Question about Sony Playstation 3 (PS3) Console
Picture but no sound
Hello I have had my ps3 for the last year in in which i used it on my sony flat screen w series tv in HDMI mode with no problems. Now i tried to hook my system up in the same way to my samsung using the hdmi cord and now i only get the picture but no sound and the main menu does not come up when i quit the game. The screen just goes blank. The T.V. is a new and the hdmi hookup has worked with other devices. What can i do to make this thing work or to at least get the main menu to show up on the screen so i can take the ps3 out of hdmi mode?
    Problem Solver:
  • 35 Answers
PS3 is The amazing device by sony but it has some common problems like sound but no picture problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Mar 12, 2009
  • 49 Answers
My sound cut out when i was playing online and everything is fine when i start it up and i get the sound then it says "PLAYSTATION 3" with the tone and then no sound at all any ideas?
Posted on Jul 23, 2008
Its in your manual on how to reset the video settings
with the system off - red light (standby mode), i think you hold down the power button on the unit for 5 - 10 seconds until you head 2 beeps from the system.  the green light should be blinking/talking to you and then stop.
the system should turn off on its own after the beeps.  you've just reset your video settings.
then power it on again normally and reset your video output settings.  I did this when I switched from HDMI to the **** cables it came with to play on another tv for the night.
Posted on Jun 18, 2008
It happens to me alot lately i think its the actual hdmi port of the ps3 just unplug the hdmi cable and plug in and it should work just fine.
My ps3 console signal isn't working but the sound works but there is no signal! not even a hdmi cable works help!
Try these tips to fix the so-called "black screen of death".
Tip 1: The main reason of HDMI black screen problem due to HDMI cable may be damaged and not properly connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:
1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damaged, borrow a friends cable and try it. If your friends cable works fine, and the black screen error disappears. Then you can buy a brand new HDMI cable for a replacement.
Tip 2: Only try as last resort. There is a possibility you'll lose all data on your PS3's hard drive. If tip 1 didn't work, you will need to go a step deeper and reset your console. Most PS3 gamers are not aware that Sony actually included a black screen of death troubleshooting method and other HDMI problems in the PS3 manual, you can find it under the troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data on the hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed by two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
If it works you should be good to go.
May 20, 2012 | Sony Playstation 3 (PS3) Console
When connecting ps3 to Hdmi tv via hdmi lead or av connection ,ps3 is powering up ok but error message appears on tv screen saying game mode not supported.
hello,,when you connect a hdmi you have to into the menu and select hdmi this should give you a 1080p picture mode
regards
shaun
Oct 08, 2010 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 + HDMI + Samsung Series 5 47"LCD Problems (tried all solutions i found) OK at my wits end now. Heres the testing I have done. Have the ps3 connected to the set using the av...
make sure ur not using both the av cable and the hdmi on some models it causes conflict although they are on different inputs. also did you try using a blu ray player or another ps3 on that hdmi port using the same cables or different cables? if another equipment work/don't work u can at least start to narrow down your problem..
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
No picture, sound or menu on PS3
Try booting the PS3 with the hard drive removed from the drive bay ( on the side) you just remove the small plastic piece hidding it and remove one screw. It's easy. Let me know what happens. Also make sure you also plug in the original red white n yellow cables too to check if it's just an hdmi issue or system wide.
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
No picture displayed on screen
OK, I am assuming you are using the same TV, PS3, cables etc that you were using before you went on vacation. Turn off the PS3...we are going to reset the video display. make sure everything is connected properly before we start. now here we "kinda" gonna turn it on, except you will hold your finger on the touch sensative power button until it beeps several times in a row with about a half second between beeps. It should reset the PS3 and the resolution.
If you get nothing on the screen after trying this several times, you should gather up 150 bucks and call sony for hardware repair.
May 04, 2009 | Sony Playstation 3 (PS3) Console
PS3 no picture and no sound
Try turning the system off completely with the main power switch on the back of the console. If that doesnt work call Sony technical support for further help.
Aug 04, 2008 | Sony Playstation 3 (PS3) Console
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
No sound from HDMI to PS3
go under system setting-->select sound settings-->select audio output settings -->hit x on hdmi-->hit x on automatic-->hit x to enter. This solved the issue for us :)
Dec 04, 2007 | Sony Playstation 3 (PS3) Console
Picture goes to a lime green fuzz and then no piture or sound!
which AV connection are you using? HDMI or the cable supplied with the PS3, If using HDMI, you have to set the PS3 visual settings to HDMI, to do this, use the cable supplied with the PS3, and have the HDMI cable plugged in. Then while using the cables supplied with the PS3, switch the settings over to HDMI, then change the TV's input selector to your HDMI and confirm the settings changes. Hope it helps take care
Oct 17, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
101 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
