Question about Honeywell L4064B2236 Fan/Limit Control Heater
What should the inside dial be set at? there are three positions.
    Genius:
  • 1,015 Answers
For most applications I would set fan on at 140 Degrees, fan off at 90 degrees and fan limit should be either factory at 190-210 or I would set it at 190. When you are setting set points on dial you should hold outside of dial so it can't move and set inner indicators where you desire. If you want you can vary by a few degrees but I would not go below 90 on fan off or above 140 on fan on. Possibly 100 and 120. Hope this helps you. Thanks
Posted on Nov 14, 2010
I just bought a police kickers timepieces watch i dont know how to set the day i've tried hundreds of time but its not working can some one help me !!
Since you have stated ABSOLUTELY nothing about provinance... model, year... owners manual POLICE being a pretty decent watch from the UK (I'm going to skip right on past the AUTHENTIC notion... Chronograph (shown).
If your your watch is a REGULAR knock-off (replicant)... t has the miyota movement...
A highly precise and reliable motor
in it's own right.
(sets very much like the high end valjoux cousins)
It is a crown-set... typically a three position stem set.
Force nothing... !!
Some GENTLY unscrew the crown... others will pull out
to set: 1, TIMW 2, DATE... THREE (back to normal -closed).
In the closed position
The stop/start butons do precisely that on those SUB-DIALS.
In the SET positions the start/reset buttons are used to ZERO those sub-dials (press & hold... then individual clicks will move each hand to zero).
Hope this helps!
http://www.bing.com/search?q=watch%20valjoux%20quartz%20movement&qs=n&form=QBRE&pq=watch%20valjoux&sc=0-13&sp=-1&sk=&cvid=607E5483C971481BBCFF824956E6A0D7
police quartz movement Bing images
Jun 25, 2016 | Police Watches
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 | Watches
How do I set the DAY of the week on my new watch, Akribos XXIV Women's AK560RD Quartz Multi-Function Genuine Leather Watch ?
There are three positions for the crown. You can pull it out all the way to third position and turn up or down Each of those turn one sub-dial. then you can push back one position and again up or down. Each of those turn another sub-dial hand.
Sep 17, 2015 | Watches
How do I set the dials on husqvarna viking 6000 sewing machine
The "dial" in the back is for decorative stitches which require a "programmer" to be inserted with the stitch formation you want to form. For a straight stitch no cam is required in the back of the machine. The three dials on the front:
Upper Left: Stitch selector
Upper Right: Stitch lenght
Lower: Stitch width
Using the upper left dial select the straight stitch picture
Using the upper right, choose your stitch lenght
Using the lower, choose your needle position, left/center/right
Dec 13, 2014 | Husqvarna Sewing Machines
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
How do I change the aperature in the manual mode. As I change the shutter speed using the top dial, that works fine however, I'm having trouble using the dial on the back to change the aperature. What...
Make sure that the power switch is in the correct position.
It actually has three positions:
  • Off
  • On (with quick control dial disabled!)
  • Third position (quick control dial enabled!)
So, when the power switch is in the middle position (ON), the rear control dial is disabled in order to save you from inadvertently changing the setting, when you are wearing the camera on a neck strap.
So be sure to put it in the third position.
Mar 17, 2010 | Canon EOS 40D Digital Camera
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
How do i set the time on an Invicta Lupah mens watch with three subdials
The Lupah has a chronograph so dont worry about the sub dials while your setting the time. Pull the crown out to the first position and set the time. For the date pull out to the second position and set the date.
To set the chronograph sweep arm pull the crown out and press and hold down the start button. The sweep arm will move into position. Stop it on the 12:00 or 0 position.
Jun 09, 2009 | Invicta Dragon Lupah 2093 Wrist Watch
Honeywell L4064B2236 Fan/Limit Control Heater Logo
48 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
