Hi, My electrolux EWT 959 washing machine keeps saying please close the lid when the lid is closed. The machine filled up full of water before saying this & now wont finish the wash. Are you able to help me. Donna.
Hi Donna,
I just wondering have you solved the problems? as I have a similar problems in the same washing machine model. Please advse if you've solved the problems and how
Thanks
Posted on Oct 06, 2011
My EWT 959 starts to fill then after about 20 seconds stops and does nothing. After a while it says turn on taps. Is there filters we can check and clean which may be confusing the machine?
Hi,first has some one turnd the water supply off for the washing machine,there are usally little filters that are where the water supply hosses connect to the back of the machine,hope this was some help all the best.
Mar 05, 2016 | Electrolux Washing Machines
Electrolux ewt 115
Hi Cong Tran.
To buy parts for your machine you should go the the manufacturers distributor with the full model number. (The shop where you bought the machine may be able to help you with that information) The parts shop can easily tell you cost and availability of the part.
Good Luck
Cheers
Nomess
Jan 03, 2015 | Electrolux Washing Machines
I have an Electrolux Washer machine model EWT959 and it currently problem is:- 1. "Choose Program & Start" 2. Once "Start/Pause" button pressed to start the wash 3. The message on...
It doesn't think the lid is actually closed indicating that there is a problem either with the lid lock or the lid locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Oct 06, 2011 | Electrolux Washing Machines
I have a LG washing machine model WT-R851 that will fill machine with water and drain water, but will not go thru the washing cycle or spin dry ,the red light flashes saying that the lid is opened and...
If I understand the symptoms the fact that the red light flashes saying that the lid is open suggests to me that there is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor. Both require a service engineer's attention I suggest ;-0(
John C
Apr 29, 2011 | Washing Machines
I have model # LA5558XTW2 washing machine. I have power to the machine. It fills with water but nothing happens after it is full. The lid closes flush and makes the correct contact. Can you help
have u checked the timer? if the lid switch is working properly next step would be to check your timer make sure the lid switch is activating when you open and close the lid
Jul 13, 2010 | Washing Machines
Machine fills with water then will not start wash ( lid is closed
Check he lid switch and or replace it, should fix your problem.
Nov 25, 2009 | Kenmore Washing Machines
Washer will not fill with water
Check the lid switch...this controls all power to the machine and if the lid isn't closed, it can interrupt the water fill even with the lid appearing to be closed. Press firmly on the center of the lid when it's closed. Sometimes the lids on these maytags get tweaked a little and then don't allow full contact with the switch... Let me know ..
KEN
May 10, 2009 | Maytag Dependable Care LAT9206
Will not complete cycle
hi. i would check the lid switch fill the tub to low level let it start to wash stop the washer now put it to the spin cycle pull out knob close the lid slowly if it does not pump replace the lid switch now push on the lid. if it goes now .replace the lid switch .thanks te appliance doc. rate me please
Aug 22, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
425 people viewed this question
Top Washing Machines Experts
