Question about Texas Instruments TI-83 Plus Calculator
How do you enter Log 1/3 in the T1-83 plus? 3
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
LOG 1 / 3 ENTER
Posted on Nov 14, 2010
Logbase16xtopower5=logbase64 125-logbase4rootx soveforx
Type solve(log(x^5,16)-log(125,64)+log(x^(1/2),4),x,0.5
Its equation with guess 0,5. Then press enter and you will give result
x=5^(1/3)=1.70997
Or, you can use equation solver with eqn=0(MATH, then B option)
See captured images below
Feb 26, 2013 | Texas Instruments TI-83 Plus Calculator
Log(x+2)+log(x+3)=7-x How to intersect with TI-84
Press Y=
On the Y1 line enter the expression LOG(X+2)+LOG(X+3) by pressing
LOG ALPHA [X] ) + LOG ALPHA [X] + 3 )
On the Y2 line enter the expression 7-X by pressing
7 - ALPHA [X]
Press GRAPH to see the graph. To see where they intersect, press 2ND [CALC] 5. See "First curve?" in the lower left. Use up/down-arrow to select one of the two curves and press ENTER. See "Second curve?" in the lower left. Use up/down-arrow to select the other curve and press ENTER. See "Guess?" in the lower left. Press ENTER. The calculator will show the coordinates of the intersection.
Sep 19, 2012 | Texas Instruments TI-84 Plus Calculator
How to find logarithm
For the common logarithm use the LOG key to the left of the 7 key. For the natural logarithm use the LN key to the left of the 4 key.
In either case press the key and then enter the value or expression whose log you want.
For example, to calculate the common log of 3, press
LOG 3 ENTER
Mar 28, 2012 | Texas Instruments TI-83 Plus Calculator
If i needed to enter log 5 to the base 3 into my calculator what buttons would i push?
You can calculate the log of x to any base b by calculating log(x)/log(b) or ln(x)/ln(b). So, to calculate log 5 to the base 3, press
LOG 5 ) / LOG 3 ENTER
or
LN 5 ) / LN 3 ENTER
Jan 25, 2011 | Texas Instruments TI-83 Plus Calculator
How can find logarith of a value from Texas Instruments BA 2 plus
The natural log is the LN key, located just to the left of the 7 key.
To calculate the common log, use the relationship log(x) = ln(x)/ln(10).
To calculate the natural log of 3, press 3 LN
To calculate the common log of 3, press 3 LN / 1 0 LN =
Jun 11, 2010 | Texas Instruments BA II PLUS Financial...
I have data entered in L1 and L3. And I want to take the log of L3 in L2. But after I do that it gives me an error. How can I fix this.
If the data in your L3 list contains only positive numbers there is no reason why you should not be able to calculate the log of the list and store that in L2.
  1. You open the list editor, [STAT][1:Edit]
  2. Use arrows to position the cursor on an element of L2.
  3. Use UpArrow to highlight the L2 heading (at the top of the list) and press ENTER.
  4. The data entry line will show L2= ..
  5. Erase anything that may be on the L2 entry line and type in
  6. [LOG] [2nd] [3] (L3) to enter the L3 identifier inside the log (
  7. Close the right parenthesis. Screen shows L2= log(L3)
  8. Press [ENTER]
  9. The L2 list will be populated with the logs of the elements of L3.
Hope it helps
Dec 08, 2009 | Texas Instruments TI-83 Plus Calculator
How can I use the Log function on my calculator?
Hi ;
for log base 10 use the the "log" key
example :
log(2) + log(3) = log(6)
enter 2 press the log key you will get 0.30102999 press the '+" key than 3 log you should get 0.47712125 for it Press the "=" or enter and you should get 0.778151250 for a answer than press inv or 2nd log and you should get 6 for a answer
and that all there is to it
Oct 07, 2009 | Texas Instruments BA-II Plus Calculator
How to calculate the antilog please
The antilog is the inverse of the logarithm. Not too surprisingly, it's invoked as the 2ND shift of the appropriate log key.
For the common antilog, use the 10^x key (2ND LOG). For example, 2ND LOG 3 ENTER gives 1000 as the common antilog of 3.
For the natural antilog, use the e^x key (2ND LN). For example, 2ND LN 3 ENTER gives 20.08553692 as the natural antilog of 3.
Sep 27, 2009 | Texas Instruments TI-83 Plus Calculator
Message Light Remains on
reset your system--Try the following steps--1) Feature 983, Log 120000, mBox, Change, enter mBox #(i.e.-24), hold Reset....
this changes current password to default password 0000 for mBox #(i.e.-24).
Next....
2)Feature 981, Other (do not enter password, instead go to "Log"), now enter the mBox # (i.e.-24) plus default password 0000 (i.e.-240000).
Next....
3) Follow voice prompt to change password (cannot start with #0), Re-enter new password (i.e.-246810), Say name clearly, Play name back, if satisfied then OK.
Next....
4)When accessing mBox, Feature 981, Other (shows "Log"), enter mBox # plus new password (i.e.-24246810), this is how you will now access your mBox.
Thanks
Nov 06, 2008 | NorStar T7316E Corded Phone
Texas Instruments TI-83 Plus Calculator Logo
26 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
