Question about Amana Refrigerators
Running intermediately, have to knock to get compressor running. refer and freezer will warm up before it will cool.
  • 3 Answers
Sounds to like a sticking cold control, Once the unit cuts off it will not come back on until the box is either hit on the side or hit around the cold control. The next time it does not come back on, try taping the cold control, if this does not work then you have a defrosting timer that is hanging up.
Posted on Nov 14, 2010
Maytag fridge not cooling
If the ref or freezer is too warm and you turn the dial to make it colder the compressor should come on. If the ref or freezer is not cold like you say the compressor should be on all the time. You should hear it, but you can definitely feel it and it should be very warm after a short while.
If the compressor does not get warm unplug the ref with the compressor running and plug it back in immediately. A good compressor should not start up right away.
If it is running and not getting warm and does start right up after unplugging it and plugging it back in it is inefficient and not compressing the freon gas enough and therefore not cooling enough.
The fan in the freezer should be running as should the fan under the refrigerator.
The condenser should be warm and the fan should be blowing[drawing] air across it when the compressor is on.
You don\'t repair compressors and to recharge them correctly is expensive.
May 01, 2013 | Refrigerators
My refer Kenmore coldspot) does not get cold. The freezer is warm as well. The fan and compressor kick on....... any best bet ideas
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Power on but both refer and freezer warm
heatman101
Aug 01, 2011 | Microwave Ovens
Freezer section gone warm, feels like refer section may be getting warm. Possible cold controls problem
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 19, 2011 | Refrigerators
I can hear the motor running and the lights are on. But the refrigerator is warm and the freezer has thawed everything.
By motor, I assume you are referring to the compressor underneath the refrigerator. Close by the compressor toward the rear of the refrigerator, there should be a compressor fan. This should be turning. If it's not, the refrigerant coils will not be cooled adequately. This results in inadequate cooling inside the unit. Check also to make sure the coils are not covered with dirt and grime. If they are, clean them.
If the compressor fan is not turning, you will need to replace the fan motor.
Oct 18, 2009 | Amana ABB1927DE Bottom Freezer...
Upright freezer quit cooling, interior fan runs, compressor runs
The coils are most certainly there probably located under your unit. Clean them thoroughly. Look under and to the very top of that space.
Jul 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
Whirlpool Refridgerator Noise
Why did you put the megahertz (60 hz) on your question? Get access to the back of the fridge, take the panel off, on the bottom, there is a compressor and condenser fan motor. Look these two and see if the noise can be found here. The fan should run when the compressor runs. If the fan is running and quiet, put your hand on the compressor. It should be warm, slightly hot, but not so that you cant leave your hand on it. If it feels hot and the fan is running, clean off the coil underneath the fridge. Often this is the only problem as nobody hardly ever cleans this thing off. Its the equivalent to the radiator on your car.
Dec 26, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Aug 20, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerators Logo
22 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
