HELLO THERE: SYMPTOM:
WASHER FILLS, BUT DOESN'T AGITATE AND/OR SPIN
1) Check the imbalance/lid
switch FOR continuity. Check also the speed selector switch (if
any), the water level and water temperature switches for proper operation .
NOTE: If any of the selector switches on the
console are only partially pushed in, it may cause improper function.
2) Check for a broken or badly
worn belt.
3) Check the motor rollers and
tension springs for damage and the motor roller tracks for jamming. Any of these might cause the belt to be loose.
4) Check the appropriate timer
circuits for continuity.
5) Remove the belts and see if
the motor will start. If you hear the motor buzzing, but it doesn't start in
either or both directions, test the capacitor (if any) and starting switch
If it does start with the load removed,
turn the pump and transmission pulleys by hand, in both directions, to see
which is locked up. If the pump is locked, If the
transmission pulley is locked,. Note that the transmission
pulley will normally be very stiff when turning it in the clockwise
direction, as you look at the bottom of the washer.
