Question about Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
My polaroid widescreen lcd tv/dvd combo, when turned on the sound comes on but the screen stays black. I have tried everything. I checked the Direct TV , all inorder. The TV screen when all black while I was in bed watching it and has not had a picture since this morning. Just a black screen. please help
  • Polaroid Master
  • 5,161 Answers
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing. For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. See http://www.lcdparts.net/howto/default.aspx for more information but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Nov 14, 2010
  • Sherry Woodbeck Nov 13, 2011
    This is my issue exactly!! Sound is fine, black screen. It actually comes on for a moment if shut off for a long time, and get's shorter in duration the more I turned it on/off/on/off as if that was going to fix it!! LOL!! Thank you for the time, attention and detail of your answer.
The screen is completely black. you can hear sound but the screen is still black.
Try unplugging everything then unplug the TV for a minute plug everything back in turn on. It might be the main board that needs replaced on it if that wont work. FYI LCD TV/ DVD Combos have been known to have issues
Jan 27, 2011 | Proscan 32LB30QD 32 in. LCD TV
Black screen
You may have blown power supply for the backlight inverter or blown backlight inverter board, either one are cheap!,
This is cheaply made TV to begin with. Repiar shop will charge you $200 and up plus parts.
http://www.shopjimmy.com/catalogsearch/result/index/?q=Polaroid+TDA-03211C+&limit=100&p=2
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
I have a 32" HD widescreen LCD TV/DVD combo. TDA03211c. When I put a dvd in to play it makes a noise and puts some digital garbage on the screen. Will not play dvds.
Sounds like the DVD player is defective. Just food for thought.. Try not invest in any make with a built in DVD player, they just don't last.
Oct 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid fdm-0700 with black screen display. DVD
go here and order the replacement inverter board. this will fix the backlight issue or no picture issue
http://lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=UI8007S-1MSS
Aug 09, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Jun 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Polaroid flm373b
Try several different inputs.
Sep 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Polarid tv-dvd combo power trouble
TROUBLE WITH REMOT CONTROL. I CANNOT PROGRAM MY DIRECT DISH
Jan 02, 2008 | Polaroid FLM-3225 32 in. LCD Television
Ilo 42"widescreen lcd tv
I hooked a sylvania 220sl8 dvd/cd/vcr, The vcr works, the dvd does not. Why?
Oct 27, 2007 | iLO 2600 Television
Polaroid 1913TDXB 19 in. LCD TV/DVD Combo Logo
302 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
