Question about Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880
I believe that the motor starter circuit on my Ingersoll Rand 2475 5 hp 80 gallon compressor is incorrect. It's a 30 amp single phase compressor
    Novelist:
  • 214 Answers
You should not be pulling over 30 amps. If you are you may have low voltage, incorrect wire size or to long of a run for wire size. I would use a hand held meter and check the amps at full load.
Posted on Nov 14, 2010
  • reyes_andres Nov 14, 2010
    I should rephrase my question, the compressor does not turn on at all, if I push in the magnetic starter coil on the motor circuit it stays energized but the motor does not start.. The voltage across the motor is 0 VAC. I am suspecting the the wiring on the motor starter circuit is incorrect.
  • elunsford Nov 14, 2010
    Is this a new unit or one that has ran. Do you have 230 volts to the top of the magnetic starter. Check each of the two legs of incoming power. You should also have 230 volts to the starter coil. Insufficient voltage to the coil say 120 volts could cause the condition you describe. If all voltages check out shut off all power and remove the magnetic starter front. There will be two small screws holding it in place. Inspect the contacts in the starter. Make sure they are there , in the correct place, and not burnt badly. If no problem is found install the magnetic starter front and power the unit up. With a volt meter check the left top incoming power lead at the top of the starter to make sure you have power. Push the starter in as you described and check the voltage at the bottom of the starter and then the overload where the motor lead connects. If no voltage is present at the bottom of the starter you have a starter contact problem. If voltage is present at the bottom of the starter push the overload reset and check for voltage at the bottom of the over load where the motor lead connects. If you have voltage at the bottom of the starter and none at the bottom of the overload after the reset you have a bad overload. FYI one leg of power to the starter coil comes from the overload.
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
I have an ingersol rand 2420n5 t30 and i want to convert it from single phase to 3 phase any help thanks
Hi robles212
To convert your T-30 to single phase you will have to do one of two things.
1. Change the motor to a single phase motor
2. Buy and install a "Phase Converter" to convert 3 phase to single phase
Please rate me
Bud
Oct 08, 2012 | Ingersoll Rand Type 30 Reciprocating Air...
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Jun 04, 2012 | Ingersoll Rand - Rand Type - 30...
How to wire a t30 1 phase 230 volt in control box, they used white black green, are the white and black both line voltage for 230 volts? its a model 2475
yes white and black are both line voltage in.each wire will have 110 to 120 volts. Attach one wire to top of starter contactor left side the other to top of starter contactor right side. Attach green wire to ground.
Jun 01, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
I have a ingersoll rand 30, srats for 20seconds then trips breaker,,,runs great when running
Sounds like the unit is pulling to many amps during start up. Possibilities are: breaker under sized, wire under sized, to long of a run of wire from breaker for wire size,Tank check valve bad. I would check the amps during start up and while running and compare to motor name plate information. Remember at start up the motor may pull 1.5 to 2 times the rated amps on the name plate. Also if this unit has a magnetic starter wire connections may be loose or overloads to small.
Dec 07, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
IR 2475E Wont start up 220 everywhere No LOP switch
did you check for a motor reset button on the motor??
Feb 20, 2010 | Ingersoll Rand - Rand Type - 30...
I have a ingersoll rand type-30,model#2475 7.5 hp,3 phase.need a wire diagram or how do you wire up the low oil and pressure switch? this is a used compressor with wiring still conected, has 3 leads to the...
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Dec 04, 2009 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880 Logo
482 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
