Question about GE WSXH208A Front Load Washer
How do I check the drain filter on GE spacesaver WSXH208A washer
  • 116 Answers
SOURCE: How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Posted on Aug 02, 2008
  • 7 Answers
SOURCE: Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Posted on Oct 26, 2008
drsn
  • 42 Answers
SOURCE: ERROR NOT DRAINING
the filter is located right after you open the drain cover on the bottom of the washer it's a hard plastic filter, if it is not clogged with any debris, then it sounds like your pump motor is bad, maybe need to replace it. lg's are very sensitive........., find out the part number and search it through google. if not email me and i could set sumthin up for you.
drsn777@hotmail.com
dave
Posted on Dec 12, 2008
SOURCE: GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Posted on Jan 16, 2010
  • 478 Answers
SOURCE: GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Posted on Jan 20, 2010
Water won't drain on the wash or rinse cycle
Hi.
If the machine does not drain the parts to be tested are rain system, motor and control board must also be tested. If machine is a top loader testing will start from lid switch. The first action will consist in checking the drain hose at the back and checking the drain filter accessible from lower front side of your GE WSXH208A.
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 14, 2011 | GE WSXH208A Front Load Washer
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
Apr 20, 2010 | GE WSXH208A Front Load Washer
The tub on my GE WSXH208A Front Loader won't drain. Is there a filter that should be cleaned? If so, just where is it and how do I access it? (A precise location is appreciated, as my washer is installed...
Drop down the drain hose to floor level with a bucket this allows you to empty machine...the filter is located r/hand or left hand of machine bottom you undo to clean , good luck.
Apr 19, 2010 | GE WSXH208A Front Load Washer
My GE washer doesn't drain water.Even after the spin cycle is over, the washer is full of water. Please help.
Either the drain is blocked or your filter is full. Find out where the filter is, usually in front below door or behind panel in front. Clean this out & refit. Plug off the mains first. Check machine filter first & then snake out your drain.
Feb 10, 2010 | GE WSXH208A Front Load Washer
I have a ge front load washer that won't drain i have stuck a coat hanger through the drain hose it doesn't seem to be clogged up.
take front cover off at bottom. there is a fiter that unscrews. be prepared for water to come out. clean filter and replace, good luck.
Jan 29, 2010 | GE WSXH208A Front Load Washer
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
The front load washing machine will not drain
Look in the rear for a small door that holds the pump filter.
Drain the washer with the small tube 1st.
Nov 17, 2009 | GE WSXH208A Front Load Washer
GE washer WSXH208AWW does not spin and drain out.
my GE washer does not spin out all the time on final spin
Sep 08, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
