Question about GE (PSS26MSRSS) Side by Side Refrigerator
My freezer is working and my fridge does not, it is warm, and the controls are on the front of the fridge,
  • 3 Answers
You have a defrost problem, After a few more days the freezer will stop working also. If you would defrost the unit by turning it off then it will start back working, but will only work for about 5 to 7 days. You will need to determine if it is the mother board on the back or if it is only the defrost heater. To do this you will need to remove the defrost heater in the freezer and check it for continuity.
Posted on Nov 14, 2010
HOT SPOT IN FRONT DIVIDER BETWEEN FRIDGE AND FREEZER
Greg,
That is usually a heating element that is used to prevent condensation from developing in that area. It should cycle on and off and be slightly warm, but not get real hot. Check around your controls and see if there is a switch for something like Energy control or something like that, the exact term is escaping my memory, and you might be able to turn it off. Hope this helps!
Jul 12, 2015 | Admiral Refrigerators
Fridge to warm freezer build up of ice at bottom
fridge to warm? check thermistor, the cold control ( sometimes called defrost timer) and the air control assembly, check to see if air control is to far closed or opened? the inlet to the fridge from freezer. sometimes a bad defrost terminator will hinder the air flow and freeze up the fan from operating and freezer section thus no air flow to the fridge..
Mar 12, 2015 | Refrigerators
Gsc3pgxcfss warm fridge, freezer working fine
It could be the servo on the diverter door, but it's most likely to be the main control board. Sorry.
Mar 23, 2014 | GE Refrigerators
Amana fridge freezer AS2628HEKB fridge warm & freezer frosty inside
The board should be replaced before the unit will operate properly. Be sure to check out all circuits to make sure there is not some kind of short. If there is, it may burn out the new board also.
Jan 21, 2013 | Refrigerators
Defrosting issue or need to replace refrigerator?
If your refrigerator was manufactured in 1999, it is way overdue for replacement.
Apr 05, 2017 | Magic Chef CTF2125 Top Freezer...
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Mar 09, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
