Question about HP Photosmart C6100 All-In-One Printer
Can't send or recive Faxes
I have not been able to send or receive faxes lately. I called my fax line to see if it was operational, and after 3 rings I got the usual FAX SOUND, so that appears to be working fine.
Yesterday we shut down the HP unit and left the power off for about 5 minutes. I then turned it back on and rebooted the computer. Scanning & printing functions work properly, but still no fax operation.
Please help, thanks.
John Clasen
jrc411@verizon.net
  • jrc411 Jun 18, 2008
    The fix sent by everyone was the same, "reset the unit to its' default settings"
    You all assumed that I know how to do this :-)
    Please send instructions, and I will follow through.
    Thanx, John
  • 54 Answers
Pls reatart ur machine if problem untill solves set it to default settings if till u have prblm then ur fax driver has been corrupted call to hp customer care.they will give u new software.
Posted on Jun 18, 2008
    Sergeant:
  • 243 Answers
Choose the correct fax setup for your home or office
To fax successfully, you need to know what types of equipment and services (if any)
share the same phone line with the HP All-in-One. This is important because you might
need to connect some of your existing office equipment directly to the HP All-in-One, and
you might also need to change some fax settings before you can fax successfully.
To determine the best way to set up the HP All-in-One in your home or office, first read
through the questions in this section and record your answers. Next, refer to the table in
the following section and choose the recommended setup case based on your answers.
Make sure to read and answer the following questions in the order they are presented.
1. Do you have a digital subscriber line (DSL) service through your telephone
company? (DSL might be called ADSL in your country/region.)
❑ Yes, I have DSL.
❑ No.
If you answered Yes, proceed directly to Case B: Set up the HP All-in-One with
DSL. You do not need to continue answering questions.
If you answered No, please continue answering questions.
2. Do you have a private branch exchange (PBX) phone system or an integrated
services digital network (ISDN) system?
If you answered Yes, proceed directly to Case C: Set up the HP All-in-One with a
PBX phone system or an ISDN line. You do not need to continue answering
questions.
3. Do you subscribe to a distinctive ring service through your telephone company that
provides multiple phone numbers with different ring patterns?
❑ Yes, I have distinctive ring.
❑ No.
If you answered Yes, proceed directly to Case D: Fax with a distinctive ring service
on the same line. You do not need to continue answering questions.
Are you unsure if you have distinctive ring? Many phone companies offer a
distinctive ring feature that allows you to have several phone numbers on one phone
line.
When you subscribe to this service, each phone number will have a different ring
pattern. For example, you can have single, double, and triple rings for the different
numbers. You might assign one phone number with a single ring to your voice calls,
Countries/regions with a parallel-type phone system (continued)
Basics Guide 35
Fax setup
and another phone number with double rings to your fax calls. This allows you to tell
the difference between voice and fax calls when the phone rings.
4. Do you receive voice calls at the same phone number you will use for fax calls on
the HP All-in-One?
❑ Yes, I receive voice calls.
❑ No.
Please continue answering questions.
5. Do you have a computer dial-up modem on the same phone line as the HP All-in-
One?
❑ Yes, I have a computer dial-up modem.
❑ No.
Are you unsure if you use a computer dial-up modem? If you answer Yes to any of
the following questions, you are using a computer dial-up modem:
– Do you send and receive faxes directly to and from your computer software
applications through a dial-up connection?
– Do you send and receive e-mail messages on your computer through a dial-up
connection?
– Do you access the Internet from your computer through a dial-up connection?
6. Do you have an answering machine that answers voice calls at the same phone
number you will use for fax calls on the HP All-in-One?
❑ Yes, I have an answering machine.
❑ No.
7. Do you subscribe to a voice mail service through your telephone company at the
same phone number you will use for fax calls on the HP All-in-One?
❑ Yes, I have a voice mail service.
❑ No.
After you have completed answering the questions, proceed to the next section to
select your fax setup case.
Select your fax setup case
Now that you have answered all the questions about the equipment and services that
share the phone line with the HP All-in-One, you are ready to choose the best setup case
for your home or office.
From the first column in the following table, choose the combination of equipment and
services applicable to your home or office setting. Then look up the appropriate setup
case in the second or third column based on your phone system. Step-by-step
instructions are included for each case in the sections that follow.
If you have answered all the questions in the previous section and have none of the
described equipment or services, choose "None" from the first column in the table.
Note If your home or office setup is not described in this section, set up the
HP All-in-One as you would a regular analog phone. Make sure you use the phone
cord supplied in the box to connect one end to your telephone wall jack and the
other end to the port labeled 1-LINE on the back of the HP All-in-One. If you use
another phone cord, you might experience problems sending and receiving faxes.
Chapter 3
36 HP Photosmart C6100 All-in-One series
Fax setup
Other equipment/
services sharing your fax
line
Recommended fax setup
for parallel-type phone
systems
for serial-type phone
systems
None
(You answered No to all
questions.)
Case A: Separate fax line
(no voice calls received)
DSL service
(You answered Yes to
question 1 only.)
Case B: Set up the HP Allin-
One with DSL
One with DSL
PBX or ISDN system
question 2 only.)
Case C: Set up the HP Allin-
One with a PBX phone
Distinctive ring service
question 3 only.)
Case D: Fax with a
distinctive ring service on
the same line
Case D: Fax with a
the same line
Voice calls
question 4 only.)
Case E: Shared voice/fax
line
line
Voice calls and voice mail
service
questions 4 and 7 only.)
Case F: Shared voice/fax
line with voice mail
Computer dial-up modem
question 5 only.)
Case G: Fax line shared
with computer dial-up
modem (no voice calls
received)
Not applicable.
Voice calls and computer
dial-up modem
questions 4 and 5 only.)
Case H: Shared voice/fax
line with computer dial-up
modem
Not applicable.
Voice calls and answering
machine
questions 4 and 6 only.)
Case I: Shared voice/fax
line with answering
machine
Not applicable.
Basics Guide 37
Fax setup
Other equipment/
line
systems
systems
Voice calls, computer dialup
modem, and answering
machine
questions 4, 5, and 6 only.)
Case J: Shared voice/fax
modem and answering
machine
Not applicable.
modem, and voice mail
service
questions 4, 5, and 7 only.)
Case K: Shared voice/fax
modem and voice mail
Not applicable.
For additional fax setup information, in specific countries/regions, see the Fax
Configuration Web site listed below.
Try these steps first and if you still need assistance please ask.
thanks,
nate
    Genius:
  • 2,028 Answers
Try resetting the machine to it's defualt settings.
Canon mf5770 not receiving faxes
Most fax machines allow you to set the number of times the phone rings before it automatically answers the phone. So if you phone goes to voice mail after 4 rings and the fax machine is set to start the fax after the 5th ring it will never receive the faxes because the call went to voice mail. Good Luck
Dec 05, 2013 | Office Equipment & Supplies
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
When recived fax it half the size of A4 paper.but when i send fax ok.
If you are able to make copies ok, I mean you get a full page of the copy, but when receiving a fax you're getting only half a page that could be a problem with the line. First, let's make sure you have all the settings right. Make sure that you have the phone cable plugged in to the port where it says line at the back of the fax machine with the other end going directly to the wall jack. (If that is a digital phone line that you have, the more that you'll have difficulty in receiving faxes, because fax machines are designed to work on analog phone lines only) Also, try turning Off your Error Correction Mode (could be found either on Basic or Advanced fax settings) If you have an answering machine on the same line with the fax, set it to 2 rings lower than the fax machine's number of rings, that way when a call comes in, the answering machine picks it up first, if a fax tone is heard, fax machine picks up. It is not recommended if you have a voicemail on the same line with the fax, if you do, it's either request to turn it off from the phone company or request for a distinctive ring, then set the distinctive ring by accessing your Advanced fax settings.
If you have all those notes above set, and you're still not being able to receive your faxes, let's check on your line. Try to plug the fax machine to a different wall jack and have someone send you a fax, if you receive the fax, then the wall jack where your fax was previously plugged in to must be faulty. Call your phone service provider for the issue.
If you're still having the same issue with the fax, with it plugged in on a diff wall jack, call the customer care hotline for your product.
Apr 26, 2011 | Office Equipment & Supplies
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
Cannot recieve faxes but i can send them
It is set on "manual receive" rather then "automatic receive"....check your "reception mode" settings and set it properly
Jul 16, 2009 | Pitney Bowes 9920 Plain Paper Fax
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Not receiving any faxes but sending
Note: check your equipment for:
Fax machine must be connected to an answer machine
Receiving a fax automatically:
1 Make sure the Fax Auto Answer light is on.
2 To set the number of telephone rings before the printer automatically receives faxes,
Receiving a fax with an answering machine
When a telephone ring is detected, the answering machine picks up the call.
If the printer detects a fax, it receives the fax and disconnects the answering machine.
If the printer does not detect a fax, the answering machine receives the call.
2 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
3 To set the number of telephone rings before the printer automatically receives faxes.
Oct 31, 2008 | Lexmark X5470 All-In-One InkJet Printer
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
My model Kodak 5500 printer/fax
Just found your post and I'm having the same problem. Everything else seems to be working correctly. I can copy, scan, print and I THINK I can send a fax correctly, I should have called the person and made sure it arrived. However, I cannot receive faxes. I have an answering machine on the line, but it is not plugged into the Kodak Pinter, it is in another room. The answering machine answered the call, the FAX noise came across, but the Kodak Printer never picked it up and printed out the fax. I think I have all the settings correct, but the instructions are not very clear. Do you think I HAVE to have the answering machine plugged into the Kodak Printer? That doesn't make sense, but I might try it.
Feb 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer Logo
359 people viewed this question
Ben Johnson
