Question about Panasonic DMR-E55 DVD Recorder
I have a dmr-eh50 and am getting a chk remote2 message on the recorder. When I enter 2 and the enter button the display goes back to a previous function. When I hit enter again the message keeps coming back.
  • sjs10526 Nov 16, 2010
    Thanks it worked.
  • 10,594 Answers
Press and hold ENTER and 2 button on remote at same time for 3 seconds to set/ change remote control on remote-2 mode so dvd recorder can get its signals.
Hope this info will hep you.
Thanks.
Posted on Nov 15, 2010
While trying to save parts of a TV-programma I recorded on mij Panasonic DMR EH50 DVD-recorder I try to delete the parts that are'nt useful to me. The recorder gives the following message: Can not 'work'...
Highlight the recorded program on Direct Navigator then press the Sub Menu button on the remote, then select "Shorten Title". Press (Enter) at the start point and end point of the section you want to erase, then use the up/down button to select "Next". Then, select "Erase" to delete the unwanted sections. Repeat this process for all unwanted parts, then select "Exit" to return to Direct Navigator.
Nov 01, 2010 | Panasonic DMR-EH50 DVD Recorder
NAO CONSIGO USAR MAIS O CONTROLE REMOTO, COM ISSO NAO CONSIGO FINALIZAR O DISCO......QUANDO TENTO USAR O CONTROLE APARECE NO DISPLAY " CHECK REMOTE ". E NAO SAI DESSA.
Há algum tempo o meu Gravador de DVD de mesa Panasonic DMR-E55PL-S vinha apresentando a seguinte mensagem de erro sempre que eu clicava qualquer comando através do controle remoto: CHK REMOTE2 Havia entrado em contato com o técnico da autorizada Panasonic de Niterói e ele ficou devendo-me uma solução. Como possuo outros 3 gravadores de mesa (2 Pioneer e 1 Samsung R121), apesar da contrariedade, não esquentei muito a mufa. Hoje, porém, encasquetei, e resolvi tentar, mais uma vez, resolver a má função. Após "ene" tentativas malogradas pintou o insight: - "Cacildas! Se eu faço tanta pesquisa para dirimir as dúvidas dos companheiros, por que não o faço também, para mim"? Assim, digitei no "gluglu": CHK REMOTE2 Panasonic Entre outras dicas, saquei esta: Question: - "Whenever I press any button on my remote control, I get this error message on the front panel display - CHK REMOTE2" Answer: - "Just hold ENTER and press the number indicated on the display for a few seconds, and it will fix the issue". Basta clicar ENTER e pressionar o numero indicado no display do painel frontal do gravador por alguns segundos - isto resolverá o problema. (Clicar ENTER e pressionar o número 2 no controle remoto). Tal dica serviu para o meu DMR-E55PL-S como também para o DMR-E85HS - do **** "flashcode" - devendo servir para outros modelos Panasonic da mesma linha. Soçarba... Mr. Walker
Aug 25, 2010 | Panasonic DMR-E55 DVD Recorder
My DMR-EH50 is stuck in SP mode and when I hit the button on the remote it keeps displaying CHK REMOTE 3. Would you know what is causing this. I cannot get the unit to do anything at all.
Very easy fix.
Your DVD recorder can be set up to accept remote contol signals on any one of three channels. Remote 1, Remote 2 or Remote 3.
Your remote can be set up to send signals on any of these channels. You need to make sure your recorder and remote are set to the same channel.
Your recorder is telling you that it is set to receive remote control signals on channel 3. This means your remote control is currently set for a different channel.
Assuming that you have a genuine Panasonic remote, do the following,
On your remote press the "Enter" button and hold it down. Then press the "3" button at the same time for two seconds, then release both. This will change your remote so it sends signals on Channel 3 which will match your recorder.
Those clever people at Panasonic realise that you will be delighted with their products and will probably have several of their appliances in use. The different channels avoids switching all your Panasonic gadgets at the same time. Clever huh?
Best wishes
Aug 24, 2010 | Panasonic DMR-E50 DVD Recorder
I have Panasonic dmr-e95H and need to reset the
My DMR-E95H displays: "CHK REMOTE2" whenever I push a button on my "replacement" remote. Is there a way to reset the DMR-E95H without the original remote?
Apr 05, 2010 | Panasonic DMR-EH57 HDD Recorder Player
We have a Panasonic DMR-EH50 DVD player/recorder. We recently moved house and following the move, the FUNCTIONS button on the remote no longer works. Everything else on the remote does. I've tried...
The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Apr 04, 2010 | Panasonic DMR-EH50 DVD Recorder
Pan DVD Recorder DMR-EH50
Press enter and 2 at the same time for more than 3secs
Oct 29, 2009 | Panasonic DMR-EH50 DVD Recorder
Actually I have a 4 yr old dmr eh50 panasonic dvd recorder
Make sure remote is set to unit code ex: press enter and 1 at same time see if this matches try enter and 2 or enter and 3 see if this matches and works
Oct 03, 2009 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
DVD Recorder Screen keeps saying HOLD and not switching on
CHILD LOCK:
The Child Lock Deactivates All Buttons On The Unit & Remote Control.
To Deactivate Press & Hold (OK) & (RETURN) Simultaneously Until "X HOLD" Disappears.
Oct 28, 2008 | Panasonic DMR-EH50 DVD Recorder
Remote control not working
I had the problem where when i would try to use my remote, it would say "check remote2". I've got a DMR-E55. I called panasonic and they told me to hold down the "enter" and "2" button for about 10 seconds. then it worked. hope it works for you too.
Jul 09, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
451 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
