Was working. Volume went up tp the max. couldn't turn it down, so I turned off the tv. Now it won't turn back on.
  • 11,800 Answers
The level of the sound volume is decided by the control processor thru a resistor grid. At maximum volume only the smallest, last resistor is used. If none of the others are engaged it means that the control processor is shorted, which would explain why you are no longer capable of starting the tv.
The control processor is solderer on the mainboard and can't be replaced on its own - you ill need to replace the entire mainboard. This is an expensive job, you must decide if the tv is still worth the at least $250 needed to do the job.
Posted on Nov 14, 2010
Radio no longer has any volume: Resets suggested dont work. How to pull this sucker apart?
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter follow the steps below.
Turn the unit on
Turn the volume down to minimum, 00, volume
Press and hold power for 10 seconds until volume numbers flash
Turn the volume back up to 50 (max volume)
Press power again to verify new max volume position
Jun 03, 2015 | Boston Acoustics Horizon Solo Clock Radio
Volume maxes out. when poered on
hi go into menu on the tv scroll down to sound setting look for avl set it to off hope it works
regards
shaun
Jan 22, 2014 | Proscan 42LA30H 42 in. LCD Television
Volume control
Poltergeist in volume circuit is the diagnosis. Try a hard reset of the receiver to see if that does the trick with the electronics.
Sep 01, 2017 | Mitsubishi WD-82737 82" DLP TV
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
I have a Samsung 32 inch LCD tv that constantly changes channel on its own. I switched it on this morning and it was working fine then the volume went to max and I couldn't turn it down. I then switched it...
You say the remote doesn't work but it may well be the problem. Take the batteries out of the controller then try using the tv using the controls on the TV.
Dec 02, 2010 | Televison & Video
The volume to the tv goes to max when you turn it on?
that hapened because your remonte contral has the + button pressed just release the volum + at your remonte and all will be ok
or try to hide your remonte control and get down sound from front panel of your tv
Dec 11, 2008 | Televison & Video
My volume will not come up
my volume went out all of a sudden will it ever come back on or how can i get it back on
Jul 20, 2008 | Durabrand DWT1905 TV
Volume Issues with Television
toshiba 35a44 I had in shop would not turn on initially,when Qa01 was replaced I was able to turn tv on, but after a couple of minutes volume went all the way down, vol display bar on screen and power and menu keys would not work, remote control function did not mater. after replacement of QA02 mpu no results. desoldered volume down and up keys and sprayed chassis with flux remover on both sides of chassis and sumerged vol keys in alcohol solutions for 10 minutes, restored them in chassis and the problem was corrected. QA01 and QA02 did not had to be replaced there was a contaminant problem on solder flux that was causing the problem. kbzon
May 11, 2007 | Toshiba 35A44 35" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
