Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Error reading ee8 - Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
  • 674 Answers
EE 8 is for a blower motor problem. It could be the sensor that checks the blower speed or it could be the blower not running. If the blower is running, the sensor is bad and you will need a new blower. If it isn't running then you may be able to fix it. Sometimes on the Laser 73, soot and carbon will build up on the exhaust fan blades. Remove the fresh air hose, that is the rubber on the back, and look for the fan blades. If you can see them turn the heater on and see if they are turning. If not turn the heater off and try to turn them with your finger. If you hear a noise like something rubbing when you turn it or feel some resistance, keep turning it until the noise stops or it frees up. Now turn it on again and see if the fan runs. If you don't have anywhere local to get parts I can get them for you. You can contact me at nitensheaterservice@earthlink.net I may also have a used blower that will work.
Posted on Nov 14, 2010
Understand the instructions for TS EE8
Following link has product manual that might match your timer:
Use + button at top of manual to enlarge print.
http://waterheatertimer.org/pdf/Argos-7day-Electronic-Timer-Manual-TS-EE8.pdf
Please add a comment and say if this manual matches your timer...fixya will send me email... and I will answer.
Include where you get confused.
You set current time first... that's the time that shows on your wristwatch right now.
You set day of the week... same day it is right now.
You set hour and minute.
The timer allows you to set up to 8 programs... you can set just 1 program or 2 or 3 etc.
Each program must have ON time
You set program 1 ON
Each program must have OFF time.
You set program 1 OFF
Each program must have a day or days of operation
So you might select monday ON at 10:10 am and OFF at 3:36 pm.
And other program for Tuesday ON at 10:45 and OFF at 4:00 pm.
When programming is finished, you set mode to auto for programs to run on the schedule you set.
Gene
Water Heater Timers Save Money
Feb 28, 2015 | Hardware & Accessories
ERROR EE8 ON SHARP 24AT
R-24AT is a UK model, and I'm in the US, so I can't give you detailed, specific part number info.
But in the Sharp commercial microwave manuals I have, it says the EE8 error means you have a shorted relay.
I would assume that's one of the cook relays on your controller board.
Here is the US, we have R-24GT and R-24GV models, and they may be similar enough that their service manual (here) will help you some.
But if you need further parts or service help, I would suggest contacting Sharp UK support here and here, respectively.
Good luck.
Dec 10, 2012 | Sharp Microwave Ovens
It saying ee8 blower
EE8 is for blower motor malfunction. It could be the motor, bearings or the speed sensor.First I would either remove the exhaust pipe from the back of the heater or take the front cover off of the heater and remove the black rubber boot from the fan (easiest). Then use a pencil or screwdriver or something similar to reach into the fan and try to turn it. Carbon builds up on the exhaust fan over time and may cause the fan to stick. Turning may break the carbon loose and free up the fan. If that doesn't get it, you are probably going to need a new blower motor.
Dec 30, 2010 | Rinnai Toyostove Direct Vent Heater:...
My laser 30,had error code EE8, but i was able to restart..my house is full of the smell of diesel, took off fan cover doesnt move when turned on but did after i turned it off...choking on fumes in alaska
EE8 is the code for combustion blower failure. I'm not sure which fan you checked. You can't see the combustion blower fan. It is inside the black plastic cover on the back side of the heater near the bottom. You can see the motor for it from inside the heater. The blower has a sensor to determine fan speed to control the amount of airflow to the burner. There could be a problem with the sensor. When you turn the heater on the first thing you should hear is the combustion blower start up and run. On the smaller heaters they are very quiet and sometimes hard to hear. Start the heater and see if the blower starts. If it doesn't remove the front cover and locate the blower motor so you can check the wires going to it. I have seen wires that mice have chewed off. Otherwise you may need a need blower motor. If it is running then the sensor is possibly bad and you would also need a new blower motor. Also make sure the exhaust pipe isn't blocked since you say the house smells like diesel. Let me know what you find. nitensheaterservice@earthlink.net
Nov 07, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo laser 73 error code EE8. What does that mean?
All error codes are explained on the lower left side of the heater. The EE8 message is for the combustion blower motor. If your stove has been unused for the summer you may get away with just spinning the blower wheel by hand to free it up. If this does not work you are in for a new motor or assembly. Either way you need to clean the blower and heat exchanger.
Tom
Aug 23, 2010 | Rinnai Toyostove Direct Vent Heater:...
My laser 73 heater has an error of ee8
Hello
An ee8 message refers to the combustion Blower motor
Unplug unit
Take off front cover
There is a rubber hose from blower case to the base of the unit
Take it off carefuly
Use your finger or a Pencil to try to move the intake fan
Resemble unit
If this doesn't work you may have to replace Blower motor or just clean it up.
If you can't figure it out gimmie a call Total Toyo (907) 488-9179
Dec 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyostove l73
Try cleaning the fan blades, etc. Does the blower stop after a while and not start again? If there is no ignite at all, could you need to clean your stove. Especially the heat pot?
May 01, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove l73
Remove the front panel. Look for the "L" shaped rubber hose near the bottom that goes to the metal blower box. Remove the end of the hose at the blower box. Inside the opening you can see the blower fan blades. Using a pencil or other slim object, gently rotate the fan while the power is on. The blower should start on its own after you get it going. Let the blower run a few minutes to loosen itself up. Replace the hose and front panel. The blower fan tends to stick if the unit is turned off for long periods of time, such as from Spring until Fall. My Laser 73 blower sticks almost every year and I cure the problem doing the above procedure. HTH
May 01, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
125 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
