked. If good air flow coming out of vent on back of dryer while running you could have a bad motor. Have to be disassembled to check it professionally.
Sep 25, 2017 | Dryers
Dryer runs for a short period of time and then shuts down without any error code but with a "clean filter" indication. This happens when running any automatic cycle except "air dry". ...
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
Jul 04, 2011 | GE Profile DPSB620ECWW Electric Dryer
Dryer ran for hours and did not stop automatically, now runs but wont heat?
Good day,
If set to automatic and there is no heat it will run continually run without shutting off. You'll need to trouble shoot the heating problem.
A lot of the problems are due to limit fuses and limit thermostats located in the back. Beyond that you'll need to supply the model and whether its gas or electric.
May 14, 2010 | Kenmore 500 6952 Dryer
It will not automatically turn off when running, the knob does not turn while running.
Miss Stephanie you must replace the timer.
If you have a timed dry setting. Run timed dry. If it does not shut off timer is bad.
If it does shut off you have a sensor problem.
Apr 14, 2009 | Kenmore Dryers
Newer Kenmore dryer automatic sensor not working.
I dont understand your problem?
Jan 19, 2009 | Dryers
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Kenmore HE4 Dryer
rmcfarland I am going to make an assumption. You are using the Automatic cycle. If so then this is wet load detection. Open the dryer door and at the bottom on the front you will see 2 metal bars. This is you moisture sensor. Clean that sensor with a mult purpose cleaner. If detergent and fabric softner sheets build up a coating on this sensor, the control will think you put in a dry load and shut down the dryer. Hope this helps.
Jan 25, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
74 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
