Question about Electrical Supplies
Need homelite generator model LR4300 UT03828 manual for the generator
2 Suggested Answers
SOURCE: Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Posted on Jul 13, 2011
Homelite HG600 Lightnin'bug generator. Where can I get an owner's manual?
Homelite Vintage Camping Generator - HG600 Lightnin Bug ...
? 1:23
www.youtube.com/watch?v=Amq5VLOsiN8
May 6, 2014 - Uploaded by david lum
For Sale: Great Generator 500 watts - quiet - looks like new - starts easily. Complete with owners manual.
Sep 25, 2015 | Electrical Supplies
Homelight lr4300 generater
http://www.homelite.com/service_support/parts_locator
May 10, 2015 | Cars & Trucks
4500 running watts 5625 starting watts
http://www.manualowl.com/p/Homelite/HGCA4500/Manual/185973
Mar 23, 2015 | Watts Electrical Supplies
Homelite LR5550 serges when it runs is there a way to set the governor so will run smooth
Try opening the high speed jet about 1/8 turn. If that don't work clean the carb.
Jul 07, 2014 | Garden
I have a homelite LR4300 with the 7.5 HP Subaru engine. The governor is not working. Whats the poblem?
Unclear when stated that there is a governor issue? I assume you have a Robin/Subaru 7.5 H.P. engine model EY280YD2510 with erratic behavior leading up to stalling out when a load is applied or the generator is at no load status after several minutes of run time?. Couple of things to check would be starting with the fuel system. Is there stale gas in the fuel tank? Have you verified fuel flow from tank? Is the fuel cutoff valve free of debris? Is the carb fuel bowel been removed and inspected for varnish? Is the air cleaner clean? Next, Ignition system. Have you inspected the flywheel for excessive rust? Have you reset the air gap on the ignition module? Does the on/off switch work (measured with a meter for continuity?) Any visual signs of damage with all wiring or the ignition module itself? I once thought I had an governor issue where the issue ended up being that the flywheel was corroded to the point that once the engine was fully warmed up the control module would contact the rust build up on the flywheel causing engine surges no matter what the load was on the generator, and at times would stall the engine. Clean flywheel off if necessary and reset the air gap on the ignition module. If that fails then inspect the governor spring (the top spring on the carb. linkage assembly) for excessive rust that will change the tension on the governor arm.Replace if in doubt! When doing all this inspecting ensure you have fresh fuel, oil, air filter, spark plug gapped correctly, and ignition module that has been tested as sound! These Robin engines are smooth running heavy duty engine that will perform for many years if taken care of. Good luck!
Dec 07, 2013 | Robin Subaru Electrical Supplies
I have a homelite 720 generator but cant fingd the instruction manual and i need to know if the charger leads only charge a battery or can be used as jump leads i know this might sound stupid but i wo
I can't find any reference to a Homelite model 720 generator but most battery charging systems do not supply enough amps to run a car starter. Battery chargers usually work in the two (trickle) to ten amp range. Car starters need way more amps to have enough power to turn an engine over, depending on the size and number of cylinders in the motor. Some chargers have a switch with a 60 amp 'start' position to help the battery turn the motor over, but without that there is little chance the charger side of your generator will supply enough amps to help your battery.
Feb 21, 2012 | Cars & Trucks
I need a wiring diagram for a homelite HRI4400HD generator please.
Go to Homelite's web page http://www.homelite.com/ and you enter your Model Number and download the Owner's Manual, that should have wiring diagram in it. If you don't find it. contact Homelite Customer Service.
Hope this helps you find what you need.
Apr 18, 2011 | Heating & Cooling
Ive got a homelite 720 watts generator and after a month from my purchase it wont start at all. i asked the dealer and they told me that the ic inside of the genset is busted. i told them if they have...
Please list your model number when posting and I might have found part number for you.
Go to homelite.com service and support, find parts, parts locator, model # if you cannot find model number go to product line, homelite, then select generator, without model number you will have dozens of generators to look at.
Jul 09, 2017 | Homelite Garden
Mar 07, 2010 | Electrical Supplies
Electrical Supplies Logo
706 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
