Question about Electronics - Others
My 1987 elite travel trailer duotherm 90125-001 heater is blowing fuse when thermostat is set to 70 degrees and it is 35 degrees outside. all internal wires are intact contacts seem clean and no mouse knawings. please help kindly
3 Suggested Answers
kcmetal9901
  • 102 Answers
SOURCE: rewiring a travel trailer
You need to first decide what all you want inside as far as electrical features such as lights, outlets, fridge, stove , tv etc.. decide their locations then calculate the load it will pull and design the electrical circuits. Sound tough but it's not that bad
Posted on Dec 04, 2008
  • 68 Answers
SOURCE: electrical wiring travel trailer-converter
I would for sure get my money back. What year and make is your coach? Are your appliances dometic/ac and fridge? The dealer made a serious error and obviously did not know what they were doing. Another question what kind of converter is it? I can help with enough info. If you live close enough I can give you a service call and give a better opinion.
send me an e-mail and I will give my phone number
rvtech@myway.com
Posted on Mar 22, 2009
Service engine soon light on 171 174 surging idle
Hi try this video it may help you find the fault it covers the codes on 4.0l engine. Ford Explorer 4 0L SOHC Rough Idle P0171 P0174 Lean Codes
Jun 23, 2017 | 2000 Ford Expedition
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Jan 28, 2014 | Open Range 2011 Mesa Ridge MR243F
Need to know how to turn the temp up on my gas hot water heater noritz tankless m n-o631-s od
If you are in a cold area, having it outside isn't helping you. Tank less heaters only raise the water temperature 40 - 70 degrees. If you had 50 degree water coming in and it is 35 degrees outside, you will be lucky to get 90 degree water.
Nov 25, 2012 | Dishwashers
I have a Honeywell RTH230 thermostat. Ive read the manual top to bottom and have set the temperature to 70 degrees and followed all the directions. But my home is still almost 85 degrees, and even hotter...
i am assuming the unit is coming on and all... there could be an issue with the refrigerant in the system such as a leak.. need to make sure the indoor fan is coming on and also that the outside unit is coming on..there are 2 copper lines at outside unit that are refrigerant lines the larger one should be cool and the small line should be warm.. there also should be hot air blowing out of the outside unit... if this is not happening you have a problem with either the freon has leaked or the compressor may not be coming on inside the outside unit \
Jul 20, 2011 | Honeywell Programmable Thermostat Heater
My heat pump runs most all the time i will set the thermostat on 70 when it gets to 70 it still runs I can kick it back down to 69 and it kicks off.I can put it on 72 when it gets to 72 it still runs, I...
therostats have what is known as off-set deflection , or simplely put the plus or minus of the temp range which the heat turns on or off this setting is adjustable on many thermostats i usually set for 3 degrees if it is set for 1 or 2 it will run all the time refer to owners manual to see how to set this in program
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
Cant get the settings to go past 70
Set the time and day and make sure you are in the "F" range.
Dec 30, 2009 | Honeywell Electronic Programmable...
My Honeywell thermostat does not heat the house to the selected temperature. It will come on but not long enough to heat the house to the temp I selected.
Verify that you have heat coming from the vents.
Also do you use a heat pump system with electric emergency heat?
It may be that if it is to cold outside that the heat pump can not handle the load due to the cold outside and you will need to turn on the emergency heat.
Keep me posted.
FlaTech.
Thank you for using FixYa!
Nov 17, 2009 | Honeywell Heating & Cooling
Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Feb 10, 2009 | Dometic Rooftop RV Air Conditioner
Heater turns on, but intermittenly
Turn the power to the furnace off and then back on and see if it resets. If not you may have a bad ignitor or dirty sensor.
Hope this helps.
Matt
Jan 05, 2009 | Fahrenheat FBE15002 Baseboard Heater
Electronics - Others Logo
143 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
