Question about Dishwashers
Dishwasher constantly trying to drain, won't wash/work
I can't get my dishwasher to do anything since moving it to a new house. Cold feed is connected and working ok (tested) and it has power, it seems to be making a noise like it is constantly trying to drain, even though there is no water in it. I can't select any programmes and it won't do any thing else. I wonder if its the anti flood device? a lot of water came out of it when it was moved and water is still seeping from underneath. Is this likely? do you know how I can find and reset it, or empty it of water if that's the problem?
caro500m@yahoo.com
Thanks, Caroline
  • caro500m Jun 18, 2008
    Please READ my problem!
    Master:
  • 788 Answers
Sounds like your drain valve is stuck open. Either that or the drip tray under the machine is full of water actioning the flood float. Mop up the water in the sump area and see if that helps as the pump cannot empty the sump.
Posted on Jun 18, 2008
  • 796 Answers
The control is having some fault...
you have to change the control board or chip
    Genius:
  • 3,422 Answers
If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
  • Priya darshan Jun 18, 2008
    If the water doesn't drain from your dishwasher, check these:
    Drain line/air gap
    Pump
    Drain valve and/or solenoid
    Belt
    Motor
    Timer
    Drain line/air gap
    A
    clog in the drain line or air gap (if there is one) is the usual reason
    that a dishwasher won't drain. Often the problem is at the point where
    the drain line attaches to the garbage disposer or household drain
    line. If you remove this line, you can clear any debris from the hose
    or hose connection. Be sure to reattach the hose before starting the
    dishwasher again.
    Pump
    Your
    dishwasher pump ejects the water. The pump is usually mounted directly
    to the motor, then attached to the bottom of the dishwasher. You can
    reach the pump from inside the dishwasher, but first you need to remove
    the lower rack, the spray arm, and the spray arm support.
    Look
    for an impeller--a round plastic fan blade-type of device that spins
    around. This is the wash impeller, which forces the water through the
    spray arm. Beneath the wash impeller is the drain impeller, which is
    similar in size and shape to the wash impeller. The drain impeller
    pushes the water toward the drain port. These components make up the
    pump. If any of the pump components are defective, you need to replace
    them.
    Many
    dishwashers use a drain valve with an electric solenoid. When
    electricity flows to the solenoid, the valve opens and diverts the
    water to the drain. Sometimes the solenoid, or the diverting lever,
    sticks and prevents the dishwasher from draining or filling properly.
    Try to free up the solenoid to lubricate the lever. Otherwise, you may
    have to replace the solenoid or pump assembly. With these systems, the
    motor always rotates in one direction. When it's energized, the drain
    valve diverts the water.
    Other dishwashers simply reverse the
    direction of the motor to drain the dishwasher. These units don't have
    a drain valve. Instead, there's a drain hose connected directly to the
    pump housing.
    Belt
    One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
    Motor
    If
    the motor isn't turning or working, the unit won't drain. First check
    to be sure you have power to the dishwasher. If not, see the section
    "It doesn't work at all." If the motor hums but doesn't turn, it may
    need to be replaced.
    Some dishwashers are susceptible to
    getting stuck if you don't run them regularly. If you haven't run the
    dishwasher for more than a week, you may need to manually spin the
    motor to free it up. If the motor is defective, you need to replace it.
    Dishwasher motors can't be serviced.
    Timer
    Part
    of what the timer does is control the motor and drain valve. If the
    timer doesn't work properly, the water may not drain and you need to
    replace the timer. This problem is uncommon.
Hotpoint diswasher won't drain or switch off and is constantly flashing f-2 , model is FDYF 2100 K
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
see the diagram attached, and proceed according.
May 24, 2013 | Hotpoint Dishwashers
Hotpoint Aquarius FDW60 won't take in water. Suspected airlock after house move?!?
Try checking the inlet solinoid , should be 1 for hot & cold, sometimes the solinoid will freeze up due to alkaline buildup .try soaking it in CRL , alkaline deposit desolving liquid .
Mar 13, 2012 | Hotpoint 24 in. FDW60 Free-standing...
The dishwasher does not work at all and there is water in the bottom. I tried to see if there was a blockage but couldn't find anything.
Usually when this occurs on an older model the motor has stuck. It requires shutting
off power at the circuit breaker that feeds the dishwasher. Then manually rotating
the motor shaft either by moving the fan blade located in the metal housing inside the
slot near the plastic pump (at the back of the motor itself for round motors).
or move the aluminum fins which are easily seen on the front of square pumps.
This applies only to
single pump units like Hotpoint, Kenmore, or GE. for others, such as Frigidaire or
Haier, often the drain pump has failed. Remember to give a little silicone spray on
the bearing ends and to make sure the disposal is working on the sink if you have one
since most dishwashers drain through them.
May 29, 2011 | Dishwashers
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
I have 4 year old Hotpoint washing machine with hot feed and cold feed. have moved to new house with only cold feed. Will it still work? Do I need to plug the blank hot feed on back of machine?
It Will work ...However you will need a Y piece connector both hot and cold hoses connect to this costs around £2.. ..A cheap fix..
Feb 08, 2010 | Washing Machines
Water will not drain out of dishwasher
I would remove the drainhose from sink and try draining in to a pale.if it does not then you will need to remove drain hose and clean out.Also you may need to clean out all screens in pump just remove with torx screwdriver easy when you get into it
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Washing indicators light is flashing and dishwasher won`t start
try to start again while applying closing pressure {push in} at the top of door where latch mechanism is if it starts then it's an adjustment that needs to be done on the door latch
Feb 20, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
G865 - Constantly draining
Your problem is a water leak.  There are a couple of rubber seals that are required to correct the problem.. When the seal leaks it accumulates in a tray in the bottom where a sensor turns on the pump when water is present.  If you remove the lower access panel and reach in you should see the accumulated water.  I had a repair tech repair mine.
Aug 20, 2008 | Miele 24 in. G865 Built-in Dishwasher
Dishwashers Logo
247 people viewed this question
Top Dishwashers Experts
