Question about Asko W6021 Front Load Washer
Will not complete it's cycle, comes up with error code F4
  • 1,998 Answers
F4 would be a thermistor problemcheck to make sure the thermistor is not stuck open if it is replace it also check the wiring going to the thermistor please message me back if you have any further questions and please remember to rank how this opinion has helped in your appliance situation
Thanks again
Rick
Posted on Nov 30, 2010
Getting error E1 checked all as per manual but still getting it
Whirlpool dishwasher F4 F8 FA error code ... - YouTube
? 1:57
www.youtube.com/watch?v=RfeFTdSdNYQ
May 27, 2012 - Uploaded by ukanfixit Although the Whirlpool dishwasher F4 error code is "not draining" it is actually a .... switch situated? my Whirlpool showsE1 and F8 error codes.
Aug 24, 2015 | Whirlpool Dishwashers
Fisher and Paykel Dishdrawer-DS605SS F4 fault code
No temperature increase has been recorded when the element is on.
The element is not connected.
The element has gone open circuit.
Temperature sensor or electronics ADC has failed.
Oct 04, 2012 | Fisher and Paykel DishDrawer DS605FDSM...
2LYMPAIA - F4
Hello
If you have F4 and the sump is full of water, there's a good chance the drain pump is being jammed by a broken bit of glass or pottery. However, if the appliance is empty of water and F4 error code is flashing, where do you go from there?
The electronic control (module pcb) does a self check of the components, during a drain cycle the programme allows a time parameter for the appliance to empty away the water. How does the pcb know the water has gone? Simply by testing a pressure switch for continuity.
The pressure switch is an on or off switch, when the appliance is empty the internal contacts are "made" (on) when the appliance is full of water the switch is "broken" (off).
The sensing grid of the pressure switch is exposed to the dishwasher wash water and can over a period of time get clogged with crud ( a mixture of food waste and detergent and limescale), eventually this crud stops the switch from being in the correct attitude during the self tests. The electronics notes the on or off and determines that the appiiance has not drained and gives error code F4.
If you have F4 error code it could be the pressure switch needs cleaning or replacing.
On the self test about 4 mins is allowed for the appliance to empty the water away.
Aug 03, 2011 | Whirlpool Dishwashers
F4 code comes up on some cycles
Hi
F4 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 27, 2011 | Kitchen Ranges
I have an Asco D3350 dishwasher. When the cycle starts the machine fills with water and when there appears to be the right amount of water in the machine an error code F4 shows on the panel. 3 clicks can...
There could be a variety of problems most common clean filter sensor water level faulty replace or pump not working how old and how often do you use it?
Aug 29, 2017 | Asko 24 in. D3350 Dishwasher
F4 error fisher & paykel nautilus dishwasher sometimes this error comes up and it seems to occur about 10 minutes from the end of the cycle. it doesn't happen all the time. the user guide does not...
F4 is a heating error- dishwasher has not reached temperature in allocated time. If intermittent fault, problem is usually with electronic board, which has temperature sensor attached. Sometimes the wiring to the control board burns out and can give intermittent false readings causing F4 error. Disconnect from power, remove front panel (4 screws down each side). You can now see wiring going to control board- check for burnt wires. Also check temperature sensor (small square with two purple wires) is stuck to inner door panel- if this is not stuck to inner panel, temperature sensor will not work properly. If in any doubt, call in the experts!!
Mar 08, 2010 | Fisher Dishwashers
Whirlpool Dishwasher machine (Mod. ADG 8970/1) wont start. Water is taken in. After several attempts to start an error code "F4" appeared.
Hello Sir,
This error code, " F4 " comes only when the waste outlet is totally clogged with waste and blocked. Try to dismantle the machine and locate the Waste outlet pipe and thoroughly clean it. This will reset the error which is caused.
Thank you Sir,
Have a nice day.
Jan 13, 2010 | Whirlpool WFW8300SW
F4 error message. Cleaned out screen at water inlet and still get error message.
There may be excess water in the water reservoir. Empty the washer Turn it off at the mains, and unplug it, then put some old towels on the floor, tip the washer forward until the excess water comes out, Reconnect and try again. Hope this helps it works for me and saves ££££'s in repair fees
Oct 04, 2009 | Asko W6461W 24" Front Load Washer w/ Delay...
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
Asko W6021 Front Load Washer Logo
295 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
