Question about Vizio GV42L 42 in. LCD Television
Everything is too bright! My new TV was working fine and then last night I tried hooking it up to my computer and it changed everything...
5 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Posted on Apr 04, 2007
  • 4 Answers
SOURCE: No Picture just sound from Toshiba 37hl17
IT is the Y Sustainer board blowing fuses. IT has 2 fuses. I have worked on severl of this model and the Y Sustainer board goes bad and blows the fuses.
Posted on Feb 23, 2008
erleichda1
  • 7 Answers
SOURCE: vizio HDTV totally not workinig
It sounds like a problem with the power supply. I had the same thing happen on a TV that was only a couple of years old. It did the same thing that you have mentioned. Once in a great while, it would turn on, and then we'd just leave it on because we didn't know when we would be able to get it to work again. The problem was, to buy a power supply for it we could get another TV. It just wasn't worth it.
Your flatscreen might be under warranty. I would look into that.
Posted on Jun 11, 2009
budmrtn
  • 11361 Answers
SOURCE: i have a toshiba 37 wlt 58 lcd tv . i watched the
Sections of the power supply may have gone out, or it detects short circuits in the backlight inverter board or in the power supply itself.
Those are the two areas you need to check. Look fo bad caps with leaking/bulging top fist in the power supply.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Aug 13, 2010
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
Everything working fine until 9pm last night, Comcast cable modem hooked up to Airport Extreme with 2Macs, 2PC's and 2X-Box360. Everything died at same time and now unable to connect to the network(which...
Try doing a Trace Route on DOS ;
Open DOS - Start > click Run > type "cmd" = DOS
DOS COMMAND
tracert www.yahoo.com
IF THE RESULT WILL SHOW A " * " or timeouts then it is something to do with your line or if the response time is very high like 100ms 200ms 300ms then it is something to do with the line indeed ( normal = 1 ms - 50ms)
Mar 06, 2010 | Apple AirPort Extreme Router
Discoloration problems
covergence problem, most likely the ic's are bad, call a repair man!
Aug 27, 2009 | Televison & Video
No sound from hdmi cable
Go to the Sound settings in PS3 and be sure it's listed as HDMI and not Audio Video Cables.
Output on TV may be set to surround sound system? Powerd On?
May 25, 2009 | Sony Playstation 3 (PS3) Console
White lines coming off of image...
If the set has contrast and brightness controls, try them but this problem is normally caused by a certain capacitor (I don't know the circuit reference number for this one) failing and it will continue to decay. Any competent TV tech (if you can still find one) will know where to look.
Jan 06, 2009 | Durabrand DWT1905 TV
My computer monitor has somehow turned its brightness all the way down, possibly due to me choosing a new screensaver which was already installed on my computer. Sadly, my monitor, an Emprex LM-1704...
Find yourself a dark room or wait for the night to come. The darkest monitor adjustment could somehow reveal some light when there are no other light source available.
You may also hook a conventional CRT monitor and make your changes (such as bringing your computer back to its original settings). The darkest adjustment in CRT monitor could still render discernible displays.
Sep 09, 2008 | Computers & Internet
No freaking signal
Double check ALL your ant wire connections. Then reprogram the converter to check for stations again. If that doesn't work then reposition your antenna and reprogram again.
May 21, 2008 | Insignia Digital-to-Analog Converter for...
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Vizio GV42L 42 in. LCD Television Logo
52 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
