Question about GE GTR11AAP Top Freezer Refrigerator
I have a reletivly new ge gts18gbsarww frig. the fan runs ok the top frosts up completly and the bottom keeps getting warmer and warmer. i f shut it off it will work about 2 to 3 weeks ok then start to freez up again. what controlls the defrost cycle and where is the modul located or is the problem someting else. can you sell me what i need and tell me where the parts are located? thanks. Norm Boss1939@comcast.net
tborn6
  • 700 Answers
SOURCE: freezer is frosting up
check your gasket on the freezer it may not be sealing properly. that is the main cause of the freezer compartment frosting up. also when you defrosted it did you otice if the drain line was clear and the water was going out of the freezer?
Posted on Dec 27, 2008
Healeyman
  • 1198 Answers
SOURCE: Bottom of frig freezes, top is 60 degrees
Check your door fit. The gasket should be tight all the way around, you can push the door back into shape.
Posted on Apr 27, 2009
cj2176
  • 520 Answers
SOURCE: GE side by side ffreezer continues to frost over
A simple defrost may not be all that is needed. There is a piece that connects to the coils called a defrost timer or a " clixon " This is most likely the problem. Have it replaced and that should get you back in business. Hope this helps. Good luck.
Posted on Jul 09, 2009
aasc
  • 1606 Answers
SOURCE: GE GSH22KGM Frig not defrosting again
I would suggest replacing the # 4 thermistor , which is a 1 " long white piece with 2 white wires attached , clipped to the top of the coils . This thermistor , tells the main control board , the temperature of the coils and the board decides what to do next , such as defrost , end defrost cycle . Also , replace the defrost thermostat , the 1 inch cylinder with 2 wires going to it , which is also clipped onto the coils . This thermostat , cuts the heater off when it reaches a certain temperature , to keep the food from defrosting . It may also help , to replace the # 5 thermistor , which is below the coils , slid into a housing , with 2 white wires going to it also . This thermistor , tells the board , the actual freezer temp , so the compressor will cycle off/on , and the fan speed also . All 3 parts , are relatively not expensive . Be sure to get wire connectors because they do not come with these parts .
Posted on Apr 14, 2010
Testimonial: "Gave excellent help and advice. "
heatman101
  • 43501 Answers
SOURCE: Freezer frosts up, frzer & frig loose temp. Need to defrost freq
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 01, 2010
I have a GE Model #TBX18NI- 18.2cuft top freezer/refrigerator, and the freezer part is working great, but the refrigerator part seems to be getting warmer and warmer. I've tried adjusting the temp...
The frig has a defrost timer which activates an electric element which cyclially defrosts the evaporator in the freezer.If either the heating element or the defrost thermostat are faulty the freezer evaporator will freeze solid not allowing cold air circulation to the rest of the frig.
At a suiteable time empty fridge contents into insulated containers and turn fridge off at powerpoint and allow to fully defrost leaving doors open.The evaporator coil in frostfree is normally located behind the rear panel of the freezer.If you do not have defrost heater it will take 3-4 hrs for complete defrost.
After defrost turn fridge back on and make sure items to be returned to freezer are free from moisture and ice and keep freezer open for minimum of time as moisture will start building up onthe evapoator.
If the fridge works ok for a couple of days and the the original problem returns the problem is with defrost thermostat or defrost heater
Apr 29, 2011 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Older (serial # erased) GE freezer top frost free Water pools in bottom of frig. cannot find drain.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Drain is under the coils and may be froze shut...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Frosting up of freezer fan/fan runs continuously
Clean and check the seals around the doors, the unit is trying to compensate for temperature loss.
Jul 27, 2009 | Refrigerators
GE GSS25KGSA.... the freezer is no longer freezing regardless of temperature setting. It gets cold but no freezing. There used to be more noise during cycles, but that has stopped also.
The fan that circulates air in the freezer compartment is frozen & not circulating air - resulting in a freezer compartment that is cool but not cold. The reason is that the “heater & bracket” that warms & defrosts the evaporator coil & the fan above it has died & w/no defrosting, the coil & the fan load up with frost & ice & stop working.
Temporary Solution:
1) Unplug the frig.
2) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
3) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes. (if you leave them in the freezer, they will melt & refreeze & make a disaster).
4) There is a metal panel below the lights & it should have frost & ice built on it.
5) Get two (not one) hair driers, set them on high heat & melt all the frost & ice & keep on melting & defrosting for about 10 minutes.
4) Plug the frig back in.
5) The freezer fan should be turning.
6) Put the shelf & food back in & close the door.
7) Expect this problem to reoccur in one to four months...
Solution:
1) Get a “heater & bracket” GE part number WR51X10055, about $30 w/shipping on eBay. This is for a GSS25KGSA GE side by side (the last two letters WW, BB, & CC are colors). If you have a different GE side by side, the correct part number can easily be found at www.searspartsdirect.com. Nice drawings.
2) Unplug the frig.
3) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
4) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes.
5) Take out the light cover. One Philips screw on top & two press-to-release plastic things on the bottom.
6) Unscrew the light bulbs.
7) Take out the metal panel below the lights. Four ¼” screws. It is held in by two tabs at the top, so swing the bottom out & pull it down. Be careful not to bend it.
8) Get two (not one) hair driers, set them on high hot & melt all the frost & ice on the evaporator coil. Do NOT touch it.
9) Remove the “Heater & Bracket” by unscrewing the two Phillips screws and then unplugging the red & blue wires.
10) Install the new “Heater & Bracket” by plugging in the red & blue wires & replacing the two screws. Be careful not to get it backwards when plugging the wires; only goes one way.
11) Put the back panel back in & secure it with the 4 ¼” screws.
12) Reinstall the lights & cover.
13) Plug the frig back in.
14) Put the shelves & food back in & close the door.
15) Expect this problem to reoccur every 3-4 years; great designs fail after the warranty is up, and keep the repairmen & parts people employed …
p.s. about once a year, you should vacuum all the accumulated dust off the condenser coils. They are hidden behind a metal cover at the bottom back of the refrig. If you don't, expect the dust eventually block all airflow & the compressor will burn up & you will be buying a new frig.
Generic GE Side by Side Refrigerators GSS25KGSA, GSS25KGSAWW, GSS25KGSABB, GSS25KGSACC.
Jul 08, 2009 | GE Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer not freezing enough and fridge not cold enough
Hello Scott, remove the food from the freezer side and remove the rear freezer panel. You will see a coil and it should be completely frosted over. If not then you have a sealed system issue. If it is froze solid in frost where you cannot even see the coil, then you have a defrost issue. You should have a little frost on all the coil, the defrost is what clears the frost so the evap fan motor can circulate the air thru out the unit. If frost is good, push the light door switch to start the fan. If it isn't running check for 120 volts. If it has voltage, but not running, replace the motor. Hope this helps.
Aug 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Confused /
Ok the freezer section works the refrig section think of the refrigerator as a large cooler with an inlet and outlet hole cold air is blown into the refrig from the freezer via the fan motor in the freezer the really cold air comes in the top of the refrig and drops to the bottom of the refrig then it is sucked back into the freezer thru a vent hole in the bottom of the refrigerator ..GOT IT?? Now when a unit has a defrost problem there is an ice or frost build up in the freezer on the coil (bad heater,bad bi metal, bad timer can cause this) the ice builds and builds to the point where it blocks the air flow across the coil hence the air can not get to the refrigerator section making it warmer but the freezer section will work ok .. I hope this makes sense...Hint : A sign of this is a lg frost buildup on the back wall of the freezer.
Nov 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Refrigerator Model GSS20IEDPD
check the back panel inside the freezer section near the lower shelf (not the bottom bim) for frost
Oct 14, 2007 | Refrigerators
GE GTR11AAP Top Freezer Refrigerator Logo
88 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
