Question about ASUS Computers & Internet
Need jumper settings to make ASUS CD-ROM-S480/ah the master CD -ROM
  • 62 Answers
No jumper setting needed it is based on cd rom connectivity wire.......use first block to make it master
as it contain to blocksneed jumper settings to make ASUS CD-ROM-S480/ah - cooleoakash.jpg
Posted on Nov 14, 2010
  • RussDodson Aug 06, 2011
    Wrong. Both of the IDE 'blocks' receive Master and Slave information supplied by the jumpers on the back of the CD device. There are three positions: 1. Cable Select (CS) - Both must be set to CS. The Master is the first connector on the cable and the Slave the second; 2. Master (MA) - the other device (if any) must be set to Slave (SL).
    I am looking for the jumper settings for the Drive itself. thanx
Detects ide HDD but not cd rom on same connector
This could be that the jumper on the CD ROM drive is set to MA (Master) and it is same jumper setting as the hard drive.
Change the jumper on the CD ROM to SL (Slave).
Jul 20, 2011 | MSI G31M3-L V2 Motherboard
Dvd writer doesnot showing in bios
Theres' a couple things you need to double check. If you also have a CD-ROM drive connected to the same data cable as the DVD-ROM writer check the jumper on the back side of both. One should be pinned with a two pin jumper and set as a master and the second should be set as the slave. The back side of each ROM drive is marked M for Master, S for Slave & C for cable select. (Cable Select not suggested).
Double check the data cable. Remove and re-seat at the motherboard and at the ROM drives Parallel ATA data cable. Also check the power cable. Remove and re-seat. If everything is connected and the two pin jumper correctly and snug you should see the DVD listed in the BIOS.
Performed a restart and check your BIOS.
Cheers'
Mike
Jul 20, 2010 | ASUS K8S-MX Motherboard
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
Reinstalling the original cd rom that came in the computer. do i need to change the jumper settings. it is a samsung sc-148
That depends upon the IDE cable you are attaching the CD ROM to.
There are two IDE cables attached to the motherboard, on IDE 1 connector/cable will be your boot hard drive (C drive) and this will be jumpered to Master and you can attach the CD ROM drive to this cable and set the jumper on the CD drive as Slave.
On IDE 2 connector/cable if there are no drives attached to this cable then the CD ROM drive can be jumpered as Master or Slave..
If there is another drive on the same IDE 2 cable then look at the jumper on that drive, if it is jumpered to Master then the CD drive needs to be jumpered to Slave. If the existing drive is jumpered as Slave then the CD drive needs to be jumpered as Master.
Both drives on the same IDE cable cannot be jumpered with the same setting.
Nov 30, 2009 | Computers & Internet
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
ASUS P5S800-VM Motherboard configuration
Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
Mar 20, 2009 | ASUS P5S800-VM Motherboard
Jumper settings for samsung dvd drive
There should be a diagram on the drive indicating the jumper positions. Good luck!
Mar 13, 2009 | Samsung SM 352 CD-RW/DVD-ROM Burner
Not Detected HDD or CD
It seems that ur Cable might have some problem..pls change tha cable and check..
and also check the jumper setting backside of hard disk and cd rom for master and sleve...
Dec 15, 2008 | Computers & Internet
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Motherboard can not detect dvd rom help
try changing cable is it set at master on jumper for end of ide cable and if its middle dvd rom drive its slave set jumpers to slave ok try changing cables clean yo cd
Jan 09, 2008 | ASUS K8V-MX Motherboard
Computers & Internet Logo
220 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
