Question about Reliance Natural Gas Water Heater Control
Will not stay on geep going out - Reliance Natural Gas Water Heater Control
    Genius:
  • 1,015 Answers
Will pilot lit then burner and after it does this with just pilot on is that when it goes out. If this is what is happening ,pilot going out,then I would first change thermocouple. The thermocouple is usually on the bottom left hand side of gas valve.It will look like copper wire about as thick as a pencil lead. Remove burner cover and trace thermocouple line to where it mounts on pilot light assy.Thermocouple should be held in place by friction.Remove thermocouple from gas valve by lossenjng retaing nut,reach in burner compartment and grasp thermocouple at base.using small amount of force pull thermocouple from pilot assy and remove.You can get anew one at most hardware stores. Try to get one close to the length you have. A little longer ok. shorter no.Reinstall being careful when you tighten thermocouple nut as it is made of brass and valve body is made of aluminum.Very easy to cross thread or overtighten and strip threads. Make sure thermocouple is properly plased by pilot. Light piloy and hopefully this will tke care of it for you. THANKS
Posted on Nov 14, 2010
My hot water heater on my 5th wheel heats up in electric and gas but doesn't stay hot. It is hot a first then gets warm and then cold. Hope you can help.
The thermostat which is integral to the gas valve is defective. Simply replace the gas valve and your problem will go away.
Dec 15, 2015 | Water Water Heaters
Sw6p suburban won't stay lit. My 6 gallon hot water heat on my 2007 camper won't stay lit, I go and light the pilot light and it lights but I turn the gas up and it blows out please help
the thermal couple is likely bad .
when you release does pilot stay lit or only as long as you hold the button .
if it stays lit then the thermal couple is good
if it only blows out as you turn on the heat then its draft issue.
May 09, 2015 | Water Water Heaters
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
Sep 04, 2013 | RTO W4 A.O Smith Gas Hot Water Heater...
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
My water heater control won't stay on. I have to
Sounds like the thremostat is going bad and not functioning right thats why you reseting it so much and then it works. They are not to expensive to replace just write down info of water heater or take old one with you to store
May 04, 2010 | White Rodgers 0754-1 Electric Water Heater...
Atwood water heater light doesnt stay on
That light in the switch should only be on momentarily while it is igniting, and then go out when everything is ok. If light stays on, it's to alert you that for some reason, the burner did not ignite, such as propane is off, or some other reason it didn't ignite. If the light stay out, then the burner should be working properly.
Oct 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
Hello, thermostate will not stay lit. vacation
Hello, if your going on vacation any way, just shut the power to it off at the breaker box and deal with it later.
Jul 07, 2009 | Fasco Bradford White Hot Water Heater...
My hot water tanks pilot light turns off after I have relit it. It stayed on while heating the water in the tank and once it stopped heating the pilot light went out again. What would be causing my...
are you holding button down long enough for thermal coupler to warm up? after pilot lights up, don't immediately let go of button for about 15 to 20 seconds then let go and pilot should stay on. If not, you may need a new thermal coupler for that water heater
Jul 03, 2009 | Water Heaters
Does not ligh (Or stay lit)
What is the model number and brand of the unit?
You can go to http://owneriq.net/ to find an owners manual for your water heater. If they don't have one, they will send you to the manufactures website where you can find one.
If the unit will not stay lit then it's the thermocouple on the unit. You need to replace it or you can try cleaning it with a small piece of emory cloth. If you put a new thrermocouple in and it still won't stay lit then it's the main gas valve that is either clogged or defective.
Mar 21, 2009 | Whirlpool Water Heaters
Reliance Natural Gas Water Heater Control  Logo
261 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
