Question about Craftsman 8 amp Reciprocating Saw with Soft Carry Bag 3 pc Blade Assortment
My blade is in upside down. How do I get it out?
    Genius:
  • 1,015 Answers
I don't know how much help I can be becauseI've always had millwaukee sawsall and on them the blades are reversible. Havve you tried loosening retaining screw up and using pliers right at base or foot and just grip it tightly and rock it up and down a little bit..while pulling stright out.Hope this helps. Good luck Thanks
Posted on Nov 14, 2010
Why won't my ceiling fan blow air down anymore no matter what direction it turns
sounds very intriguing really, like some body has played the
practical joke of turning the blade assembly upside down.
Just an onservatio. Can the blades be removed and replaced upside down? please let me know what you discover, it sounds very interesting
Jun 03, 2015 | Hunter 21894 Westover Four Seasons 52-inch...
Why do i have excessive vibration /broken blades with a sears scroll saw
You have poor quality blades (try Olsen blades), or
You're forcing the work past the blade (just "offer" the work to the blade, let it cut, don't force it to cut), or
Your tension is too high, or
Your tension is too low, or
Your blades are getting installed upside-down (teeth point DOWN).
May 10, 2014 | Sears Scrollsaw Woodworking & Crafts
Need a new blade for blade bracket item #33221 Harbor Breeze 52"
Someone commented "Otherwise the fan blades are on upside down." The blades are reversible, with different finishes on each side, there is no way to install the blades "upside down". Not sure what they were trying to say...
I'm a retired electrical contractor that has installed, quite literally, thousands of fans.
Nov 15, 2012 | Dryers
I have just bought this model second hand, and the blade is fitted upside doen for some reason. How do i change blades?
Hi marill469,
Here is a website where you can download the owner's manual for your saw: http://www.retrevo.com/d/ds/progress?doc=e045b5a9143e1e2ea028b778addd77ca&rk=0.7594880065395843
The instructions for blade insertion and removal are on page 7.
As far as I know, there is no upside down on a recip saw blade. You can use it either way. Upside down allows you to get the blade in tighter spaces due to the shape of the saw.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 19, 2011 | Makita JR3050T Recipro Saw 9 Amp
It will not pick up mown grass, either wet or dry.
Check the blade! Your mowers blade is either worn out or installed upside down. The shape of a mower blade creates a vacuum or lift. The leading edge of the blade (sharp edge) should be parellel to the ground, while the trailing edge of the blade should rise up at about a 45 degree angle. This creates lift. As a blade wears, not only will the leading edge get dull, but sand and dirt cause the trailing edge to wear and reduces the vacuum effect. An upside down blade (easy to do) will just smash the grass and won't create any lift.
Sep 08, 2010 | Garden
How do I install gator blades?
They attach just like the standard blades. A bolt goes through a washer, then the blade, then into the bottom of the mandrel. Helps to have a short block of 4x4 wood laying around to act as a stop to the blade movement while you unbolt the old and put in the new. If you have never done this it also helps to have the deck either off the mower or the whole thing on a good set of jack stands. And do not put them on upside down, the little vanes go UP in order to provide lift to the grass. If you have the deck off and upside down in the grass,t UP is then DOWN.
Aug 12, 2010 | Garden
Fan blades will not line up with holes on motor, can not attach blades
I had fun like this once! Check and see if the holes line up after turning the blade bracket upside down, next move the blade bracket to the next set of holes.
Feb 11, 2010 | Hampton Bay Sidewinder 04890 Ceiling Fan
My Bosch 4000 blade will not go down any farther than an inch above the top of the table.I have checked and cleaned all the gear area and can see nothing that is causing it .
First of all, love the saw. As good as portables can be, the 4000 is really great.
Now, just remedied the blade height adjustment problem, here is how:
Unplug saw.
Removed blade....not easy when you cannot raise the blade, flip the saw upside down and remove the plastic shield, turn saw upright and remove blade.
Used my compressor with blower attachment and blasted all of the dust out of the gears and screw rods with saw upright and upside down, bevel saw to 45 degrees to gain more access..
Sprayed quite liberally with silicone spray lube and gently worked blade height adjustment, adding more lube, cranking wheel, more lube....blade adjustment now works like the day I bought the saw.
DO NOT USE WD40 or the like. This will just attract more dirt in a very short amount of time.
We'll see how the silicone spray holds up.
Good luck,
RjW
Jan 24, 2010 | Bosch Electric Table Saws
Lawnmower blade turns but does not cut
You have either bent the blade and its to high to cut or you need to sharpen the blade with a grinder.
Aug 01, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Clutch adjustment on a John Deere JX 85 push mower
my jx85 when cutting grass with my jx85 the power to the blade dies if i lift it up the power will come back put it back into grass it dies again any ideas please
Jun 21, 2009 | Garden
Craftsman 8 amp Reciprocating Saw with Soft Carry Bag  3 pc Blade Assortment Logo
69 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
