Question about Samsung HCN529W 52" Rear Projection Television
Dead power led blinks 9 times
Samsung HCN529w dead, chirps when power pressed, led blinks 9 times.
Any ideas where to start, or where to obtain a service manual.
Thanks
  • 1 more comment
  • Tom Fillmore
    Tom Fillmore Apr 18, 2009
    I have the same problem with my hcn529w. When you turn the tv on, I wouldn't say it chirps, but more like when you get a 1up while playing Mario on Nintendo. Then the red light on the front blinks 9 times and the screen stays black. When you turn the tv off you get a sound similar to the Mario sound, except this note goes high to low.
    Where is the horizontal Output transistor located? There's a couple of transistors around the flyback transformer.
  • Tom Fillmore
    Tom Fillmore May 08, 2009
    I replaced Q404 (j6920) and it did not fix anything. Can anyone else help me out?
  • Tom Fillmore
    Tom Fillmore May 09, 2009
    I meant Q431 not Q404.
    Scholar:
  • 62 Answers
I bought a replacement deflection board (BP94-00501B) from encompass parts for ~$120 and that fixed the problem. Hopefully I can figure out what components went bad.
Posted on Sep 25, 2009
  • Samsung Master
  • 5,138 Answers
Hori output Tansistor.
Posted on Dec 30, 2008
TV DEAD RED LIGHT BLINKS 9 TIMES
What is the brand name to your TV? These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 13, 2015 | Televison & Video
Bush led 26916hd
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 13, 2013 | Bush LCD/ Plasma/ LED Pivot Mount in Black
Reset hp 4500
Canon ip 4500 printer reset proses:
1. Condition Canon IP4500 printer is dead,
2. Press and hold the resume button on Canon IP4500,
3. Press and hold the power button on Canon IP4500,
4. Release the resume button on Canon IP4500,
5. Press the resume button 2 times,
6. Release the power button,
7. Green Led on Canon IP4500 will blink,
8. Wait until the green led is not blinking,
9. Press the resume button 4 times,
10. turn off the printer
Thank you
Jun 01, 2013 | Office Equipment & Supplies
SAMSUNG HCN4727WX XAA CH P55A-N REV.1
If total dead follow the money or in this case the voltage--start with AC into the power supply--its likely on input side of power supply as if standby was working you would see or hear something........at the bridge rectifier it will of course change to DC but that is just before the AC goes unswitched to the standby supply which has to be ON 7/24.
May 30, 2012 | Samsung HCN529W 52" Rear Projection...
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Power to unit but will not turn on.
You need to replace your STKs Both of them they are convergence ICs and do control startup. they are big black ics STK392-040 also ck (2) resistors-- RZ142 3.9ohms RZ145 3.9ohms .To order Parts Call Electronix 1-800-223-3205.
Dec 30, 2008 | Samsung HCN529W 52" Rear Projection...
Blinks twice pause blinks 4 times
SYMPTOMS
Dead or Shutdown symptoms.
RESOLUTION
Dead symptom reported to be caused by the following:
1. Dead.
Found Q601 & Q602 shorted, R615 open, and IC600 on the A Board were the cause of the symptom.
2. Dead.
Found D614, Zener diode, on B+ line was shorted.
3. Set shutdown and the standby LED blinks 3 then 5 times.
Found 200v line was low. Disconnected CN706 on the C Board and found 200v now
present on CN706/pin 7.
Found: IC702 (C board) shorted the 200 volt line.
HQ Comments: C541 on the A Board could become defective if the 200v line is shorted since
the polarity on the capacitor will become reversed. R553 fuse resistor could also be opened
on the A Board.
4. Error code of 4 blinks .
Dead set press power button you hear the relay and you see red led flash 3 times and stops? Has no HV or other action. Tech removed the back as no 200 volt supply, did unplug CN706 and now has 200volts. Tech did remove the IC702 and same it comes up so needs this IC.
5. Dead. 5 blinks then 3 blinks. Found shorted Damper diode D504. Q502 has a built in damper, as well.
6. The TV does not turn On and the LED flashers 9 times.
Found one side of R610 open on the Base of Q690 on the A board.
7. Dead, 9 flashes, Q606
Would not start when cold, has stand by 5 but relay never energize.
No response from front panel or remote controls.
9 blinks is not in service manual.
Found Q606 (Zero Det.), on the A Board, had no soldered on the collector
of the transistor causing an intermittent connection.
Soldered the collector of Q606 and set returned to operation.
HQ Comments: Also refer to E30968554.
8. Dead. 5 blinks or 3 blinks
Found on the A Board D611 in the Power Supply open, and Hor. Output Q502 shorted.
9. Found Power Supply components D611 shorted causing Q600, Q601, and R615
to fail on the A Board.
10. No picture or sound. Standby flashes.
Found Q512 (Pin Out) shorted. on the A Board.
11. Dead. No sound or picture.
Found the FBT and Q502 were shorted, and R615 open on the A Board.
12. Dead
No power, Stand by light flashes 4 times.
Found T604 and IC601, replaced.
Found D611 on the A Board was the cause of the symptom.
13. Dead.
Found D534 shorted on the A Board.
14. Shutdown 4 Blinks.
Replacing R595, OCP Latch Q532 on the A Board, fixed the set.
PN 1-247-891-00, 330K 1/4 watt.
15. Unit shuts down after 15 mins.
Immediate shutdown - sometimes it give a 3 blink, sometimes nothing.
Found R595 (330K) was open located in the Q532 OCP Latch circuit.
R595 P/N 124789100 330k 1/4w
16. Won't power up. LED Blinks 4 times, B+ is very low
B+ is at 49V, +15/-15 only coming up to about 1 volt.
Wth Hor Out disconnected B+ only comes up to 50v.
17. Intermittently does not turn on
Found a intermittent C633 on pin # 3 of IC600.
C663 P/N 113647911 Film cap .001uf 100v
Billy
If you need the service manual contact me at:billyjones@fletchersite.com
Jan 27, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung HCN529W 52" Rear Projection Television Logo
361 people viewed this question
Henry  Thomas
Henry Thomas
