Question about Poulan Pro Chain Saw 46cc 20"
What is the fuel mixture ratio for the Poulan 260?
  • 7,733 Answers
A 7.5 oz bottle on a 1 gallon of gasoline.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
Need gas and oil mixture ratio
The gas oil ratio on all Poulan models is 40:1.
First, I recommend a synthetic oil mix if you can find it and also recommend running a 93 octane gasoline.
Second, I would mix no more than 1 gallon at a time, unless you are doing a lot of cutting.
Gas/Oil mixtures do not last that long. I don't give them more than a month, and generally try to run any mixture within 2 weeks.
Think about it, gas cam gum up on it's own when let sitting for too long. Imagine what it can do with oil mixed in it.
Good luck with your saw, and be careful when cutting.
Jul 07, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan chainsaw,the cilinder gets oil,so the sparkplug gets wet and it will not start
Probably have a Carb. problem. Take the carb apart and clean. The Needle Valve sounds like it is sticking.
Jan 18, 2013 | Poulan Garden
POULAN 25CC NOT STARTING AND BEFORE THIS HAPPEND IT WAS OVER HEATING
overheating on a 2 stroke is usually caused by lack of oil mixture. try draining all the fuel and re mixing the ratioo to a 40 to 1 ratio. if no smoke then richen the mixture till it slightly smokes. i.e. 50:1 ratio
Aug 30, 2012 | Poulan WeedEater Hedge Trimmer 25cc Engine
Fuel/oil mixture
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
From Poulan website:
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas. If you have other brands of equipment that require different fuel/oil ratios and you don't want to mix separate fuel cans, you should use the lowest numerical ratio. For example, if you have products requiring 40:1, 50:1, and 32:1 ratios you should use the 32:1 ratio for all products. This may cause slight smoke increase in the exhaust in the 40:1 and 50:1 products due to more oil in the fuel, but it won't damage either of the engines.
Aug 15, 2011 | Poulan Garden
Oil mixture wild thing
The oil mixture is 50-1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the gas/oil mixture for the poulan wild thing chain saw please?
Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sep 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I bought a reconditioned Poulan pro PP4629AVX and I can't find a manual for it. What is the oil to gas mixture? Thanks Steve
Sep 25, 2010 | Poulan Pro Chain Saw 46cc 20"
What is the fuel to oil mixture ratio for my gas featherlight weedeater?
That oil/fuel mixture would be 50-1 or 2.8 ounces per gallon...
heatman101
Sep 08, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the fuel mixture for my new Poulan Pro 18'' chainsaw? It looks like 32:1 but not sure.Thanks! Don
If you use a mixture of 50:1 you can't go wrong.This is the industry standard and can be acheived by following the mixture guide lines one the bottle of oil.32:1 will make your saw smoke to the point of being almost unbearable and will foul the plug,so 50:1 is the mix your looking for.
Dec 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need fuel/oil mixture ratio for a poulan 3400 chain saw. Much obliged!!!!
Hi, fuel/oil mixture is 40:1 for Poulan. Hope this helps.
Mar 01, 2009 | Poulan Garden
Poulan Pro Chain Saw 46cc 20" Logo
74 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
