Question about Garden
Danarm petrol chainsaw 1-71-ss carb settings - Garden
4 Suggested Answers
SOURCE: 14" Ryobi petrol chainsaw will only run for 10 seconds
You are on the right track. Keep priming which indicates the fuel mixture is too lean to run. In other words the fuel line is partially clogged up. A drop of water on the gas tank would cause this problem. The fuel is fed on the suction basis. So clean up the fuel tank, (disassembly the carburator) reservoir, needle, float, offrice and fuel filter. A can of carburator cleaner (spray one) is a big help.
Posted on Jun 04, 2009
  • 302 Answers
SOURCE: Carb settings for my Chainsaw
most all of them are 1 1/2 turns out from bottmed out which must be done gently to avoid bending the needle tip
Posted on Aug 14, 2009
dontbother10
  • 2220 Answers
SOURCE: set carb homelite chainsaw mod ut 10939
No response to CR.
Posted on Mar 13, 2010
MC CULLOCH X SERIES 2500 CML PETROL POURING OUT OF CARB
diaphram may be backwards or placed incorrectly
Aug 11, 2014 | Garden
I have a gardentec 52cc chainsaw which wont start. I have a spark and fuel getting thro.
Hi you mentioned that you defo getting spark is that from spark plug against side of engine, try this put a very small amount 50/50 pet oil inside cylinder head through sparky entrance screw spark plug back in try it now if it pops abit no matter after 5 times you have a carb prob float faulty jets blocked, blocked feed line, Advise you need a bowl petrol no smoking wash carb in it blow clean jets put back only when all is clean check petrol tube sometimes they go hard and block up make sure petrol is getting to cylinder head, hopes this helps
Feb 17, 2014 | Garden
Holden barina carburettor problems
feed line blocked from petrol tank test to see if petrol is coming through , replace feed pipe also check carb float chamber needle could be bent thats why its not drawing petrol through hope this helps
Feb 07, 2014 | Garden
No fuel (2 stroke) getting into priming bulb of Ryobi petrol chainsaw 18"
Change the fuel filter in the tank, if this does not help there is dirt in the carb, remove the carb, under the pump diaphram is a filter screen, replce this.
Apr 07, 2011 | Ryobi Garden
Jonsered Parts Model 361 & Model E61 Where can I find?
The 361 was a badged engineered machine, it was manufactured by TML in Canada, they produced machines for many other manufacturers, Danarm, Frontier, to name a few, it is an old machine from the mid 1980s, there are no parts available from Jonsered, but try the web for these other makes, Husqvarna had a machine much the same from them the Husky 35, and the Husky 37, try the web for these models.
Good luck
Feb 08, 2011 | Garden
Well, I have been given a Danarm 13'' chainsaw and it is very reluctant to start. I know that it runs but feel sure it needs a tune. There are adjuster screw labeled high and low. Are these to do with the...
Yes. Initial settings should be (lightly turn in screws to seat them) Low (L) 1 turn out, High (H) 1-1/4 turn out. check some basics
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 23, 2009 | Garden
Jun 04, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Leaking petrol
Hi bob
Below the carb there are towards the cilinder:a gasket,a plastik suport and another gasket.Check the gaskets from there.Also the 2 bolts of the carb should to be tightened.
cheers savumihai71
Dec 13, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
356 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
