Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Looking to buy a ice basket for a cold spot.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Dec 27, 2010
What is the most reliable brand to buy?
Cuisinart holds the top spot but might not be the ones that you are looking for. Musso is the next best.
Jun 03, 2014 | Ice Cream Makers
2006 Jeep Commander - When I press the washer fluid button, washer fluid squirts out of the window frame on the driver's side front window. Why is that, and how do can I fix that problem?
what goes where/??? are all you saying is it lands in the wrong spot?
there are nozzle jets, they can be misaligned, clogged or partial clogged or cracked in half from ice up.
only looking at it finds the cause.
using cold rated, washer fluid for COLD ?
Jan 05, 2014 | 2007 Jeep Commander Rocky Mountain
Cracking sounds from top of refrigerator compartment of a 7 year old WSE6070WA
Had the problem in a similar fridge - the repair person said the noise was most likely the sound of ice build up being removed during defrost cycle and not to worry. Suggest you check the freezer temperature is not too cold and building up excess ice.
Oct 20, 2013 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
What is an English Picnic basket? I am looking to buy a picnic basket and am getting confused by the different products available.
An English picnic basket is usually a more traditional suitcase style picnic basket that comes with plates, cutlery etc.
Feb 27, 2013 | Home
Kitchenaid dishwasher model kudm24se the upper and lower baskets have rusty areas. Would like to replace with new baskets or a method of correcting or fixing the rust spots
That is not that hard to replace and you can easily buy the parts yourselfonline...
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Jun 02, 2011 | Dishwashers
Ice accumilation at bottom of upright freezer
i could be wrong, but, look along the bottom of the door to see if the seal is tight to the frame......if there is an air gap it is causing the floor to freeze the cold air....
Jun 04, 2010 | Woods Upright Freezer MU07W
My icemaker fills the tray but when the water shuts off it drips on the the ledge under the tray and ice builds up. Also now my ice cube tray seems to be leaking.Are parts available or does the entire unit...
My ice maker would not return to a level position after dumping out the ice. When the water turned on to refill the ice tray, it would run off the tilted ice tray and into the ice basket thus freezing all the ice cubes in the basket together. To remove the icemaker, there are two screws that hold the icemaker to the top of the freezer. Turn off the icemaker. Remove the left screw and loosen the right screw by removing the screw on the left. Slide the icemaker outward and it should come loose. Unplug the power connector from the icemaker to the freezer. The ice tray can be removed from the icemaker by gently pulling the tray to the right and the slot it goes into on the left side of the icemaker to the left. Once the tray is out of the assembly, inspect the round plastic shaft on the left side of the ice tray. Mine had two flat spots that were worn into the plastic from use. I used a dremel tool with a round barrel sanding disk at the tools lowest speed to remove the flat spots and decrease the overall diameter of the shaft which stopped the tray from sticking. Reassemble the ice tray in the icemaker.
Mar 10, 2010 | LG LSC26905TT Side by Side Refrigerator
My fridge wont make ice
you need to replace the ice maker .
Sep 12, 2009 | Refrigerators
KENMORE COLD SPOT REFRIGATOR/FREEZER,MODEL 106 52542101,WILL NOT EJECT ICE (SIDE BY SIDE)
hi thanks for the question if the ice cubes are formed in the tray nicely then you need a new ice maker if the whole ice tray is a smooth sheet of ice the freezer might not be cold enough empty out the ice manually ant try again &lower the freezer temp thanke the appliance doc
Sep 17, 2008 | Refrigerators
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
