Question about Canon MultiPASS MP730 All-In-One InkJet Printer
There are vertical stripes when something is printed.
    Scholar:
  • 52 Answers
This would be an issues that is a result to drying. Are you using Canon inks?
All manufacturers of printers use a wipe cleaning.. So try to run a few cleaning run from the canon software. If the cleaning doesn't help then the print head could be plugged with ink.
http://www.ehow.com/how_2006950_clean-canon-cartridge.html instruction on how to clean.
Canon website:
http://gdlp01.c-wss.com/gds/9/0900002529/01/MultiPASS_MP730_700_Users_Guide_EN.pdf
Good luck with your task at hand! Thank you for Visiting FixYa.com
Posted on Nov 14, 2010
White vertical lines down printed documents...
hello
you have to check the fuser film, it may be not good
regerds and dont forget to rate mt answer
Feb 19, 2010 | Konica Minolta PagePro 1400W Laser Printer
White vertical stripe on color images when they're printed
You may have some dust on the imaging window (printer head). Remove the toner cartridges and clean it with some tissues.
Apr 28, 2009 | Konica Minolta magicolor 2430 DL Laser...
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Aug 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
Printing problem
  1. Open the Printers folder.
    • For Windows XP Select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    • For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  2. Right-click the printer icon to open Properties.
  3. Click the 'Maintenance' tab and click the 'Print Head Alignment' icon.
  4. The message below is displayed. After confirming the two points below, click 'Print Head Alignment'.
  5. The following message is displayed. Click 'OK'. Print head cleaning starts. The power lamp flashes during cleaning operation. Do not perform other operations. After cleaning has finished, the first head alignment pattern will be printed.
  6. The following message is displayed. After printing has finished, click 'Yes'.
  7. Refer to the printed sheet, and select the pattern with the fewest visible vertical stripes in column A.
    <1> Example of highly visible vertical stripes in the pattern.
    <2> Example of the fewest visible vertical stripes in the pattern.
  8. Enter the selected pattern's number in the Column A box.
  9. Similarly, enter the selected numbers in the boxes for column B to F.
  10. After all numbers have been entered, click 'OK'.
Apr 09, 2008 | Office Equipment & Supplies
Possible Print Head Issue
Select the Jet Substitution Mode.
  1. On the Control Panel, select Troubleshooting, and then press the OK button.
  2. Select Print Quality Problems, and then press the OK button.
  3. Select Eliminate Light Stripes, and then press the OK button.
  4. Select Jet Substitution Mode, and then press the OK button.
  5. Follow the Control Panel prompts to select the color and malfunctioning jet number indicated on the Light Stripes Test page.
Mar 25, 2008 | Xerox Phaser 8550DX Laser Printer
Epson C1100 - Vertical faint stripes on colour photos
see if this solution fixes the problem.
Also clean the print head using instructions in the manual
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Mar 04, 2008 | Epson Aculaser C1100 Printer
Samsung CLP-510 Print Quality problem
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Dec 01, 2007 | Samsung CLP-510 Laser Printer
Occasional 1/2 inch wide vertical column of color printing on page
Yes absolutely the PCU problem, contact your nearest shop to check the PCU before anything will happen to your printer.
Please rate me solved you decide to check the PCU. Don't look for another solution because I got already the right answer which already suspected at your own guest.
Best regards,
Philip
Nov 12, 2007 | Epson ACULASER CX11NF All-In-One Printer
Blank stripes on page left to right
If the blank stripes go up and down the page (vertical) then it sounds like the laser lens has simply got toner on it. remove the toner and photo conductor units. Look for the glass panel that covers the laser lens and simply wipe it off with a cloth. Some machines incorporate a lens wiping pad that can clean the lens without taking out the parts. I can not remember if the 1710 does or not.
Sep 06, 2007 | Samsung ML 1710 Laser Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
70 people viewed this question
old marine
old marine
