Question about HP Photosmart C6100 All-In-One Printer
Can't send or recieve faxes
I cannot send or receive faxes lately, so I disconnected power to the HP 6100 Photosmart all in one, reconnected after about 5 minutes, and then finally rebooted my computer.
Next I called my fax number to confirm that it was operational. After three rings I got the usual FAX SOUND, so that appear to be fine.
The unit will copy and scan just fine, but no faxing.
Please help, thanks, John
jrc411@verizon.net
  • 4 more comments
  • CuteBoy Jul 07, 2008
    HP Photosmart 6150 suddenly came up with Unable to Send or Receive Faxes msg when printer turned on. When I try to receive (call the FAX #) get an electrical noice from where phone ports plugged in. Has worked for 2 yrs. HP says h/ware failure -- which means buy a new one. Use a strong Surge Protector; unplug while we are gone. What happened?
  • karencantel Jul 17, 2008
    I have a HP Photosmart 7200 series All in One, and the fax will not send or receive faxes, When I attempt to fax, I will receive above mentioned message on small LCD screen on printer, I checked phone line,there is a dial tone, and it is analog, and no static. I even called HP, had to reboot printer, to 'reestablish' connections, and this did not work. This error message I receive, just started a few days ago, I have had printer for one month, and, it coincided with a thunderstorm we experienced and our power went out, for a brief second,, perhaps there was a power surge? Anyway, any imput would be great, as to how to fix my fax...thank you....karen
  • Anonymous Aug 04, 2008
    Same problem with the C7280 - we've had lightning lately and power surges - my power was protected but the phone line was not. My cable modem was definitely hit by the surge, and that's where my phone connection comes from...
  • Audreyd001 Aug 16, 2008
    Same problem after a storm also.  Is there anyway to fix this without having to replace the whole thing?
  • Anonymous Oct 07, 2008
    I have the same problem after strom fax failure for HP C6180, phone line is in working condition. I trun off power and start again did not work for me.
    Find solution let me know.
    Jbabylon1@aol.com
  • JBuilder May 01, 2009
    I have a HP c7280 and it is experiencing the same issue. It won't send or receive faxes, it says Fax failure-unable to send or receive faxes. This problem started after we had some thunder/lightning storms. Can it be fixed or should i just buy new one?
Step three: Use an analog telephone service HP Fax and All-in-One products are designed to work with analog telephone services and might experience some difficulties when they are connected to phone lines with digital services. Make sure the product is connected to an analog telephone service. To obtain digital services information or support, contact the telephone service provider or system administrator.
Posted on Aug 26, 2008
  • lcmpt Aug 26, 2008
    I was told to purchase a DIGITAL CONVERTER and that should work.
Can I send and receive faxes?
u need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
Aug 22, 2015 | HP Photosmart 3210 Printer
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
C7180 can't send or receive fax? this worked a
press setup button. scroll to advanced fax setup. press ok. scroll to ecm press ok. select off. then press ok. then press cancell button to go back to main screen. now try to send and recieve fax.
Dec 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
When I try to send a fax the machine gives a message cannot receive or send fax. I am getting a dial tone through port 2 still. If bad modem can they be changed in this model?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
In order to find the solution to this issue, you need the fax number for another fax machine that is operating correctly with which to send and receive faxes. After trying each of the following solutions, try to send or receive a fax from this other fax machine to test if the issue has been resolved with your HP fax product. The other fax can be in the same building, on another telephone line, or at another location with someone who can assist. It can also be helpful to call the person or company that is sending the fax. That party can offer information about how that fax machine behaves when sending a fax. This information can be valuable in determining the nature of the issue.
There are several possible solutions to this issue. Start with the first solution and then continue with the other solutions in the order presented until the issue is resolved. When the issue is resolved, there is no need to continue troubleshooting.
Solution one: Run a fax diagnostic test
Run a fax diagnostic test to make sure that the HP fax product is set up correctly.
Load letter or A4 unused plain white paper into the input tray.
on the product control panel, press the setup button ( ).
Use the down arrow key ( ) to select Tools and then press the OK button ( ).
on the Tools menu, use the down arrow key ( ) to select Run Fax Test and then press the OK button ( ).
Review the results of the test.
If the result of the fax diagnostic test is All Pass ,
Reinitialize the fax
1. With the HP fax product turned on, disconnect the power cord from the back of the HP fax product and from the electrical outlet.
2. Connect one end of the telephone cord to the telephone jack and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
3. Reconnect the power cord to the back of the HP fax product and then reconnect the power cord to the electrical outlet.
4. After the HP fax product reaches a ready state, try to send and receive a fax again.
If this works GREAT!, if not let me know....JCE
Apr 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
My HP Photosmart 2610 will send faxes but wont receive them.
If your issue is somewhat like this:
When receiving a fax the line disconnects. No faxes or calls can be made until the fax being received is cancelled.
Then, Try the following procedure:
  1. Ensure that you have a two contact phone cable connected to line 1 socket of the printer and that the other end of the cable is connected to the phone jack in the wall.
  2. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 3 keys.
  3. Plug the power back into the printer, keep holding the # and 3 keys till you see “ Partial Reset ” displayed on the printer screen.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good Luck!!!! Let me know if there is anything more i can do for you if not and this solves the problem, please rate it. Thanks, JCE
Apr 14, 2009 | HP Photosmart 2610 All-In-One InkJet...
Cannot recieve a fax
i have a H P 3050 THREE IN ONE AND I CANNOT RECEIVE FAXES I HAVE COMCAST AND HAVE ALL MY SERVICES IN ONE, CABLE, PHONE AND INTERNET. DOES ANYONE KNOW HOW TO PLUG THIS IN CORRECTLY
Jan 13, 2009 | HP Office Equipment & Supplies
Installed new computer - keep getting error - HP Photosmart C6150
Try
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jan 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 prints but won't copy or fax...
i can not recieve faxes. It use to work fine. I can send them out, but not receive.
Jan 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
Unable to receive fax unless Westell modem is disconnected
sounds like you have a modem problem and that should the telephone company's call.
Jan 28, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer Logo
1,327 people viewed this question
Seeker5211
Seeker5211
