Question about Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
What port does speakers plug into - Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
  • 656 Answers
Speaker plug into the speaker port you will see a three female pin in the rear panel of the computer insert the speaker pin into the center female pin it iis the speaker out
Posted on Nov 14, 2010
Bad Speaker Port
I would head to a radio shack and get a replacement port and make the repair.
Jun 19, 2013 | Audio Players & Recorders
Can a Dell Dimension 3000 connect to 5.1 surround sound
If your Laptop has a "Latitude C/Port Advanced Port Replicator" Then this Port Replicator connects Dell Latitude notebooks to peripheral devices such as a monitor, printer, keyboard and mouse. To accomplish this, connect your peripheral devices to the Dell port replicator itself, and leave them connected to it. Then connect your notebook to the port replicator to access the devices without having to attach them individually each time you want to use them. You can also set up speakers on the Dell Latitude C/Port port replicator to provide improved quality audio.
Follow following steps:
1) Place your Dell Latitude notebook in your C/Port Advanced Port Replicator and turn on the notebook using the power button.
  • 2) Place the speakers you want to connect to the port replicator on either side of the port replicator according to the Left and Right (L and R) labels on the speakers.
  • 3) Plug the audio line connector from the speakers into the audio line out plug on the port replicator. The audio line out plus is on the right-hand side of the port replicator base next to the infrared port, directly opposite the notebook ejection lever.
  • 4) Plug the power cable from the speakers into a power outlet if needed. Battery-powered speakers will not require this. Turn on the speakers following the manufacturer's instructions.
  • 5) Open your preferred music or audio software (such as Windows Media Player or iTunes) on your Dell Latitude notebook and play an audio file to hear the newly-attached speakers.
  • Dec 01, 2011 | Dell Dimension 3000 PC Desktop
    HOW TO PLUG IN SPEAKER
    1. Make sure the speaker is plugged ti the mains(power) 2. There are three or four audio ports at the back of your machine 3. Plug in the speaker jack into the port painted green
    Goodluck
    Jun 18, 2011 | Gateway Solution Computer Speakers
    The speakers quit working/what do I do?
    Make sure that it is the speakers that stopped working by unplugging them from your computer (or whatever you have them plugged into), and plugging headphones into the same jack that the speakers were plugged into.If the headphones work, you have confirmed that the problem is with the speakers. If the speakers use an AC adapter (black plastic cubical thing that plugs into the wall), then you might try getting a replacement AC adapter with the same output (AC or DC), voltage, polarity (which side is positive, and which is negative), and connector. If the speakers plugged into a USB port for power, your USB port may have turned itself off. In that case, reboot the computer to see if the USB port will turn back on.
    If none of this works, you have to buy new speakers.
    Apr 18, 2011 | HP JBL Platinum Computer Speakers
    No sound
    Make sure the speaker are plugged into the "audio out" ports. Black negative, red positive.
    If a dvd players or other system is hooked up, the speaker should hook into that unit, then the unit is hooked to the auxiliary port(s), or the proper ports for each unit: ex: cd/dvd should be plugged into vd/dvd; same for vcr, game system - auxiliary is for pretty much any unit not listed on the backing of the receive - however, some units will still work while plugged into the ports other than auxiliary.
    Make sure the receive is selected to the desired device.
    If you simply have the speakers plugged into the speaker ports, make sure the speaker themselves are still good - try hooking them up to another source such as a a dvd player equipped with surround sound or speaker adapters that will suffice your speaker wiring.
    Please let me know if you need further assistance.
    carsandcomps,
    Guru, Premium Expert @ Fixya.com
    Jun 28, 2010 | Onkyo TX-SR606 Receiver
    Humming sound coming out of speakers, nothing else. Cannnot adjust volume.
    What color port on the back of the system are you plugging your speaker in?
    The speakers should be plugged into the GREEN port...sounds like you have it plugged into the Mic/Pink
    Sep 12, 2009 | GE HO98010 Computer Speakers
    Speakers keep cutting out when they are plugged in and a high pitch squeal comes out of computer speaker
    How many Audio ports do you have in the back of your computer? Also, what Audio DRIVERS do you have installed in your computer? If you have REALTEK audio drivers, it SHOULD automatically recognize the speakers are being plugged in and change that ports usage over to speaker output, but not all drivers do this. It could simply be that you're plugging them into the wrong port audio port if you have 4 - 6 back there, as some motherboards do. Try different audio plugs and see if that works for you.
    Jul 06, 2009 | Logitech X-240 Computer Speakers
    HP speakers not working with Dell computer
    Your speakers are plugged into the wrong port? Most computers have at least a mic port and a speaker port, many also have front, rear, center, and subwoofer. Try playing a sound, then moving the connector to another port and trying again.
    Are your new speakers plugged in? Is the volume on them turned up?
    Dec 28, 2008 | E-Machines eMachines Desktop PC
    I moved, and now my speakers won't work
    check for the power button is on behind the woofer or speaker,if ur speakers does not have switch hten select the volume control optin and click the properties and check the sounds by clicking the speaker images in that window.if u have problem again,askme through fixya again.
    Aug 16, 2008 | AOpen MS-810 Computer Speakers
    Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
    159 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
